12-13-2018, 03:48 | #1 (permalink) |
Junior Member Join Date: Dec 2018
Member: 2882817 Status: Offline Thanks Meter: 0 | Medusa Pro crashes after connection to eMMC [Answered] Very rarely it will connect. When connected I was able to use content extractor to download files and partition manager to download whole partitions. Thus I believe my connection is good (able to download 1gb+ without problems). I have tried it on 2 computers, one desktop, one laptop. Tried multiple USB cables. Even tried with a powered USB hub to give it extra power. Nothing seems to be helping, just random luck on connection. It does seem to connect slightly better on the laptop. I am working directly on a Tegra 3 SOC using the test points for the eMMC. Any suggestions would be greatly appreciated. Code: Welcome to Medusa Pro Software version 1.6.9. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Hynix eMMC H8G2d Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384732640403FD90DCFBA2F3 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G2d Product revision : 0.3 Product serial number : (hex) FD90DCFB Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: EXT2FS (00001000, 00200000) 1024 MB P01: EXT2FS (00201000, 00200000) 1024 MB P02: EXT2FS (00401000, 00040000) 128 MB P03: EXT2FS (00441000, 00A4F000) 5.154 GB Last edited by Medusa Box; 12-13-2018 at 05:48. |
12-13-2018, 05:47 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
