04-16-2019, 07:37 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Cambodia
Member: 1218675 Status: Offline Thanks Meter: 24 | Medusa Pro connected but can not write file [Answered] It can connect phone very good. But when i flash eMMC file it got error. Code: See here my logs! Partition table has been found on device. Warning: openned file size is bigger than eMMC size. Partition table is found from file C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition recovery from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... ERROR[007]: Command fail. #red At sector 744672 Please help me to solve my box problem my dear Team! |
04-16-2019, 10:00 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. First of all please post here full Software log, we will check it. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
04-16-2019, 11:08 | #3 (permalink) | |
Member: 1218675 Status: Offline Thanks Meter: 24 | Quote:
After i try once again with my problem box and also save log too. Then i will post them here. But it take time too long for once processing. | |
04-16-2019, 12:35 | #4 (permalink) |
Member: 1218675 Status: Offline Thanks Meter: 24 | This is the log of success box: (My friend's box) Welcome to Medusa Pro Software version 1.7.6. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203AA6EF2CD953D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) AA6EF2CD Manufacturing date : 09/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE63MB_16_04_2019_16_39_04.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: reserve_exp1 (0003F828, 00001000) 2048 KB P09: reserve_exp2 (00040828, 00001000) 2048 KB P10: fsc (00041828, 00000002) 1024 b P11: ssd (00041830, 00000010) 8 KB P12: sbl1 (00041840, 00000400) 512 KB P13: rpm (00041C40, 00000400) 512 KB P14: tz (00042040, 00001000) 2048 KB P15: devcfg (00043040, 00000200) 256 KB P16: sbl1bak (00043240, 00000400) 512 KB P17: rpmbak (00043640, 00000400) 512 KB P18: tzbak (00043A40, 00001000) 2048 KB P19: devcfgbak (00044A40, 00000200) 256 KB P20: dsp (00044C40, 00008000) 16 MB P21: DDR (00050000, 00000040) 32 KB P22: fsg (00050040, 00000C00) 1536 KB P23: sec (00050C40, 00000020) 16 KB P24: aboot (00050C60, 00000800) 1024 KB P25: abootbak (00051460, 00000800) 1024 KB P26: modem (00051C60, 00040000) 128 MB P27: dtbo (00091C60, 00004000) 8 MB P28: vbmeta (00095C60, 00000080) 64 KB P29: boot (00095CE0, 00020000) 64 MB P30: recovery (000B5CE0, 00020000) 64 MB P31: devinfo (000D5CE0, 00000800) 1024 KB P32: splash (000D8000, 00005800) 11 MB P33: LOGO (000DD800, 00010000) 32 MB P34: DRIVER (000ED800, 00010000) 32 MB P35: cache (000FD800, 00080000) 256 MB P36: misc (0017D800, 00000800) 1024 KB P37: keystore (0017E000, 00000400) 512 KB P38: config (0017E400, 00000040) 32 KB P39: oem (0017E440, 00000800) 1024 KB P40: limits (00180000, 00000040) 32 KB P41: mota (00184000, 00000400) 512 KB P42: dip (00184400, 00000800) 1024 KB P43: mdtp (00184C00, 00010000) 32 MB P44: syscfg (00194C00, 00000400) 512 KB P45: mcfg (00195000, 00002000) 4 MB P46: lksecapp (00198000, 00000100) 128 KB P47: cmnlib (00198100, 00000800) 1024 KB P48: cmnlib64 (00198900, 00000800) 1024 KB P49: keymaster (00199100, 00000800) 1024 KB P50: lksecappbak (00199900, 00000100) 128 KB P51: cmnlibbak (00199A00, 00000800) 1024 KB P52: cmnlib64bak (0019A200, 00000800) 1024 KB P53: keymasterbak (0019AA00, 00000800) 1024 KB P54: apdp (0019C000, 00000200) 256 KB P55: msadp (0019C200, 00000200) 256 KB P56: dpo (0019C400, 00000010) 8 KB P57: logdump (0019C410, 00020000) 64 MB P58: vm-kystore (001BC410, 00000800) 1024 KB P59: vm-data (001BCC10, 00005000) 10 MB P60: hyp (001C4000, 00004000) 8 MB P61: vm-system (001C8000, 00020000) 64 MB P62: vm-linux (001E8000, 00010000) 32 MB P63: system (001F8000, 006B4800) 3433 MB P64: vendor (008AC800, 0020FB00) 1055 MB P65: userdata (00AC0000, 0125EFDE) 9.186 GB Partition table has been found on device. Warning: openned file size is bigger than eMMC size. Partition table is found from file C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition GPT from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition persist from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition opporeserve1 from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition opporeserve2 from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition reserve_exp1 from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition reserve_exp2 from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition fsc from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition ssd from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition sbl1 from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition rpm from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition tz from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition devcfg from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition sbl1bak from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition rpmbak from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition tzbak from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition devcfgbak from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition dsp from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition DDR from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition fsg from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition sec from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition aboot from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition abootbak from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition modem from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition dtbo from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition vbmeta from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition boot from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition recovery from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition devinfo from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition splash from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition LOGO from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition DRIVER from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition cache from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition misc from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition keystore from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition config from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition oem from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition limits from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition mota from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition dip from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition mdtp from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition syscfg from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition mcfg from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition lksecapp from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition cmnlib from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition cmnlib64 from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition keymaster from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition lksecappbak from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition cmnlibbak from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition cmnlib64bak from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition keymasterbak from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition apdp from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition msadp from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition dpo from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition logdump from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition vm-kystore from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition vm-data from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition hyp from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition vm-system from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition vm-linux from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition system from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition vendor from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition userdata from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing is finished. SW: 1.7.6; FW: 1.24. Reconnect the device to see changesDisconnected. Disconnected. |
04-16-2019, 12:39 | #5 (permalink) |
Member: 1218675 Status: Offline Thanks Meter: 24 | This one is the log of my box: Welcome to Medusa Pro Software version 1.7.6. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203AA6EF2CD953D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) AA6EF2CD Manufacturing date : 09/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE63MB_16_04_2019_18_36_17.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: reserve_exp1 (0003F828, 00001000) 2048 KB P09: reserve_exp2 (00040828, 00001000) 2048 KB P10: fsc (00041828, 00000002) 1024 b P11: ssd (00041830, 00000010) 8 KB P12: sbl1 (00041840, 00000400) 512 KB P13: rpm (00041C40, 00000400) 512 KB P14: tz (00042040, 00001000) 2048 KB P15: devcfg (00043040, 00000200) 256 KB P16: sbl1bak (00043240, 00000400) 512 KB P17: rpmbak (00043640, 00000400) 512 KB P18: tzbak (00043A40, 00001000) 2048 KB P19: devcfgbak (00044A40, 00000200) 256 KB P20: dsp (00044C40, 00008000) 16 MB P21: DDR (00050000, 00000040) 32 KB P22: fsg (00050040, 00000C00) 1536 KB P23: sec (00050C40, 00000020) 16 KB P24: aboot (00050C60, 00000800) 1024 KB P25: abootbak (00051460, 00000800) 1024 KB P26: modem (00051C60, 00040000) 128 MB P27: dtbo (00091C60, 00004000) 8 MB P28: vbmeta (00095C60, 00000080) 64 KB P29: boot (00095CE0, 00020000) 64 MB P30: recovery (000B5CE0, 00020000) 64 MB P31: devinfo (000D5CE0, 00000800) 1024 KB P32: splash (000D8000, 00005800) 11 MB P33: LOGO (000DD800, 00010000) 32 MB P34: DRIVER (000ED800, 00010000) 32 MB P35: cache (000FD800, 00080000) 256 MB P36: misc (0017D800, 00000800) 1024 KB P37: keystore (0017E000, 00000400) 512 KB P38: config (0017E400, 00000040) 32 KB P39: oem (0017E440, 00000800) 1024 KB P40: limits (00180000, 00000040) 32 KB P41: mota (00184000, 00000400) 512 KB P42: dip (00184400, 00000800) 1024 KB P43: mdtp (00184C00, 00010000) 32 MB P44: syscfg (00194C00, 00000400) 512 KB P45: mcfg (00195000, 00002000) 4 MB P46: lksecapp (00198000, 00000100) 128 KB P47: cmnlib (00198100, 00000800) 1024 KB P48: cmnlib64 (00198900, 00000800) 1024 KB P49: keymaster (00199100, 00000800) 1024 KB P50: lksecappbak (00199900, 00000100) 128 KB P51: cmnlibbak (00199A00, 00000800) 1024 KB P52: cmnlib64bak (0019A200, 00000800) 1024 KB P53: keymasterbak (0019AA00, 00000800) 1024 KB P54: apdp (0019C000, 00000200) 256 KB P55: msadp (0019C200, 00000200) 256 KB P56: dpo (0019C400, 00000010) 8 KB P57: logdump (0019C410, 00020000) 64 MB P58: vm-kystore (001BC410, 00000800) 1024 KB P59: vm-data (001BCC10, 00005000) 10 MB P60: hyp (001C4000, 00004000) 8 MB P61: vm-system (001C8000, 00020000) 64 MB P62: vm-linux (001E8000, 00010000) 32 MB P63: system (001F8000, 006B4800) 3433 MB P64: vendor (008AC800, 0020FB00) 1055 MB P65: userdata (00AC0000, 0125EFDE) 9.186 GB Partition table has been found on device. Warning: openned file size is bigger than eMMC size. Partition table is found from file C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition GPT from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... Done. Writing partition persist from C:/Program Files/Medusa Pro Software/OPPO A3S CPH1803EX_A09 Full.bin file... ERROR[007]: Command fail. At sector 48200 Cancelling operation. Please wait...Attempting to read... Disconnected. Reconnect the device to see changesDisconnected. |
04-16-2019, 14:17 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | It looks like You have bad contacts via USB connection, please clean all contacts on USB port of your box (backside of the box) besides try to use another USB cable for connection |
04-17-2019, 04:16 | #7 (permalink) |
Member: 1218675 Status: Offline Thanks Meter: 24 | Yes sir! but my box like new. and i also try to clean its USB and change USB Cable but problem not solve. Other box (my friend's box) older than mine and i use the same USB cable it 's working fine. |
04-17-2019, 10:07 | #8 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | That error means that there is a problem with connections. If your box is new and if You still have warranty You can try to exchange to another one. |
