05-03-2018, 10:49 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: BiH
Member: 825846 Status: Offline Sonork: kalaba Thanks Meter: 23 | LS777 repair boot ok but no power on [Answered] before I did the same while it was ok I did the backup firmware in tot format I tried to type this complete but also all ended but the phone does not fire Code: Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 3.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A420C18C0AA4A3 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.4 Product serial number : (hex) 20C18C0A Manufacturing date : 10/2017 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 7602176 Device Manufacturer :lge Device Platform :msm8937 Build ID :NRD90U Display Build ID :NRD90U Release ID :7.0 Device Model :LG-LS777 Device Name :sf340_spr_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :sf340_spr_us-user 7.0 NRD90U 171561308fd04 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4a2_16_04_2018_18_45_20.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.7; FW: 1.23. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: tzbak (00033000, 00001000) 2048 KB P06: sbl1 (00034000, 00000800) 1024 KB P07: sbl1bak (00034800, 00000800) 1024 KB P08: rpm (00035000, 00000400) 512 KB P09: rpmbak (00035400, 00000400) 512 KB P10: devcfg (00035800, 00000400) 512 KB P11: devcfgbak (00035C00, 00000400) 512 KB P12: cmnlib (00036000, 00000400) 512 KB P13: cmnlibbak (00036400, 00000400) 512 KB P14: cmnlib64 (00036800, 00000400) 512 KB P15: cmnlib64bak (00036C00, 00000400) 512 KB P16: keymaster (00037000, 00000400) 512 KB P17: keymasterbak (00037400, 00000400) 512 KB P18: spare1 (00037800, 00000400) 512 KB P19: spare2 (00037C00, 00000400) 512 KB P20: persistent (00038000, 00000400) 512 KB P21: devinfo (00038400, 00000800) 1024 KB P22: spare3 (00038C00, 00003400) 6.5 MB P23: modemst1 (0003C000, 00000C00) 1536 KB P24: modemst2 (0003CC00, 00000C00) 1536 KB P25: mcfg (0003D800, 00002000) 4 MB P26: fsc (0003F800, 00000400) 512 KB P27: ssd (0003FC00, 00000400) 512 KB P28: fsg (00040000, 00000C00) 1536 KB P29: spare4 (00040C00, 00003400) 6.5 MB P30: dsp (00044000, 00008000) 16 MB P31: ftm (0004C000, 00004000) 8 MB P32: misc (00050000, 00004000) 8 MB P33: drm (00054000, 00004000) 8 MB P34: sns (00058000, 00004000) 8 MB P35: fota (0005C000, 00005000) 10 MB P36: sec (00061000, 00000400) 512 KB P37: keystore (00061400, 00000400) 512 KB P38: rct (00061800, 00000400) 512 KB P39: encrypt (00061C00, 00000400) 512 KB P40: eksst (00062000, 00000400) 512 KB P41: apdp (00062400, 00000400) 512 KB P42: msadp (00062800, 00000400) 512 KB P43: dpo (00062C00, 00000400) 512 KB P44: DDR (00063000, 00000400) 512 KB P45: spare5 (00063400, 00000C00) 1536 KB P46: boot (00064000, 00010000) 32 MB P47: laf (00074000, 00010000) 32 MB P48: lafbak (00084000, 00010000) 32 MB P49: recovery (00094000, 00010000) 32 MB P50: recoverybak (000A4000, 00010000) 32 MB P51: factory (000B4000, 0001C000) 56 MB P52: raw_resources (000D0000, 00002000) 4 MB P53: raw_resourcesbak (000D2000, 00002000) 4 MB P54: persist (000D4000, 00010000) 32 MB P55: mpt (000E4000, 00004000) 8 MB P56: carrier (000E8000, 00014000) 40 MB P57: system (000FC000, 00740000) 3712 MB P58: cache (0083C000, 00268000) 1232 MB P59: userdata (00AA4000, 0127AFDE) 9.24 GB P60: grow (01D1EFDE, 00000001) 512 b Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing aboot partition... Done. Writing abootbak partition... Done. Writing tz partition... Done. Writing tzbak partition... Done. Writing sbl1 partition... Done. Writing sbl1bak partition... Done. Writing rpm partition... Done. Writing rpmbak partition... Done. Writing devcfg partition... Done. Writing devcfgbak partition... Done. Writing cmnlib partition... Done. Writing cmnlibbak partition... Done. Writing cmnlib64 partition... Done. Writing cmnlib64bak partition... Done. Writing keymaster partition... Done. Writing keymasterbak partition... Done. Writing spare1 partition... Done. Writing spare2 partition... Done. Writing persistent partition... Done. Writing devinfo partition... Done. Writing spare3 partition... Done. Writing mcfg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing fsg partition... Done. Writing spare4 partition... Done. Writing dsp partition... Done. Writing ftm partition... Done. Writing misc partition... Done. Writing drm partition... Done. Writing sns partition... Done. Writing fota partition... Done. Writing sec partition... Done. Writing keystore partition... Done. Writing rct partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing DDR partition... Done. Writing spare5 partition... Done. Writing boot partition... Done. Writing laf partition... Done. Writing lafbak partition... Done. Writing recovery partition... Done. Writing recoverybak partition... Done. Writing factory partition... Done. Writing raw_resources partition... Done. Writing raw_resourcesbak partition... Done. Writing persist partition... Done. Writing mpt partition... Done. Writing carrier partition... Done. Writing grow partition... Done. Smart Repair is successfully complete. SW: 1.5.7; FW: 1.23. Disconnected. Last edited by Medusa Box; 05-03-2018 at 14:37. |
05-03-2018, 14:36 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Accordingly to your Software log, repair process was performed successfully and correctly. If the device doesn't go into Download Mode, here can be two main reasons of this problem - device has HW issue or boot loaders in SRF, that You have used for repairing, could be not suitable (not compatible) with your phone (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to find original firmware (the same version as was in the device before or higher version) and do "Factory Repair". |
05-03-2018, 15:17 | #3 (permalink) |
Member: 825846 Status: Offline Sonork: kalaba Thanks Meter: 23 | the version was ZVA and I did before that backup firmware phone worked properly before I tried to lower the version ... after I enter and his code firmware does not fire again I dont find fw original zva or new version for this model Last edited by kalser; 05-03-2018 at 16:07. |
05-04-2018, 04:54 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Unfortunately, we also don't have ZVA or higher firmware version for this device model at the moment. If You have the same device model in working state, You can read out full flash from it and write it into your "dead" device. Also maybe someone have such full flash/dump and he will upload here for You. Please also check here: http://forum.gsmhosting.com/vbb/f799...wered-2370724/. Last edited by Octopus box; 05-04-2018 at 05:35. |
04-03-2019, 09:03 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | @Annier84 Hello. Well Medusa Pro software was developed to repair dead boot devices, so how You manage to "kill" dead boot devices?! |
