04-08-2019, 02:44 | #1 (permalink) |
Insane Poster Join Date: Jul 2009
Member: 1072857 Status: Offline Thanks Meter: 4 | LS777 repair issue [Answered] I am trying to repair boot of LS777 ZVB version (Hynix eMMC HAG4a2) I did a factory repair with LS777ZVE_08.tot version via Medusa pro Jtag.Now device doesnt power on but it is detected as LGE AndroidNet USB Serial Port. What should i do about? Best Regards Welcome to Medusa Pro Software version 1.7.6. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 SRF "K:/LG_LS777_EMMC.SRF" has been installed successfully. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : K:/LG_LS777_EMMC.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A432A835A7A4D3 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.4 Product serial number : (hex) 32A835A7 Manufacturing date : 10/2017 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 7602176 Device Manufacturer :lge Device Platform :msm8937 Build ID :NRD90U Display Build ID :NRD90U Release ID :7.0 Device Model :LG-LS777 Device Name :sf340_spr_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :sf340_spr_us-user 7.0 NRD90U 181981140cdc9 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG4a2_07_04_2019_14_45_56.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: tzbak (00033000, 00001000) 2048 KB P06: sbl1 (00034000, 00000800) 1024 KB P07: sbl1bak (00034800, 00000800) 1024 KB P08: rpm (00035000, 00000400) 512 KB P09: rpmbak (00035400, 00000400) 512 KB P10: devcfg (00035800, 00000400) 512 KB P11: devcfgbak (00035C00, 00000400) 512 KB P12: cmnlib (00036000, 00000400) 512 KB P13: cmnlibbak (00036400, 00000400) 512 KB P14: cmnlib64 (00036800, 00000400) 512 KB P15: cmnlib64bak (00036C00, 00000400) 512 KB P16: keymaster (00037000, 00000400) 512 KB P17: keymasterbak (00037400, 00000400) 512 KB P18: spare1 (00037800, 00000400) 512 KB P19: spare2 (00037C00, 00000400) 512 KB P20: persistent (00038000, 00000400) 512 KB P21: devinfo (00038400, 00000800) 1024 KB P22: spare3 (00038C00, 00003400) 6.5 MB P23: modemst1 (0003C000, 00000C00) 1536 KB P24: modemst2 (0003CC00, 00000C00) 1536 KB P25: mcfg (0003D800, 00002000) 4 MB P26: fsc (0003F800, 00000400) 512 KB P27: ssd (0003FC00, 00000400) 512 KB P28: fsg (00040000, 00000C00) 1536 KB P29: spare4 (00040C00, 00003400) 6.5 MB P30: dsp (00044000, 00008000) 16 MB P31: ftm (0004C000, 00004000) 8 MB P32: misc (00050000, 00004000) 8 MB P33: drm (00054000, 00004000) 8 MB P34: sns (00058000, 00004000) 8 MB P35: fota (0005C000, 00005000) 10 MB P36: sec (00061000, 00000400) 512 KB P37: keystore (00061400, 00000400) 512 KB P38: rct (00061800, 00000400) 512 KB P39: encrypt (00061C00, 00000400) 512 KB P40: eksst (00062000, 00000400) 512 KB P41: apdp (00062400, 00000400) 512 KB P42: msadp (00062800, 00000400) 512 KB P43: dpo (00062C00, 00000400) 512 KB P44: DDR (00063000, 00000400) 512 KB P45: spare5 (00063400, 00000C00) 1536 KB P46: boot (00064000, 00010000) 32 MB P47: laf (00074000, 00010000) 32 MB P48: lafbak (00084000, 00010000) 32 MB P49: recovery (00094000, 00010000) 32 MB P50: recoverybak (000A4000, 00010000) 32 MB P51: factory (000B4000, 0001C000) 56 MB P52: raw_resources (000D0000, 00002000) 4 MB P53: raw_resourcesbak (000D2000, 00002000) 4 MB P54: persist (000D4000, 00010000) 32 MB P55: mpt (000E4000, 00004000) 8 MB P56: carrier (000E8000, 00014000) 40 MB P57: system (000FC000, 00740000) 3712 MB P58: cache (0083C000, 00268000) 1232 MB P59: userdata (00AA4000, 0127AFDE) 9.24 GB P60: grow (01D1EFDE, 00000001) 512 b Opening C:/Users/Chuchi/Desktop/LS777ZVE_08.tot file... Signature OK. Signature 2 OK. Open file "C:/Users/Chuchi/Desktop/LS777ZVE_08.tot". Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition aboot... Done. Writing partition abootbak... Done. Writing partition tz... Done. Writing partition tzbak... Done. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition rpm... Done. Writing partition rpmbak... Done. Writing partition devcfg... Done. Writing partition devcfgbak... Done. Writing partition cmnlib... Done. Writing partition cmnlibbak... Done. Writing partition cmnlib64... Done. Writing partition cmnlib64bak... Done. Writing partition keymaster... Done. Writing partition keymasterbak... Done. Writing partition mcfg... Done. Writing partition dsp... Done. Writing partition sec... Done. Writing partition apdp... Done. Writing partition msadp... Done. Writing partition boot... Done. Writing partition laf... Done. Writing partition lafbak... Done. Writing partition recovery... Done. Writing partition recoverybak... Done. Writing partition factory... Done. Writing partition raw_resources... Done. Writing partition raw_resourcesbak... Done. Writing partition persist... Done. Writing partition system... Done. Writing is finished. SW: 1.7.6; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : K:/LG_LS777_EMMC.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A432A835A7A4D3 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.4 Product serial number : (hex) 32A835A7 Manufacturing date : 10/2017 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 7602176 Device Manufacturer :lge Device Platform :msm8937 Build ID :NRD90U Display Build ID :NRD90U Release ID :7.0 Device Model :LG-LS777 Device Name :sf340_spr_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :sf340_spr_us-user 7.0 NRD90U 181981140cdc9 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG4a2_07_04_2019_15_20_29.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: tzbak (00033000, 00001000) 2048 KB P06: sbl1 (00034000, 00000800) 1024 KB P07: sbl1bak (00034800, 00000800) 1024 KB P08: rpm (00035000, 00000400) 512 KB P09: rpmbak (00035400, 00000400) 512 KB P10: devcfg (00035800, 00000400) 512 KB P11: devcfgbak (00035C00, 00000400) 512 KB P12: cmnlib (00036000, 00000400) 512 KB P13: cmnlibbak (00036400, 00000400) 512 KB P14: cmnlib64 (00036800, 00000400) 512 KB P15: cmnlib64bak (00036C00, 00000400) 512 KB P16: keymaster (00037000, 00000400) 512 KB P17: keymasterbak (00037400, 00000400) 512 KB P18: spare1 (00037800, 00000400) 512 KB P19: spare2 (00037C00, 00000400) 512 KB P20: persistent (00038000, 00000400) 512 KB P21: devinfo (00038400, 00000800) 1024 KB P22: spare3 (00038C00, 00003400) 6.5 MB P23: modemst1 (0003C000, 00000C00) 1536 KB P24: modemst2 (0003CC00, 00000C00) 1536 KB P25: mcfg (0003D800, 00002000) 4 MB P26: fsc (0003F800, 00000400) 512 KB P27: ssd (0003FC00, 00000400) 512 KB P28: fsg (00040000, 00000C00) 1536 KB P29: spare4 (00040C00, 00003400) 6.5 MB P30: dsp (00044000, 00008000) 16 MB P31: ftm (0004C000, 00004000) 8 MB P32: misc (00050000, 00004000) 8 MB P33: drm (00054000, 00004000) 8 MB P34: sns (00058000, 00004000) 8 MB P35: fota (0005C000, 00005000) 10 MB P36: sec (00061000, 00000400) 512 KB P37: keystore (00061400, 00000400) 512 KB P38: rct (00061800, 00000400) 512 KB P39: encrypt (00061C00, 00000400) 512 KB P40: eksst (00062000, 00000400) 512 KB P41: apdp (00062400, 00000400) 512 KB P42: msadp (00062800, 00000400) 512 KB P43: dpo (00062C00, 00000400) 512 KB P44: DDR (00063000, 00000400) 512 KB P45: spare5 (00063400, 00000C00) 1536 KB P46: boot (00064000, 00010000) 32 MB P47: laf (00074000, 00010000) 32 MB P48: lafbak (00084000, 00010000) 32 MB P49: recovery (00094000, 00010000) 32 MB P50: recoverybak (000A4000, 00010000) 32 MB P51: factory (000B4000, 0001C000) 56 MB P52: raw_resources (000D0000, 00002000) 4 MB P53: raw_resourcesbak (000D2000, 00002000) 4 MB P54: persist (000D4000, 00010000) 32 MB P55: mpt (000E4000, 00004000) 8 MB P56: carrier (000E8000, 00014000) 40 MB P57: system (000FC000, 00740000) 3712 MB P58: cache (0083C000, 00268000) 1232 MB P59: userdata (00AA4000, 012B7FDE) 9.359 GB P60: grow (01D5BFDE, 00000001) 512 b |
