11-04-2017, 10:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: india
Member: 2097870 Status: Offline Sonork: FINDING.... Thanks Meter: 65 | Meudsa Pro data recover question [Answered] Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Whole proccess time: . Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Whole proccess time: . Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC Page size : 512 B Block size : 512 B Block count : 142994052 Size : 68.18 GB --------------------------------------------------------------- CID Info CID : 5A5A00000000000000000000000101ED Manufacturer ID : 0X5A Device/BGA : Device (removable) OEM/Application ID : 0X00 Product name : Product revision : 0.0 Product serial number : (hex) 1 Manufacturing date : 00/2014 --------------------------------------------------------------- CSD Info CSD : 3C3C0000000000000000000000FFFF31 CSD structure : CSD version No. 1.0 SPEC version : Allocated by MMCA Data read access time1: 0.03 ms TRAN speed : 0 MHz READ block length : 1 Bytes WP group enable : NO PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : YES --------------------------------------------------------------- EXTCSD Info Erase block size : 9216 Kbytes Boot1 size : 26624 Kbytes Boot2 size : 26624 Kbytes RPMB size : 7680 Kbytes Partition config : 10110010 Boot partition enable : (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00011100 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3603406848 Kbytes Partitions attribute : 0xE2 Part setting completed: 0xCB GP partition 1 size : 3760 MB GP partition 2 size : 3736 MB GP partition 3 size : 1784 MB GP partition 4 size : 1160 MB Enhanced area size : (0x78800000) 1928 MB Enhanced area start : (0x3737C600) 883.5 MB Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/_04_11_2017_01_51_04.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.7; FW: 1.22. Whole proccess time: . Parsing device... Image size in bytes: 198510592 Warning: Unknown file system type. Details: Sector offset: 0 Parse finished. Whole proccess time: 3 seconds : 0 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Parsing device... Image size in bytes: 198510592 Loading an image file ... Image size in bytes: 198510592 Warning: Unknown file system type. Details: Sector offset: 0 Parse finished. Whole proccess time: 16 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Parsing device... Image size in bytes: 198510592 Loading an image file ... Image size in bytes: 198510592 Warning: Unknown file system type. Details: Sector offset: 0 Parse finished. Whole proccess time: 16 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Parsing device... Image size in bytes: 198510592 Loading an image file ... Image size in bytes: 198510592 Warning: Unknown file system type. Details: Sector offset: 0 Parse finished. Whole proccess time: 78 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Parsing device... Image size in bytes: 198510592 Whole proccess time: 3 seconds : 0 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Parsing device... Image size in bytes: 198510592 Loading an image file ... Image size in bytes: 198510592 Warning: Unknown file system type. Details: Sector offset: 0 Parse finished. Whole proccess time: 15 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Last edited by Octopus box; 11-04-2017 at 10:26. |
11-04-2017, 10:26 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
