10-18-2018, 08:40 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Moto XT1791 can add repair? [Answered] Welcome to Medusa Pro Software version 1.5.8. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515831334D4207B86CF28B3599 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) B86CF28B Manufacturing date : 03/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_18_10_2018_02_33_57.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. P00: GPT (00000000, 00000100) 128 KB P01: sbl1 (00000100, 00000400) 512 KB P02: rpm (00000500, 00000200) 256 KB P03: tz (00000900, 00000E00) 1792 KB P04: devcfg (00001900, 00000100) 128 KB P05: aboot (00001B00, 00000C00) 1536 KB P06: cmnlib (00002700, 00000200) 256 KB P07: cmnlib64 (00002900, 00000200) 256 KB P08: keymaster (00002B00, 00000200) 256 KB P09: prov (00002D00, 00000180) 192 KB P10: sbl1bak (00002F00, 00000400) 512 KB P11: rpmbak (00003300, 00000200) 256 KB P12: tzbak (00003700, 00000E00) 1792 KB P13: devcfgbak (00004700, 00000100) 128 KB P14: abootbak (00004900, 00000C00) 1536 KB P15: cmnlibbak (00005500, 00000200) 256 KB P16: cmnlib64bak (00005700, 00000200) 256 KB P17: keymasterbak (00005900, 00000200) 256 KB P18: provbak (00005B00, 00000180) 192 KB P19: modem (00005D00, 00032000) 100 MB P20: fsc (00037D00, 00000002) 1024 b P21: ssd (00037D02, 00000010) 8 KB P22: dsp (00037D12, 00008000) 16 MB P23: DDR (0003FE00, 00000040) 32 KB P24: sec (0003FE40, 00000020) 16 KB P25: utags (0003FF00, 00000400) 512 KB P26: utagsBackup (00040300, 00000400) 512 KB P27: modemst1 (00040700, 00001000) 2048 KB P28: modemst2 (00041700, 00001000) 2048 KB P29: fsg (00042700, 00004000) 8 MB P30: persist (00046700, 00010000) 32 MB P31: frp (00056700, 00000400) 512 KB P32: cid (00056B00, 00000100) 128 KB P33: logo (00056C00, 00008000) 16 MB P34: carrier (0005EC00, 00008000) 16 MB P35: metadata (00066C00, 00000400) 512 KB P36: kpan (00067000, 00004000) 8 MB P37: boot (0006B000, 00008000) 16 MB P38: recovery (00073000, 000080C8) 16.1 MB P39: misc (0007B100, 00000800) 1024 KB P40: limits (0007B900, 00000040) 32 KB P41: mota (0007BA00, 00000400) 512 KB P42: dip (0007BE00, 00000800) 1024 KB P43: syscfg (0007C600, 00000400) 512 KB P44: logs (0007CA00, 00001000) 2048 KB P45: apdp (0007DA00, 00000200) 256 KB P46: msadp (0007DC00, 00000200) 256 KB P47: dpo (0007DE00, 00000010) 8 KB P48: padA (0007DF00, 00002100) 4.125 MB P49: sp (00080000, 00004000) 8 MB P50: hw (00084000, 00004000) 8 MB P51: oem (00088000, 00148000) 656 MB P52: cache (001D0000, 00080000) 256 MB P53: system (00250000, 006C0000) 3456 MB P54: userdata (00910000, 0312DF00) 24.59 GB Backuping Gpt partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_Gpt_0x0_0x100_18_10_2018_02_33_57.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.8; FW: 1.23. Backuping Cid partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_Cid_0x56b00_0x100_18_10_2018_02_33_57.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.8; FW: 1.23. Disconnected. Last edited by Medusa Box; 10-18-2018 at 09:42. |
10-18-2018, 09:42 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Try to write other latest available XML firmwares. We will try to but this device and add repair support in future Software updates. |
11-07-2018, 07:30 | #3 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | need hellp for make sfr of this model xt1791,this phone work all ok need read partition for create sft or dump and repair other phone thanks Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.6V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515831334D4207937DC2356497 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 937DC235 Manufacturing date : 06/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 2424832 Number of sectors : 7077888 Device Manufacturer :motorola Device Platform :msm8937 Build ID :OPP28.65-37 Release ID :8.1.0 Device Model :Moto G (5S) Device Name :montana_retail Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_06_11_2018_23_28_52.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. P00: GPT (00000000, 00000100) 128 KB P01: sbl1 (00000100, 00000400) 512 KB P02: rpm (00000500, 00000200) 256 KB P03: tz (00000900, 00000E00) 1792 KB P04: devcfg (00001900, 00000100) 128 KB P05: aboot (00001B00, 00000C00) 1536 KB P06: cmnlib (00002700, 00000200) 256 KB P07: cmnlib64 (00002900, 00000200) 256 KB P08: keymaster (00002B00, 00000200) 256 KB P09: prov (00002D00, 00000180) 192 KB P10: sbl1bak (00002F00, 00000400) 512 KB P11: rpmbak (00003300, 00000200) 256 KB P12: tzbak (00003700, 00000E00) 1792 KB P13: devcfgbak (00004700, 00000100) 128 KB P14: abootbak (00004900, 00000C00) 1536 KB P15: cmnlibbak (00005500, 00000200) 256 KB P16: cmnlib64bak (00005700, 00000200) 256 KB P17: keymasterbak (00005900, 00000200) 256 KB P18: provbak (00005B00, 00000180) 192 KB P19: modem (00005D00, 00032000) 100 MB P20: fsc (00037D00, 00000002) 1024 b P21: ssd (00037D02, 00000010) 8 KB P22: dsp (00037D12, 00008000) 16 MB P23: DDR (0003FE00, 00000040) 32 KB P24: sec (0003FE40, 00000020) 16 KB P25: utags (0003FF00, 00000400) 512 KB P26: utagsBackup (00040300, 00000400) 512 KB P27: modemst1 (00040700, 00001000) 2048 KB P28: modemst2 (00041700, 00001000) 2048 KB P29: fsg (00042700, 00004000) 8 MB P30: persist (00046700, 00010000) 32 MB P31: frp (00056700, 00000400) 512 KB P32: cid (00056B00, 00000100) 128 KB P33: logo (00056C00, 00008000) 16 MB P34: carrier (0005EC00, 00008000) 16 MB P35: metadata (00066C00, 00000400) 512 KB P36: kpan (00067000, 00004000) 8 MB P37: boot (0006B000, 00008000) 16 MB P38: recovery (00073000, 000080C8) 16.1 MB P39: misc (0007B100, 00000800) 1024 KB P40: limits (0007B900, 00000040) 32 KB P41: mota (0007BA00, 00000400) 512 KB P42: dip (0007BE00, 00000800) 1024 KB P43: syscfg (0007C600, 00000400) 512 KB P44: logs (0007CA00, 00001000) 2048 KB P45: apdp (0007DA00, 00000200) 256 KB P46: msadp (0007DC00, 00000200) 256 KB P47: dpo (0007DE00, 00000010) 8 KB P48: padA (0007DF00, 00002100) 4.125 MB P49: sp (00080000, 00004000) 8 MB P50: hw (00084000, 00004000) 8 MB P51: oem (00088000, 00148000) 656 MB P52: cache (001D0000, 00080000) 256 MB P53: system (00250000, 006C0000) 3456 MB P54: userdata (00910000, 0312DFDF) 24.59 GB Backuping Gpt partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_Gpt_0x0_0x100_06_11_2018_23_28_52.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.8; FW: 1.23. Backuping Cid partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_Cid_0x56b00_0x100_06_11_2018_23_28_52.bin file... Last edited by jmr; 11-07-2018 at 07:37. |
11-07-2018, 07:44 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. To create SRF, connect the device, press "Constructor" button, select (check) all partitions except CID, fill info fields and create SRF. Then, please upload it somewhere and post here link, we will upload your SRF into the Support Area for all Medusa users. |
11-07-2018, 08:10 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | The best ways is to read all partitions, except CID. But You also can create second SRF without Cache and System partitions, they are not necessary, but may be useful. |
