07-10-2017, 05:16 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Huawei Rio_L03 can add to repair Interface : eMMC Voltage : 3.3V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC R311MB Core : Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 150100523331314D42068ECFC28BC259 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R311MB Product revision : 0.6 Product serial number : (hex) 8ECFC28B Manufacturing date : 12/1999 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_09_07_2017_23_15_57.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.4; FW: 1.16. |
07-10-2017, 06:41 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. As You can see on your Software log, You have not connected eMMC chip correctly or chip is damaged - it is not correct, that eMMC capacity (size) is only 1 GB (1024.00 MB), also Erase block, Boot1, Boot2 and RPMB sizes can't be zero: Quote:
When eMMC will be connected correctly, try to do "Factory Repair" ("Factory Repair" tab in Software) using original firmware (Press «Repair devices based on Qualcomm CPU’s using XML files (*.xml)» button, elect «rawprogram0.xml» and «patch0.xml» files and write them). | ||
The Following User Says Thank You to Medusa Box For This Useful Post: |
07-10-2017, 06:55 | #3 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | try to connect again but not have xml for repair this model only update but cant write by medusa or you have xml file for repair this model wait for you help thanks |
07-10-2017, 07:13 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Unfortunately, we have no firmware with "*.xml" or SRF for this device at the moment. We will try to find this phone and add support for it in one on the future Software updates. |
07-11-2017, 06:22 | #5 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | team medusa find this soft RIO-L02_M105_Board Software_general_Android 5.1_EMUI 3.1_05021TKA is xml but medusa not enable write xml wait for you help model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 4 Bus speed : Auto Connecting... Device : Samsung eMMC R311MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB --------------------------------------------------------------- CID Info CID : 150100523331314D42068ECFC28BC259 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R311MB Product revision : 0.6 Product serial number : (hex) 8ECFC28B Manufacturing date : 12/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_11_07_2017_00_18_07.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.4; FW: 1.16. |
07-11-2017, 06:44 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Yes, writing "*.xml" firmwares currently supported only via USB connection, not via eMMC. We have prepared test Software version for You. Please try to do "Factory Repair" (write "*.xml" firmware) using this test Software version and post the result. Also please make photo (or scan) of device PCB in high quality, upload it somewhere and post here link, we need it to prepare pinout picture. |
07-11-2017, 07:48 | #7 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC R311MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB --------------------------------------------------------------- CID Info CID : 150100523331314D42068ECFC28BC259 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R311MB Product revision : 0.6 Product serial number : (hex) 8ECFC28B Manufacturing date : 12/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2842624 Number of sectors : 5242880 Device Manufacturer : HUAWEI Device Platform : msm8916 Build ID : HUAWEIRIO-L02 Display Build ID : HL1RIOL02M105 Release ID : 5.1 Device Model : HUAWEI RIO-L02 Device Name : RIO-L02 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : RIO-L02-user 5.0 GRJ90 C00B105 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_11_07_2017_01_46_09.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.0; FW: 1.20. P00: GPT (00000000, 00000022) P01: sbl1 (00000022, 00000400) P02: hyp (00000422, 00000400) P03: sec (00002000, 00000040) P04: DDR (00002040, 00000040) P05: rpm (00004000, 00000400) P06: tz (00004400, 00000400) P07: aboot (00004800, 00002780) P08: pad (00006F80, 00000800) P09: oeminfo (00007780, 00020000) P10: misc (00027780, 00002000) P11: modemst1 (00029780, 00002000) P12: modemst2 (0002B780, 00002000) P13: fsg (0002E000, 00002000) P14: modem (00030000, 00064000) P15: fsc (00094000, 00000002) P16: ssd (00094002, 00000010) P17: log (00094012, 00020000) P18: persist (000B6000, 00020000) P19: boot (000D6000, 00020000) P20: recovery (000F6000, 00020000) P21: erecovery (00116000, 00020000) P22: cache (00136000, 00080000) P23: cust (001B6000, 00100000) P24: system (002B6000, 00500000) P25: config (007B6000, 00000400) P26: userdata (007B8000, 01566FDF) Selected rawprogram XML file: C:/Users/Los Martinez Lozada/Downloads/RIO-L02_M105_Board Software_general_Android 5.1_EMUI 3.1_05021TKA/Software/EXE/factory/factory_verison/HL1RIOL02M105/MSMQCOMV100R001C00B001_Download.xml. Patch xml file open failed. Patch Xml file open failed. Xml file parsing finished. Selected rawprogram XML file: C:/Users/Los Martinez Lozada/Downloads/RIO-L02_M105_Board Software_general_Android 5.1_EMUI 3.1_05021TKA/Software/EXE/factory/factory_verison/HL1RIOL02M105/fastbootimage/MSMQCOMV100R001C00B001_Download.xml. Patch xml file open failed. Patch Xml file open failed. Xml file parsing finished. maybe filex xml not compatible for write by this method |
07-11-2017, 07:52 | #8 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Yes, You should use firmwares with "rawprogram.xml". Please post here link to your firmware with "*.xml" file, we will research it. Last edited by Octopus box; 07-11-2017 at 08:05. |
07-21-2017, 03:13 | #9 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | hi team, can repair my rio-l03 my emmc is Samsung eMMC R311MB by you new update? see in support but not is same emmc this can repiar my phone |
07-23-2017, 23:15 | #11 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | all write ok but phone not poweron always qualcom mode Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Huawei Model : G8_RIO-L03 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_G8_RIO-L03_EMMC.srf Voltage : 3.3V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC R311MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB --------------------------------------------------------------- CID Info CID : 150100523331314D42068ECFC28BC259 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R311MB Product revision : 0.6 Product serial number : (hex) 8ECFC28B Manufacturing date : 12/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_20_07_2017_21_26_32.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.0; FW: 1.20. P00: GPT (00000000, 00000022) P01: sbl1 (00000022, 00000400) P02: hyp (00000422, 00000400) P03: sec (00002000, 00000040) P04: DDR (00002040, 00000040) P05: rpm (00004000, 00000400) P06: tz (00004400, 00000400) P07: aboot (00004800, 00002780) P08: pad (00006F80, 00000800) P09: oeminfo (00007780, 00020000) P10: misc (00027780, 00002000) P11: modemst1 (00029780, 00002000) P12: modemst2 (0002B780, 00002000) P13: fsg (0002E000, 00002000) P14: modem (00030000, 00064000) P15: fsc (00094000, 00000002) P16: ssd (00094002, 00000010) P17: log (00094012, 00020000) P18: persist (000B6000, 00020000) P19: boot (000D6000, 00020000) P20: recovery (000F6000, 00020000) P21: erecovery (00116000, 00020000) P22: cache (00136000, 00080000) P23: cust (001B6000, 00100000) P24: system (002B6000, 00500000) P25: config (007B6000, 00000400) P26: userdata (007B8000, 01566FDF) Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_G8_RIO-L03_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing hyp partition... Done. Writing sec partition... Done. Writing DDR partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing aboot partition... Done. Writing pad partition... Done. Writing oeminfo partition... Done. Writing misc partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing fsg partition... Done. Writing modem partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing log partition... Done. Writing persist partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing erecovery partition... Done. Writing config partition... Done. |
07-24-2017, 06:10 | #12 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Most likely boot loaders in SRF are not compatible with your phone revision (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to find firmware with "rawprogram.xml" and make "Factory Repair" using it. |
