02-16-2018, 13:36 | #1 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | Moto XT1543 connection question [Answered] but can not find the pinnacle Could you send srf xt1543? pinning emmc xt1543 Welcome to Medusa Pro Software version 1.5.4. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: Gemalto e-gate Smart Card 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Motorola Model : XT1541 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/MOTOROLA_XT1541_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Motorola Model : XT1541 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/MOTOROLA_XT1541_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Motorola Model : XT1541 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/MOTOROLA_XT1541_EMMC.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : 10 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Motorola Model : XT1541 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/MOTOROLA_XT1541_EMMC.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Motorola Model : XT1541 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/MOTOROLA_XT1541_EMMC.srf Voltage : 1.8V Bus Mode : 4 bits Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 1 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 1 MHz Connecting... ERROR[001]: Can not connect. No target device present. Last edited by Medusa Box; 02-16-2018 at 16:24. |
02-16-2018, 16:23 | #2 (permalink) | |||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Quote:
Accordingly to this error: Quote:
1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible (3-5 CM length). 6. For GND connection use more thicker wire. Also, as I see from your Software log, You have set too high Voltage level: Quote:
