08-07-2018, 01:55 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 762794 Status: Offline Thanks Meter: 14 | Moto XT1621 "dead" after erase FRP partition [Answered] Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB --------------------------------------------------------------- CID Info CID : 150100514531334D420722BF68AFB3C5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.7 Product serial number : (hex) 22BF68AF Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2523136 Number of sectors : 5242880 Device Manufacturer : motorola Device Platform : msm8952 Build ID : NPJ25.93-14-8.1 Release ID : 7.0 Device Model : Moto G (4) Device Name : athene_retail Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_06_08_2018_19_04_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.7; FW: 1.22. P00: GPT (00000000, 00000100) P01: modem (00000100, 00032000) P02: fsc (00032100, 00000002) P03: ssd (00032102, 00000010) P04: sbl1 (00032112, 00000400) P05: sbl1bak (00032512, 00000400) P06: rpm (00032912, 000001B0) P07: rpmbak (00032D12, 000001B0) P08: tz (00033112, 00000718) P09: tzbak (00033D12, 00000718) P10: hyp (00034912, 000000C0) P11: hypbak (00034D12, 000000C0) P12: dsp (00035112, 00008000) P13: modemst1 (0003D112, 00001000) P14: modemst2 (0003E112, 00001000) P15: DDR (0003F200, 00000040) P16: fsg (0003F240, 00004000) P17: sec (00043240, 00000020) P18: aboot (00043300, 00000BB8) P19: abootbak (00043F00, 00000BB8) P20: logs (00044B00, 00001000) P21: utags (00045B00, 00000400) P22: utagsBackup (00045F00, 00000400) P23: cid (00046300, 00000100) P24: logo (00046400, 00008000) P25: clogo (0004E400, 00008000) P26: metadata (00056400, 00000400) P27: kpan (00056800, 00004000) P28: boot (0005A800, 00008000) P29: recovery (00062800, 000080C8) P30: persist (0006A900, 00010000) P31: misc (0007A900, 00000800) P32: config (0007B100, 00000040) P33: limits (0007B200, 00000040) P34: mota (0007B300, 00000800) P35: devcfg (0007BB00, 00000200) P36: dip (0007BD00, 00000800) P37: syscfg (0007C500, 00000400) P38: cmnlib (0007C900, 00000188) P39: keymaster (0007CB00, 000001B8) P40: frp (0007CD00, 00000400) P41: padC (0007D100, 0000AF00) P42: sp (00088000, 00004000) P43: hw (0008C000, 00004000) P44: customize (00090000, 00010000) P45: oem (000A0000, 00148000) P46: cache (001E8000, 00080000) P47: system (00268000, 00500000) P48: userdata (00768000, 015A6F00) Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Gpt_0x0_0x100_06_08_2018_19_04_14.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.7; FW: 1.22. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Cid_0x46300_0x100_06_08_2018_19_04_14.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.7; FW: 1.22. Erasing. Please wait... Erasing partition frp... Done. Done Disconnected. Last edited by Medusa Box; 08-07-2018 at 04:40. |
08-07-2018, 04:39 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Why You made erasing FRP partition? This is incorrect. If You want to do Reset FRP, You should use special "Reset FRP" button in the Software, not make eraseing FRP partition. "Reset FRP" operation make FRP data backup and then make repack FRP data on the device, not erase FRP partition. If You have not read FRP partition backup, before to erase FRP partition, try to find the same device model, read out FRP partition from it and write this RFP partition backup into your device. Also You can try to make "Factory Repair" using original Motorola firmware for this device model. Don't forget to read out Full flash backup from your device before to perform "Factory Repair" operation. |
08-07-2018, 17:14 | #4 (permalink) |
Member: 762794 Status: Offline Thanks Meter: 14 | Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420722BF68AFB3C5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.7 Product serial number : (hex) 22BF68AF Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2523136 Number of sectors : 5242880 Device Manufacturer :motorola Device Platform :msm8952 Build ID :NPJ25.93-14-8.1 Release ID :7.0 Device Model :Moto G (4) Device Name :athene_retail Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_07_08_2018_11_10_52.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.1; FW: 1.23. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00032000) 100 MB P02: fsc (00032100, 00000002) 1024 b P03: ssd (00032102, 00000010) 8 KB P04: sbl1 (00032112, 00000400) 512 KB P05: sbl1bak (00032512, 00000400) 512 KB P06: rpm (00032912, 000001B0) 216 KB P07: rpmbak (00032D12, 000001B0) 216 KB P08: tz (00033112, 00000718) 908 KB P09: tzbak (00033D12, 00000718) 908 KB P10: hyp (00034912, 000000C0) 96 KB P11: hypbak (00034D12, 000000C0) 96 KB P12: dsp (00035112, 00008000) 16 MB P13: modemst1 (0003D112, 00001000) 2048 KB P14: modemst2 (0003E112, 00001000) 2048 KB P15: DDR (0003F200, 00000040) 32 KB P16: fsg (0003F240, 00004000) 8 MB P17: sec (00043240, 00000020) 16 KB P18: aboot (00043300, 00000BB8) 1500 KB P19: abootbak (00043F00, 00000BB8) 1500 KB P20: logs (00044B00, 00001000) 2048 KB P21: utags (00045B00, 00000400) 512 KB P22: utagsBackup (00045F00, 00000400) 512 KB P23: cid (00046300, 00000100) 128 KB P24: logo (00046400, 00008000) 16 MB P25: clogo (0004E400, 00008000) 16 MB P26: metadata (00056400, 00000400) 512 KB P27: kpan (00056800, 00004000) 8 MB P28: boot (0005A800, 00008000) 16 MB P29: recovery (00062800, 000080C8) 16.1 MB P30: persist (0006A900, 00010000) 32 MB P31: misc (0007A900, 00000800) 1024 KB P32: config (0007B100, 00000040) 32 KB P33: limits (0007B200, 00000040) 32 KB P34: mota (0007B300, 00000800) 1024 KB P35: devcfg (0007BB00, 00000200) 256 KB P36: dip (0007BD00, 00000800) 1024 KB P37: syscfg (0007C500, 00000400) 512 KB P38: cmnlib (0007C900, 00000188) 196 KB P39: keymaster (0007CB00, 000001B8) 220 KB P40: frp (0007CD00, 00000400) 512 KB P41: padC (0007D100, 0000AF00) 21.88 MB P42: sp (00088000, 00004000) 8 MB P43: hw (0008C000, 00004000) 8 MB P44: customize (00090000, 00010000) 32 MB P45: oem (000A0000, 00148000) 656 MB P46: cache (001E8000, 00080000) 256 MB P47: system (00268000, 00500000) 2560 MB P48: userdata (00768000, 015A6F00) 10.83 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Gpt_0x0_0x100_07_08_2018_11_10_52.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.1; FW: 1.23. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Cid_0x46300_0x100_07_08_2018_11_10_52.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.1; FW: 1.23. Partition table has been found on device. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition frp from D:/frp_PhysPart_0_06_08_2018_18_58_49.bin file... Done. Writing is finished. |
08-08-2018, 02:43 | #5 (permalink) |
Member: 762794 Status: Offline Thanks Meter: 14 | i make "Factory Repair" using original Motorola firmware , but phone dead new log Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420722BF68AFB3C5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.7 Product serial number : (hex) 22BF68AF Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_07_08_2018_20_42_09.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00032000) 100 MB P02: fsc (00032100, 00000002) 1024 b P03: ssd (00032102, 00000010) 8 KB P04: sbl1 (00032112, 00000400) 512 KB P05: sbl1bak (00032512, 00000400) 512 KB P06: rpm (00032912, 000001B0) 216 KB P07: rpmbak (00032D12, 000001B0) 216 KB P08: tz (00033112, 00000718) 908 KB P09: tzbak (00033D12, 00000718) 908 KB P10: hyp (00034912, 000000C0) 96 KB P11: hypbak (00034D12, 000000C0) 96 KB P12: dsp (00035112, 00008000) 16 MB P13: modemst1 (0003D112, 00001000) 2048 KB P14: modemst2 (0003E112, 00001000) 2048 KB P15: DDR (0003F200, 00000040) 32 KB P16: fsg (0003F240, 00004000) 8 MB P17: sec (00043240, 00000020) 16 KB P18: aboot (00043300, 00000BB8) 1500 KB P19: abootbak (00043F00, 00000BB8) 1500 KB P20: logs (00044B00, 00001000) 2048 KB P21: utags (00045B00, 00000400) 512 KB P22: utagsBackup (00045F00, 00000400) 512 KB P23: cid (00046300, 00000100) 128 KB P24: logo (00046400, 00008000) 16 MB P25: clogo (0004E400, 00008000) 16 MB P26: metadata (00056400, 00000400) 512 KB P27: kpan (00056800, 00004000) 8 MB P28: boot (0005A800, 00008000) 16 MB P29: recovery (00062800, 000080C8) 16.1 MB P30: persist (0006A900, 00010000) 32 MB P31: misc (0007A900, 00000800) 1024 KB P32: config (0007B100, 00000040) 32 KB P33: limits (0007B200, 00000040) 32 KB P34: mota (0007B300, 00000800) 1024 KB P35: devcfg (0007BB00, 00000200) 256 KB P36: dip (0007BD00, 00000800) 1024 KB P37: syscfg (0007C500, 00000400) 512 KB P38: cmnlib (0007C900, 00000188) 196 KB P39: keymaster (0007CB00, 000001B8) 220 KB P40: frp (0007CD00, 00000400) 512 KB P41: padC (0007D100, 0000AF00) 21.88 MB P42: sp (00088000, 00004000) 8 MB P43: hw (0008C000, 00004000) 8 MB P44: customize (00090000, 00010000) 32 MB P45: oem (000A0000, 00148000) 656 MB P46: cache (001E8000, 00080000) 256 MB P47: system (00268000, 00500000) 2560 MB P48: userdata (00768000, 015B6F00) 10.86 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Gpt_0x0_0x100_07_08_2018_20_42_09.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Cid_0x46300_0x100_07_08_2018_20_42_09.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. |
08-08-2018, 04:48 | #6 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
08-08-2018, 21:10 | #7 (permalink) |
Member: 762794 Status: Offline Thanks Meter: 14 | Welcome to Medusa Pro Software version 1.6.5. Started. Reader #0: FT SCR2000 0 Reader #1: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Motorola Model : XT1642 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/MOTOROLA_XT1642_EMMC.srf Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420722BF68AFB3C5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.7 Product serial number : (hex) 22BF68AF Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2523136 Number of sectors : 5242880 Device Manufacturer :motorola Device Platform :msm8952 Build ID :NPJ25.93-14-8.1 Release ID :7.0 Device Model :Moto G (4) Device Name :athene_retail Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_07_08_2018_11_20_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00032000) 100 MB P02: fsc (00032100, 00000002) 1024 b P03: ssd (00032102, 00000010) 8 KB P04: sbl1 (00032112, 00000400) 512 KB P05: sbl1bak (00032512, 00000400) 512 KB P06: rpm (00032912, 000001B0) 216 KB P07: rpmbak (00032D12, 000001B0) 216 KB P08: tz (00033112, 00000718) 908 KB P09: tzbak (00033D12, 00000718) 908 KB P10: hyp (00034912, 000000C0) 96 KB P11: hypbak (00034D12, 000000C0) 96 KB P12: dsp (00035112, 00008000) 16 MB P13: modemst1 (0003D112, 00001000) 2048 KB P14: modemst2 (0003E112, 00001000) 2048 KB P15: DDR (0003F200, 00000040) 32 KB P16: fsg (0003F240, 00004000) 8 MB P17: sec (00043240, 00000020) 16 KB P18: aboot (00043300, 00000BB8) 1500 KB P19: abootbak (00043F00, 00000BB8) 1500 KB P20: logs (00044B00, 00001000) 2048 KB P21: utags (00045B00, 00000400) 512 KB P22: utagsBackup (00045F00, 00000400) 512 KB P23: cid (00046300, 00000100) 128 KB P24: logo (00046400, 00008000) 16 MB P25: clogo (0004E400, 00008000) 16 MB P26: metadata (00056400, 00000400) 512 KB P27: kpan (00056800, 00004000) 8 MB P28: boot (0005A800, 00008000) 16 MB P29: recovery (00062800, 000080C8) 16.1 MB P30: persist (0006A900, 00010000) 32 MB P31: misc (0007A900, 00000800) 1024 KB P32: config (0007B100, 00000040) 32 KB P33: limits (0007B200, 00000040) 32 KB P34: mota (0007B300, 00000800) 1024 KB P35: devcfg (0007BB00, 00000200) 256 KB P36: dip (0007BD00, 00000800) 1024 KB P37: syscfg (0007C500, 00000400) 512 KB P38: cmnlib (0007C900, 00000188) 196 KB P39: keymaster (0007CB00, 000001B8) 220 KB P40: frp (0007CD00, 00000400) 512 KB P41: padC (0007D100, 0000AF00) 21.88 MB P42: sp (00088000, 00004000) 8 MB P43: hw (0008C000, 00004000) 8 MB P44: customize (00090000, 00010000) 32 MB P45: oem (000A0000, 00148000) 656 MB P46: cache (001E8000, 00080000) 256 MB P47: system (00268000, 00500000) 2560 MB P48: userdata (00768000, 015A6F00) 10.83 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Gpt_0x0_0x100_07_08_2018_11_20_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Cid_0x46300_0x100_07_08_2018_11_20_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420722BF68AFB3C5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.7 Product serial number : (hex) 22BF68AF Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2523136 Number of sectors : 5242880 Device Manufacturer :motorola Device Platform :msm8952 Build ID :NPJ25.93-14-8.1 Release ID :7.0 Device Model :Moto G (4) Device Name :athene_retail Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_07_08_2018_12_17_16.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00032000) 100 MB P02: fsc (00032100, 00000002) 1024 b P03: ssd (00032102, 00000010) 8 KB P04: sbl1 (00032112, 00000400) 512 KB P05: sbl1bak (00032512, 00000400) 512 KB P06: rpm (00032912, 000001B0) 216 KB P07: rpmbak (00032D12, 000001B0) 216 KB P08: tz (00033112, 00000718) 908 KB P09: tzbak (00033D12, 00000718) 908 KB P10: hyp (00034912, 000000C0) 96 KB P11: hypbak (00034D12, 000000C0) 96 KB P12: dsp (00035112, 00008000) 16 MB P13: modemst1 (0003D112, 00001000) 2048 KB P14: modemst2 (0003E112, 00001000) 2048 KB P15: DDR (0003F200, 00000040) 32 KB P16: fsg (0003F240, 00004000) 8 MB P17: sec (00043240, 00000020) 16 KB P18: aboot (00043300, 00000BB8) 1500 KB P19: abootbak (00043F00, 00000BB8) 1500 KB P20: logs (00044B00, 00001000) 2048 KB P21: utags (00045B00, 00000400) 512 KB P22: utagsBackup (00045F00, 00000400) 512 KB P23: cid (00046300, 00000100) 128 KB P24: logo (00046400, 00008000) 16 MB P25: clogo (0004E400, 00008000) 16 MB P26: metadata (00056400, 00000400) 512 KB P27: kpan (00056800, 00004000) 8 MB P28: boot (0005A800, 00008000) 16 MB P29: recovery (00062800, 000080C8) 16.1 MB P30: persist (0006A900, 00010000) 32 MB P31: misc (0007A900, 00000800) 1024 KB P32: config (0007B100, 00000040) 32 KB P33: limits (0007B200, 00000040) 32 KB P34: mota (0007B300, 00000800) 1024 KB P35: devcfg (0007BB00, 00000200) 256 KB P36: dip (0007BD00, 00000800) 1024 KB P37: syscfg (0007C500, 00000400) 512 KB P38: cmnlib (0007C900, 00000188) 196 KB P39: keymaster (0007CB00, 000001B8) 220 KB P40: frp (0007CD00, 00000400) 512 KB P41: padC (0007D100, 0000AF00) 21.88 MB P42: sp (00088000, 00004000) 8 MB P43: hw (0008C000, 00004000) 8 MB P44: customize (00090000, 00010000) 32 MB P45: oem (000A0000, 00148000) 656 MB P46: cache (001E8000, 00080000) 256 MB P47: system (00268000, 00500000) 2560 MB P48: userdata (00768000, 015A6F00) 10.83 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Gpt_0x0_0x100_07_08_2018_12_17_16.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Cid_0x46300_0x100_07_08_2018_12_17_16.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Backuping FRP data... Opening C:/Program Files/Medusa Pro Software/Backups/FRP_0x7b100_0x40_07_08_2018_12_17_30.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Removing FRP. Please wait... Done. SW: 1.6.5; FW: 1.24. Selected file: C:/Users/inkagsm/Downloads/Compressed/ATHENE_NPJS25.93-14.7-5_cid50_subsidy-IUSMXLA_regulatory-DEFAULT_CFC.xml/flashfile.xml. File parsing finished. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Write data verification is enabled. Writing. Please wait... Writing partition modem... Done. Writing partition sbl1... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition hyp... Done. Writing partition dsp... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Erasing partition DDR... Done. Writing partition fsg... Done. Writing partition aboot... Done. Writing partition logo... Done. Erasing partition clogo... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition cmnlib... Done. Writing partition keymaster... Done. Erasing partition customize... Done. Writing partition oem... Done. Erasing partition cache... Done. Writing partition system (8 parts): Writing from file C:/Users/inkagsm/Downloads/Compressed/ATHENE_NPJS25.93-14.7-5_cid50_subsidy-IUSMXLA_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.0 (1/8)... Done Writing from file C:/Users/inkagsm/Downloads/Compressed/ATHENE_NPJS25.93-14.7-5_cid50_subsidy-IUSMXLA_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.1 (2/8)... Done Writing from file C:/Users/inkagsm/Downloads/Compressed/ATHENE_NPJS25.93-14.7-5_cid50_subsidy-IUSMXLA_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.2 (3/8)... Done Writing from file C:/Users/inkagsm/Downloads/Compressed/ATHENE_NPJS25.93-14.7-5_cid50_subsidy-IUSMXLA_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.3 (4/8)... Done Writing from file C:/Users/inkagsm/Downloads/Compressed/ATHENE_NPJS25.93-14.7-5_cid50_subsidy-IUSMXLA_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.4 (5/8)... Done Writing from file C:/Users/inkagsm/Downloads/Compressed/ATHENE_NPJS25.93-14.7-5_cid50_subsidy-IUSMXLA_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.5 (6/8)... Done Writing from file C:/Users/inkagsm/Downloads/Compressed/ATHENE_NPJS25.93-14.7-5_cid50_subsidy-IUSMXLA_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.6 (7/8)... Done Writing from file C:/Users/inkagsm/Downloads/Compressed/ATHENE_NPJS25.93-14.7-5_cid50_subsidy-IUSMXLA_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.7 (8/8)... Done Writing partition system... Done. Erasing partition userdata... Done. Writing is finished. SW: 1.6.5; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420722BF68AFB3C5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.7 Product serial number : (hex) 22BF68AF Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_07_08_2018_13_00_23.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00032000) 100 MB P02: fsc (00032100, 00000002) 1024 b P03: ssd (00032102, 00000010) 8 KB P04: sbl1 (00032112, 00000400) 512 KB P05: sbl1bak (00032512, 00000400) 512 KB P06: rpm (00032912, 000001B0) 216 KB P07: rpmbak (00032D12, 000001B0) 216 KB P08: tz (00033112, 00000718) 908 KB P09: tzbak (00033D12, 00000718) 908 KB P10: hyp (00034912, 000000C0) 96 KB P11: hypbak (00034D12, 000000C0) 96 KB P12: dsp (00035112, 00008000) 16 MB P13: modemst1 (0003D112, 00001000) 2048 KB P14: modemst2 (0003E112, 00001000) 2048 KB P15: DDR (0003F200, 00000040) 32 KB P16: fsg (0003F240, 00004000) 8 MB P17: sec (00043240, 00000020) 16 KB P18: aboot (00043300, 00000BB8) 1500 KB P19: abootbak (00043F00, 00000BB8) 1500 KB P20: logs (00044B00, 00001000) 2048 KB P21: utags (00045B00, 00000400) 512 KB P22: utagsBackup (00045F00, 00000400) 512 KB P23: cid (00046300, 00000100) 128 KB P24: logo (00046400, 00008000) 16 MB P25: clogo (0004E400, 00008000) 16 MB P26: metadata (00056400, 00000400) 512 KB P27: kpan (00056800, 00004000) 8 MB P28: boot (0005A800, 00008000) 16 MB P29: recovery (00062800, 000080C8) 16.1 MB P30: persist (0006A900, 00010000) 32 MB P31: misc (0007A900, 00000800) 1024 KB P32: config (0007B100, 00000040) 32 KB P33: limits (0007B200, 00000040) 32 KB P34: mota (0007B300, 00000800) 1024 KB P35: devcfg (0007BB00, 00000200) 256 KB P36: dip (0007BD00, 00000800) 1024 KB P37: syscfg (0007C500, 00000400) 512 KB P38: cmnlib (0007C900, 00000188) 196 KB P39: keymaster (0007CB00, 000001B8) 220 KB P40: frp (0007CD00, 00000400) 512 KB P41: padC (0007D100, 0000AF00) 21.88 MB P42: sp (00088000, 00004000) 8 MB P43: hw (0008C000, 00004000) 8 MB P44: customize (00090000, 00010000) 32 MB P45: oem (000A0000, 00148000) 656 MB P46: cache (001E8000, 00080000) 256 MB P47: system (00268000, 00500000) 2560 MB P48: userdata (00768000, 015B6F00) 10.86 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Gpt_0x0_0x100_07_08_2018_13_00_23.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Cid_0x46300_0x100_07_08_2018_13_00_23.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Partition table has been found on device. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420722BF68AFB3C5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.7 Product serial number : (hex) 22BF68AF Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_07_08_2018_13_05_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00032000) 100 MB P02: fsc (00032100, 00000002) 1024 b P03: ssd (00032102, 00000010) 8 KB P04: sbl1 (00032112, 00000400) 512 KB P05: sbl1bak (00032512, 00000400) 512 KB P06: rpm (00032912, 000001B0) 216 KB P07: rpmbak (00032D12, 000001B0) 216 KB P08: tz (00033112, 00000718) 908 KB P09: tzbak (00033D12, 00000718) 908 KB P10: hyp (00034912, 000000C0) 96 KB P11: hypbak (00034D12, 000000C0) 96 KB P12: dsp (00035112, 00008000) 16 MB P13: modemst1 (0003D112, 00001000) 2048 KB P14: modemst2 (0003E112, 00001000) 2048 KB P15: DDR (0003F200, 00000040) 32 KB P16: fsg (0003F240, 00004000) 8 MB P17: sec (00043240, 00000020) 16 KB P18: aboot (00043300, 00000BB8) 1500 KB P19: abootbak (00043F00, 00000BB8) 1500 KB P20: logs (00044B00, 00001000) 2048 KB P21: utags (00045B00, 00000400) 512 KB P22: utagsBackup (00045F00, 00000400) 512 KB P23: cid (00046300, 00000100) 128 KB P24: logo (00046400, 00008000) 16 MB P25: clogo (0004E400, 00008000) 16 MB P26: metadata (00056400, 00000400) 512 KB P27: kpan (00056800, 00004000) 8 MB P28: boot (0005A800, 00008000) 16 MB P29: recovery (00062800, 000080C8) 16.1 MB P30: persist (0006A900, 00010000) 32 MB P31: misc (0007A900, 00000800) 1024 KB P32: config (0007B100, 00000040) 32 KB P33: limits (0007B200, 00000040) 32 KB P34: mota (0007B300, 00000800) 1024 KB P35: devcfg (0007BB00, 00000200) 256 KB P36: dip (0007BD00, 00000800) 1024 KB P37: syscfg (0007C500, 00000400) 512 KB P38: cmnlib (0007C900, 00000188) 196 KB P39: keymaster (0007CB00, 000001B8) 220 KB P40: frp (0007CD00, 00000400) 512 KB P41: padC (0007D100, 0000AF00) 21.88 MB P42: sp (00088000, 00004000) 8 MB P43: hw (0008C000, 00004000) 8 MB P44: customize (00090000, 00010000) 32 MB P45: oem (000A0000, 00148000) 656 MB P46: cache (001E8000, 00080000) 256 MB P47: system (00268000, 00500000) 2560 MB P48: userdata (00768000, 015B6F00) 10.86 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Gpt_0x0_0x100_07_08_2018_13_05_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE13MB_Cid_0x46300_0x100_07_08_2018_13_05_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.5; FW: 1.24. Disconnected. |
08-09-2018, 04:27 | #8 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to do "Factory Repair" using another original firmwares for this device model. Also don't forger to write the first CID backup back into the device, this is important. |
