09-04-2012, 19:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2010 Location: romania
Member: 1390461 Status: Offline Thanks Meter: 80 | ERROR[002]: Failed to load Medusa Device Server to target RAM. ERROR[002]: Failed to load Medusa Device Server to target RAM.. ..used full battery,usb cable inserted but still this error.any suggestion? |
09-05-2012, 07:33 | #2 (permalink) |
Member: 1390461 Status: Offline Thanks Meter: 80 | Welcome to Medusa Box Software version 1.5.1 Selected device model: Samsung GT-I9100 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.81 V CPU : Samsung S5PC210 Core ID : 4BA00477 ERROR[002]: Failed to load Medusa Device Server to target RAM. this is full log |
09-05-2012, 07:54 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Please try to solder Jtag wires as more shorter, try to connect your device on different (lower) speeds, also please use at the same time both - fully charged battery (or external power supply) and USB cable. |
09-06-2012, 13:51 | #6 (permalink) |
Member: 1390461 Status: Offline Thanks Meter: 80 | Welcome to Medusa Box Software version 1.5.4 Selected device model: Samsung GT-I9100 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 ERROR[002]: Failed to load Medusa Device Server to target RAM. Selected device model: Samsung GT-I9100 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.83 V CPU : Samsung S5PC210 Core ID : 4BA00477 ERROR[002]: Failed to load Medusa Device Server to target RAM. Selected device model: Samsung GT-I9100 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.82 V CPU : Samsung S5PC210 Core ID : 4BA00477 ERROR[002]: Failed to load Medusa Device Server to target RAM. Selected device model: Samsung GT-I9100 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.82 V CPU : Samsung S5PC210 Core ID : 4BA00477 ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.82 V CPU : Samsung S5PC210 Core ID : 4BA00477 ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.82 V CPU : Samsung S5PC210 Core ID : 4BA00477 ERROR[002]: Failed to load Medusa Device Server to target RAM. hello???any solution????????????? |
09-06-2012, 14:16 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Can't say You exactly where is the problem... Most likely this is HW problem. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
09-14-2012, 11:10 | #8 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 318611 Status: Offline Sonork: 100.1613803 Thanks Meter: 10 | I'm same problem. This is my first log Log started at 9/14/2012 2:42:55 PM ... Welcome to Medusa Box Software version 1.5.2 Connecting to server Retrieving files list Downloading file "SAMSUNG_GTI9100_Repair.mf" Selected device model: Samsung GT-I9100 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. MI: Medusa JTAG init failed. ERROR[035]: Target device has been powered off during connect. Please connect the target device and power it on... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 8000 KHz. VREF level : 2.76 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000191. MI: Detailed server caps: FLASH, WDOG, A64, IOCTL MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0xE0150001. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000191 Storage Device: Samsung eMMC VIS00M Device ID : 00150001 Block size : 512 bytes Blocks : 30777344 Storage size : 14.7 Gb Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9100_Re pair.mf" file... Writting BOOT section. Please wait... Done Writting PREBOOT section. Please wait... MI: Server status 0xFFFFFFFF (not STAT_IDLE). And now: Log started at 9/14/2012 4:51:09 PM ... Welcome to Medusa Box Software version 1.5.5 Selected device model: Samsung GT-I9100 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Selected device model: Samsung GT-I9100 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.79 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Selected device model: Samsung GT-I9100 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Selected device model: Samsung GT-I9100 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 2. ERROR[000]: Unable to halt core. ERROR[035]: Target device has been powered off during connect. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Selected device model: Samsung GT-I9100 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Selected device model: Samsung GT-I9100 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Selected device model: Samsung GT-I9100 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Selected device model: Samsung GT-I9100 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.78 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Failed to load. My phone is new, i only reflash to change language but disconnect cable when repartition action. Then connect to medusa with first time log. |
09-21-2012, 06:59 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | We can't say You exactly where is the problem. There is no any problems with repairing 2 our own GT-I9100. We have ordered another one GT-I9100 for researching. We will say You the result as soon as we will receive it. |
07-22-2013, 06:59 | #11 (permalink) | ||
Freak Poster Join Date: Sep 2009 Location: Sri Lanka
Member: 1109931 Status: Offline Sonork: Bongo Thanks Meter: 44 | Samsung M110s Boot Repair Error... Quote:
Whats this problem Quote:
07-22-2013, 07:11 | #13 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
