09-20-2017, 13:06 | #1 (permalink) |
Freak Poster Join Date: Jan 2015 Location: manshera,Pakistan
Member: 2330556 Status: Offline Thanks Meter: 79 | LG VS990 REPAIR boot done but still dead [Solved] I flashed with latest f.w and phone become dead after flashing.. Repaired with medusa with same firmware but phone is still dead The model on back sticker is H900..and the model written on pcb is VS990.. So i flash the phone with vs990 f.w and it slept forever.. repair logs.. Parsing file... Opening D:/firmware/LG/FIRMWARE/VS99029A_01_0817.kdz file... File parsing finished. Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition pmic... Done. Writing partition sbl1... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition hyp... Done. Writing partition rpm... Done. Writing partition aboot... Done. Writing partition sbl1bak... Done. Writing partition pmicbak... Done. Writing partition hypbak... Done. Writing partition tzbak... Done. Writing partition rpmbak... Done. Writing partition abootbak... Done. Writing partition sdibak... Done. Writing partition persist... Done. Writing partition sec... Done. Writing partition rct... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Last edited by Medusa Box; 09-21-2017 at 10:19. |
09-20-2017, 13:32 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
Also this can be software problem - boot loaders in firmware file which You have used for repairing ("VS99029A_01_0817.kdz"), could be not suitable (not compatible) with your phone (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to find the other original LG firmwares for this phone model and do "Factory Repair" using them. Also, try to do "Factory Repair" using the latest firmwares for H900 and H901. | |
09-20-2017, 13:55 | #3 (permalink) | |
Member: 2330556 Status: Offline Thanks Meter: 79 | Quote:
09-20-2017, 14:58 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to do "Factory Repair" using the latest firmwares for H900 and H901. If the problem is still the same, most likely, your device has HW issue. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
09-21-2017, 10:12 | #5 (permalink) |
Member: 2330556 Status: Offline Thanks Meter: 79 | Thanks solved with firmware for h90021w Last edited by Medusa Box; 09-21-2017 at 10:19. |
The Following User Says Thank You to arsikhanarsi For This Useful Post: |
