08-26-2019, 12:29 | #1 (permalink) | |
Freak Poster Join Date: Jul 2016 Location: eMMC/UFS/SPI/JTAG
Member: 2598878 Status: Offline Thanks Meter: 99 | LG V10 Data Recovery [Solved] Quote:
08-28-2019, 07:05 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Did You try to perform Read Full Flash? If no, then try to do it and post here full Software log |
The Following User Says Thank You to Medusa Box For This Useful Post: |
08-28-2019, 15:09 | #4 (permalink) | |
Member: 2598878 Status: Offline Thanks Meter: 99 | When i try full read... Is possible to fix it? Quote:
08-28-2019, 15:16 | #5 (permalink) | |
Member: 2598878 Status: Offline Thanks Meter: 99 | When i change voltage Quote:
08-29-2019, 06:54 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Please, try to use another USB cable, check all soldered wires, then repeat operation again, if problem will still remain, try to use another PC. |
08-29-2019, 09:23 | #8 (permalink) | ||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
That's why we recommend You to: Quote:
08-30-2019, 00:49 | #9 (permalink) | |
Member: 2598878 Status: Offline Thanks Meter: 99 | New cable and new port is better but now i have about 50% and Quote:
08-30-2019, 00:57 | #10 (permalink) | |
Member: 2598878 Status: Offline Thanks Meter: 99 | this is All log for read. Quote:
08-30-2019, 11:16 | #12 (permalink) | |
Member: 2598878 Status: Offline Thanks Meter: 99 | Still the same problem Quote:
08-31-2019, 21:16 | #13 (permalink) |
Member: 2598878 Status: Offline Thanks Meter: 99 | I solved the problem. You must set Voltage : 1.8V Bus Mode : 1 bit Bus speed :10Hz |
The Following 2 Users Say Thank You to WerVa21 For This Useful Post: |
