10-24-2012, 15:00 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 381171 Status: Offline Thanks Meter: 52 | i9001 Partition Table damaged flash file write very slow in medusa jtag loading of file is 3% per hour set jtag speed to 12mhz and than same any solution to improve to jtag speed |
10-25-2012, 09:14 | #3 (permalink) |
Member: 381171 Status: Offline Thanks Meter: 52 | first repair with easy repair mode , all done perfectly but phone not on (dead) condition than again repeat the same procedure show partition table damage error, try to flash with full flash file downloaded from medusa server , not success and flashing very slow |
10-26-2012, 11:12 | #5 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Have You tried to put the phone into Emergency Mode after of repairing in EasyRepair Mode? Quote:
10-30-2012, 13:51 | #6 (permalink) |
Member: 381171 Status: Offline Thanks Meter: 52 | Selected device model: Samsung GT-I9001 Connecting. Please wait... Resetting target. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 126 ns, average speed 7936 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 27B360E1, IR Length = 5. MI: Halting target, attempt 1. MI: Qualcomm ARM1136JF-S core detected. MI: Qualcomm CPUID = 2057A0E1. JTAG speed : Auto (RTCK). VREF level : 1.81 V CPU : Qualcomm MSM8255T Core ID : 2057A0E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000191. MI: Detailed server caps: FLASH, WDOG, A64, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xE0150001. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000191 Storage Device: Samsung eMMC M8G2FA Device ID : 00150001 Block size : 512 bytes Blocks : 15106048 Storage size : 7.2 Gb MBR: partition, type 0x00000045 (0x30393443, 0x46343537) MBR: partition, type 0x00000020 (0x000101D2, 0x00930000) MBR: partition, type 0x00000073 (0x7478652E, 0x00000034) MBR: partition, type 0x00000038 (0x45334435, 0x44393839) WARNING[002]: Partition Table damaged. Use Full flash write. Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9001_Re pair.mf" file... Writting PARTITION section. Please wait... Done Writting BOOT section. Please wait... Done Disconnected AFTER THE ABOVE PROCEDURE PHONE IN DEAD CONDITION , SO TRY TO FULL FLASH (FILE DOWNLOADED FROM MEDUSA SUPPORT) IT'S FLASH VERY SLOW |
