01-19-2018, 09:51 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Algeria
Member: 2105719 Status: Offline Thanks Meter: 20 | LG V10 VS990 Repaired [Answered] A customer gave me his LG V10 to repair network problems. I knew the phone is refurbished, The software version is H901 while the Phone PCB is VS990, Accidentally I flashed the phone with Latest H90021w firmware, The Phone is in a working condition, but there is numerous problems, like security settings doesn't work, network .... Then I realized I made a mistake , it should be a Verizon VS990 firmware flashed on the Phone not a H900 firmware, So I tried with VS990 KDZ firmware, Whenever I flash a version, The Phone goes back to Qualcomm Mode, I tried with most of VS990 firmwares but Phone keeps dying. The only firmware he accepts is H90021w which has so many problems as mentioned before. After a little digging, I found that the latest version of H900 which is H90021w has an AntiRollback version = 2 while the latest version of VS990 has an AntiRollback version = 1. So is there anyway I could fix this miserable problem? If I do Full erase feature on Medusa Then flash with latest VS990 kdz, Will that work? Last edited by Medusa Box; 01-19-2018 at 10:07. |
01-19-2018, 10:06 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello. Unfortunately, no solution on how to downgrade bootloaders version and full erasing will no help to solve the problem. You can try to write V30x firmware for H901 (http://forum.gsmhosting.com/vbb/f664...l#post12776707), maybe this will help, but note, writing not compatible firmware version may lead to damage the device, so write firmware at your own risk. |
01-19-2018, 10:31 | #3 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: pakistan Age: 27
Member: 2498409 Status: Offline Thanks Meter: 127 | Quote:
brother u flash firmware vs990 via medusa pro i have same problem i solved with medusa pro full flash via medusa pro ur problem solved | |
01-19-2018, 12:08 | #5 (permalink) | |
Member: 2105719 Status: Offline Thanks Meter: 20 | Quote:
01-19-2018, 12:39 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Yes, also You can try to find the same device, update it via OTA to the latest firmware version, read out full flash and write this full flash into your device. |
01-19-2018, 21:02 | #7 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Quote:
http://forum.gsmhosting.com/vbb/12914277-post877.html you need two firmware 1st H90021w and 2nd vs990 v28 | |
The Following User Says Thank You to maanarman For This Useful Post: |
01-19-2018, 22:53 | #8 (permalink) | |
05-03-2018, 14:41 | #11 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Quote:
