04-24-2018, 22:23 | #1 (permalink) |
Freak Poster Join Date: May 2014 Location: MUMBAI INDIA
Member: 2194159 Status: Offline Thanks Meter: 88 | Medusa Pro doesn't detect devices via eMMC [Answered] Medusa pro box not detect any phone or direct emmc with jumper Box connecting in pc fine Software interface work perfectly File download and repair via usb working Only emmc not detect How to solve my problem Last edited by Medusa Box; 04-25-2018 at 05:05. |
04-25-2018, 05:04 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. At first please post here full Software log with the procedure of device connecting via eMMC, we will check. Most likely, the problem is with incorrect soldering of some necessary wires. Please carefully check soldering of each wire and try to connect the device again. Here are a few main possible reasons why the device not connected: 1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible (3-5 CM length). 6. For GND connection use more thicker wire. Try to connect the device with higher Voltage level (try to set 2.0V, 2.2V) and with different Bus speed values. |
04-27-2018, 20:45 | #3 (permalink) |
Member: 2194159 Status: Offline Thanks Meter: 88 | I soldering wire is 100% correct connected I checking in microscope I flow all step but not connecting no use external Emmc or JTAG both not working I try mor than 10 set emmc or JTAG both not working |
04-27-2018, 21:11 | #4 (permalink) |
Freak Poster Join Date: Oct 2017
Member: 2773088 Status: Offline Thanks Meter: 24 | i had the exact same problem a couple of weeks ago it turned out the problem was from my laptop formatted it and reinstalled everything now its working perfectly |
The Following User Says Thank You to pomgrapes For This Useful Post: |
