12-29-2017, 12:15 | #1 (permalink) |
Insane Poster Join Date: Dec 2016 Location: Belo Horizonte - MG
Member: 2658469 Status: Offline Thanks Meter: 20 | "Live Log" or EXT_CSD for GT-I9200 request [Answered] I have one Gt-i9200, i replace the emmc, but dont works, can be boot configuration. I did not get access to nand for backup of ext_csd or see boot configurations, does anyone have the loge of this device, or do you know which boot configuration? Thanks. Last edited by Medusa Box; 12-29-2017 at 13:48. |
12-29-2017, 13:46 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Currently we have no this device. We will try to buy it, connect and provide You correct boot configuration. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
01-03-2018, 07:12 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Here is "Live Log" for You: Code: Welcome to Medusa Pro Software version 1.5.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 016G92 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1101003031364739323010C74C0B400D Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 016G92 Product revision : 3.0 Product serial number : (hex) 10C74C0B Manufacturing date : 04/2013 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFEF92400045 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7700480 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/016G92_02_01_2018_12_56_19.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: modem (00002000, 0001E000) 60 MB P02: sbl1 (00020000, 00000100) 128 KB P03: sbl2 (00020100, 00000200) 256 KB P04: sbl3 (00020300, 00000400) 512 KB P05: aboot (00020700, 00001000) 2048 KB P06: rpm (00021700, 00000400) 512 KB P07: tz (00021B00, 00000400) 512 KB P08: pad (00021F00, 00006400) 12.5 MB P09: param (00028300, 00004000) 8 MB P10: efs (0002C300, 00006D00) 13.62 MB P11: modemst1 (00033000, 00001800) 3072 KB P12: modemst2 (00034800, 00001800) 3072 KB P13: boot (00036000, 00005000) 10 MB P14: recovery (0003B000, 00005000) 10 MB P15: fota (00040000, 00005000) 10 MB P16: backup (00045000, 000037F0) 6.992 MB P17: fsg (000487F0, 00001800) 3072 KB P18: ssd (00049FF0, 00000010) 8 KB P19: persist (0004A000, 00004000) 8 MB P20: system (0004E000, 003C0000) 1920 MB P21: cache (0040E000, 00064000) 200 MB P22: hidden (00472000, 00032000) 100 MB P23: userdata (004A4000, 018B4000) 12.35 GB |
