Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 09-06-2019, 01:59   #1 (permalink)
Member: 861495
Thanks Meter: 52
skyhynix H9TQ17ABJTCCUR-KUM [Answered]
H9TQ17ABJTCCUR-KUM what emmc should i choose to work with one on medusa i dont see this emmc chip
Old 09-06-2019, 19:08   #2 (permalink)
Member: 861495
Thanks Meter: 52
any ideas how i can find out what this chip is compatible with
Old 09-06-2019, 19:23   #3 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
tell here in which dvice it habeen used model nomber for beter help
Old 09-08-2019, 01:28   #4 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 900
on which phone u wanna change?
Old 09-08-2019, 11:13   #5 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
Skhynix_h9tp32a46dcc
@suport
i need the following emmc ic chip tp point & its firmware.this chip demage,hence it is using in lg d175 f.
Old 09-08-2019, 11:30   #6 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
@support if you dont mind i am old user of medusa box,at the moment i have no emmc socket for medusa,only other box have,so i want to post other box log.
Connection status: EHCI:HUB:HUB:HUB:USB 2.0 High-Speed
Interface: UFI High-Speed
Serial number: 0011-8839-7904
 Boot version: 1.04, FW version: 1.13 (Aug 19 2019 23:46:09)
Insertion test... Done.
Init bus...
VCC: 3.3 V, VCCQ: 3.0 V
Bus: 1 bit (SDR 52MHz)
Access mode: sector mode
Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V)
 Card/BGA: Card (removable) - MMC
 Manufacturer ID: 0x65 (Unknown)
 Product name: MMOR (0x4d204d4f5212), rev: 0x81, serial number: 0x00000240
 Manufacturing date: ? 2014
CID: 65646F4D 204D4F52 12810000 02400152
Bad CID detected, eMMC might be damaged !!!
CSD: D07FFF32 0F59007F F6DB8000 1E40001C
Bad CSD detected, eMMC might be damaged !!!
EXT_CSD revision: 1.5 (MMC v4.41)
Partition info:
 Boot1: 2048 KiB
 Boot2: 2048 KiB
 RPMB: 128 KiB
 User area: 128 MiB(134,217,728 bytes)
Partition configuration: 0x78
 Boot acknowledge is sent during the boot operation
 User area is enabled for boot
Partitioning support: 0x03
 Device support partitioning feature
 Device can have enhanced technological features
 Device partitioning possible
Boot configuration protection: 0x00
Boot bus conditions: 0x00
Boot area write protection: 0x00
 Power-on write protection: possible
 Permanent write protection: possible
 Lock status: not locked
Old 09-09-2019, 07:14   #7 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
@support please take a look here.....
Old 09-09-2019, 07:54   #8 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,397
Hello.
Unfortunately, this eMMC model isn't supported
Old 09-09-2019, 09:15   #9 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
Originally Posted by Medusa Box View Post
Hello.
can i use another chip instead of this chip,it is 4gb using in lg d175f.
Page generated in 0.18523 seconds with 9 queries
