10-23-2018, 08:23 | #1 (permalink) |
Freak Poster Join Date: May 2016 Location: India,Odisha Age: 27
Member: 2573604 Status: Offline Thanks Meter: 30 | Micromax Q4251 repair question [Answered] Last edited by Medusa Box; 10-23-2018 at 10:11. |
10-23-2018, 08:56 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello. Repairing of this device is supported via USB and proper SFR (Smart Repair File) is present on the Support Area. At first try to connect this device via USB and do "Smart Repair". Post here the result. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
10-23-2018, 09:17 | #3 (permalink) |
Member: 2573604 Status: Offline Thanks Meter: 30 | Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q823MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100513832334D420006BBFE507399 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q823MB Product revision : 0.0 Product serial number : (hex) 6BBFE50 Manufacturing date : 07/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF92404009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 461920 Number of sectors : 5632000 Device Manufacturer :Micromax Device Platform :msm8909 Build ID :MMB29M Display Build ID :MMX_Q4251_IND_SW_V2.7_HW_V0.2_03122016 Release ID :6.0.1 Device Model :Micromax Q4251 Device Name :Q4251 Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :msm8909-user 6.0.1 MMB29M eng.spwork.20161203.153543 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q823MB_23_10_2018_13_46_53.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.8; FW: 1.24. P00: GPT (00000000, 00020000) 64 MB P01: modem (00020000, 00020000) 64 MB P02: sbl1 (00040000, 00000400) 512 KB P03: sbl1bak (00040400, 00000400) 512 KB P04: aboot (00040800, 00000800) 1024 KB P05: abootbak (00041000, 00000800) 1024 KB P06: rpm (00041800, 00000400) 512 KB P07: rpmbak (00041C00, 00000400) 512 KB P08: tz (00042000, 00000600) 768 KB P09: tzbak (00042600, 00000600) 768 KB P10: pad (00042C00, 00000800) 1024 KB P11: modemst1 (00043400, 00000C00) 1536 KB P12: modemst2 (00044000, 00000C00) 1536 KB P13: misc (00044C00, 00000800) 1024 KB P14: fsc (00045400, 00000002) 1024 b P15: ssd (00045402, 00000010) 8 KB P16: splash (00045412, 00005000) 10 MB P17: DDR (00060000, 00000040) 32 KB P18: fsg (00060040, 00000C00) 1536 KB P19: sec (00060C40, 00000020) 16 KB P20: boot (00060C60, 00010000) 32 MB P21: system (00070C60, 0055F000) 2750 MB P22: persist (005CFC60, 00010000) 32 MB P23: cache (005DFC60, 00080000) 256 MB P24: recovery (0065FC60, 00010000) 32 MB P25: devinfo (0066FC60, 00000800) 1024 KB P26: keystore (00680000, 00000400) 512 KB P27: oem (00680400, 00020000) 64 MB P28: config (006A0400, 00000400) 512 KB P29: userdata (006A0800, 00000000) 0 b |
