12-20-2017, 18:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Moto X XT1058 replace eMMC and repair successfully done Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 016G92 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 11010030313647393201D94E8A4F508F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 016G92 Product revision : 0.1 Product serial number : (hex) D94E8A4F Manufacturing date : 05/2013 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFEF92400045 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7700480 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 2457600 Number of sectors : 3145728 Device Manufacturer : motorola Device Platform : msm8960 Build ID : LPAS23.12-21.7-1 Display Build ID : LPAS23.12-21.7-1 Release ID : 5.1 Device Model : XT1058 Device Name : ghost_att Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : ghost_att-user 5.1 LPAS23.12-21.7-1 1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software138/EXT_CSD Backups/016G92_20_12_2017_20_27_53.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00032000) 100 MB P02: sbl1 (00032100, 00000BB8) 1500 KB P03: sbl2 (00032CB8, 00000BB8) 1500 KB P04: sbl3 (00033870, 00000404) 514 KB P05: aboot (00034870, 00000400) 512 KB P06: rpm (00035428, 0000011C) 142 KB P07: tz (00035810, 000001A4) 210 KB P08: utags (00035BF8, 00000400) 512 KB P09: logs (00035FF8, 00000800) 1024 KB P10: padA (000367F8, 00001808) 3076 KB P11: sbl2Backup (00038000, 00000BB8) 1500 KB P12: sbl3Backup (00038BB8, 00001000) 2048 KB P13: abootBackup (00039BB8, 00000BB8) 1500 KB P14: rpmBackup (0003A770, 000003E8) 500 KB P15: tzBackup (0003AB58, 000003E8) 500 KB P16: utagsBackup (0003AF40, 00000400) 512 KB P17: padB (0003B340, 00000CC0) 1632 KB P18: modemst1 (0003C000, 00001800) 3072 KB P19: modemst2 (0003D800, 00001800) 3072 KB P20: mbl (0003F000, 00001000) 2048 KB P21: hob (00040000, 00000500) 640 KB P22: dhob (00040500, 00000010) 8 KB P23: persist (00040600, 00004000) 8 MB P24: ssd (00044600, 00000010) 8 KB P25: fsg (00044610, 00001800) 3072 KB P26: sp (00045E10, 00000800) 1024 KB P27: misc (00046610, 00000400) 512 KB P28: pds (00046A10, 00001800) 3072 KB P29: cid (00048210, 00000100) 128 KB P30: logo (00048310, 00002000) 4 MB P31: clogo (0004A310, 00002000) 4 MB P32: devtree (0004C310, 00000800) 1024 KB P33: boot (0004CC00, 00005000) 10 MB P34: recovery (00051C00, 00005000) 10 MB P35: kpan (00056C00, 00004000) 8 MB P36: cache (0005AC00, 001FCC00) 1018 MB P37: padC (00257800, 00000800) 1024 KB P38: system (00258000, 00300000) 1536 MB P39: customize (00558000, 00036000) 108 MB P40: userdata (0058E000, 017C3F00) 11.88 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software138/Backups/016G92_Gpt_0x0_0x100_20_12_2017_20_27_53.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.0; FW: 1.22. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software138/Backups/016G92_Cid_0x48210_0x100_20_12_2017_20_27_53.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.0; FW: 1.22. Erasing partition GPT... Done. Erasing partition modem... Done. Erasing partition sbl1... Done. Erasing partition sbl2... Done. Erasing partition sbl3... Done. Erasing partition aboot... Done. Erasing partition rpm... Done. Erasing partition tz... Done. Erasing partition utags... Done. Erasing partition logs... Done. Erasing partition padA... Done. Erasing partition sbl2Backup... Done. Erasing partition sbl3Backup... Done. Erasing partition abootBackup... Done. Erasing partition rpmBackup... Done. Erasing partition tzBackup... Done. Erasing partition utagsBackup... Done. Erasing partition padB... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Erasing partition mbl... Done. Erasing partition hob... Done. Erasing partition dhob... Done. Erasing partition persist... Done. Erasing partition ssd... Done. Erasing partition fsg... Done. Erasing partition sp... Done. Erasing partition misc... Done. Erasing partition pds... Done. Erasing partition cid... Done. Erasing partition logo... Done. Erasing partition clogo... Done. Erasing partition devtree... Done. Erasing partition boot... Done. Erasing partition recovery... Done. Erasing partition kpan... Done. Erasing partition cache... Done. Erasing partition padC... Done. Erasing partition system... Done. Erasing partition customize... Done. Erasing partition userdata... Done. Erasing is finished. SW: 1.5.0; FW: 1.22. Write data verification is enabled. Write partitions from C:/Users/maan/Desktop/moto x Sandisk eMMC SEM16G_Wed Dec 20 2017_20_24_18.mpt file... Writing partition GPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl2... Done. Writing partition sbl3... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition utags... Done. Writing partition logs... Done. Writing partition padA... Done. Writing partition sbl2Backup... Done. Writing partition sbl3Backup... Done. Writing partition abootBackup... Done. Writing partition rpmBackup... Done. Writing partition tzBackup... Done. Writing partition utagsBackup... Done. Writing partition padB... Done. Writing partition modemst1... Done. Writing partition modemst2... Done. Writing partition mbl... Done. Writing partition hob... Done. Writing partition dhob... Done. Writing partition persist... Done. Writing partition ssd... Done. Writing partition fsg... Done. Writing partition sp... Done. Writing partition misc... Done. Writing partition pds... Done. Writing partition cid... Done. Writing partition logo... Done. Writing partition clogo... Done. Writing partition devtree... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition kpan... Done. Writing partition padC... Done. Writing partition customize... Done. SW: 1.5.0; FW: 1.22. Selected file: D:/MOTOROLA/XT1058 MOTO X/XT1058_GHOST_ATT_5.1_LPAS23.12-21.7-1_cid1_CFC.xml/flashfile.xml. File parsing finished. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Write data verification is enabled. Writing. Please wait... Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl2... Done. Writing partition sbl3... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Writing partition fsg... Done. Writing partition logo... Done. Erasing partition clogo... Done. Writing partition boot... Done. Writing partition recovery... Done. Erasing partition cache... Done. Erasing partition customize... Done. Writing is finished. SW: 1.5.0; FW: 1.22. Last edited by Medusa Box; 12-21-2017 at 06:22. |
The Following User Says Thank You to maanarman For This Useful Post: |
