01-24-2018, 17:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Motorola Turbo XT1254 32GB Convert To 64GB Successfully Done Code: Welcome to Medusa Pro Software version 1.5.2. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HCG8e Page size : 512 B Block size : 512 B Block count : 122159104 Size : 58.25 GB (59648.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48434738650503906725C3A1AF Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8e Product revision : 0.3 Product serial number : (hex) 906725C3 Manufacturing date : 10/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFFF8A4040B3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30539776 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : 90000000 bytes Device sector size : 512 bytes Partition offset : 3473408 Number of sectors : 6914048 Device Manufacturer : motorola Device Platform : apq8084 Build ID : SU4TL-49 Display Build ID : SU4TL-49 Release ID : 5.1 Device Model : XT1254 Device Name : quark_verizon Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : quark_verizon-user 5.1 SU4TL-49 5 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HCG8e_24_01_2018_16_44_53.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.22. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00040000) 128 MB P02: sbl1 (00040100, 00000300) 384 KB P03: sdi (00040500, 00000070) 56 KB P04: sec (00040700, 00000020) 16 KB P05: ddr (00040720, 00000040) 32 KB P06: aboot (00040800, 00000800) 1024 KB P07: rpm (000413B8, 00000200) 256 KB P08: utags (000417A0, 00000400) 512 KB P09: tz (00041BA0, 000003E8) 500 KB P10: factorytune1 (00041F88, 00001800) 3072 KB P11: padA (00043788, 00000878) 1084 KB P12: sbl1bak (00044000, 00000300) 384 KB P13: abootBackup (00044400, 00000800) 1024 KB P14: rpmBackup (00044FB8, 00000200) 256 KB P15: utagsBackup (000453A0, 00000400) 512 KB P16: tzBackup (000457A0, 000003E8) 500 KB P17: mdm1m9kefs1 (00045B88, 00000800) 1024 KB P18: mdm1m9kefs2 (00046388, 00000800) 1024 KB P19: padB (00046B88, 00001078) 2108 KB P20: frp (00047C00, 00000400) 512 KB P21: logs (00048000, 00001000) 2048 KB P22: persist (00049000, 00010000) 32 MB P23: mdm1hob (00059000, 00000200) 256 KB P24: mdm1dhob (00059200, 00000040) 32 KB P25: sp (00059240, 00000800) 1024 KB P26: cid (00059A40, 00000100) 128 KB P27: pds (00059B40, 00001800) 3072 KB P28: logo (0005B340, 00004000) 8 MB P29: clogo (0005F340, 00005800) 11 MB P30: misc (00064B40, 00000800) 1024 KB P31: padC (00065340, 00000CC0) 1632 KB P32: mdm1m9kefs3 (00066000, 00000618) 780 KB P33: mdm1m9kefsc (00066700, 00000002) 1024 b P34: ssd (00066702, 00000010) 8 KB P35: kpan (00066712, 00004000) 8 MB P36: boot (0006A800, 00008000) 16 MB P37: recovery (00072800, 00008020) 16.02 MB P38: factorytune2 (0007A820, 00008040) 16.03 MB P39: cache (00082860, 002CD7A0) 1435 MB P40: system (00350000, 00698000) 3376 MB P41: userdata (009E8000, 06A87F00) 53.27 GB Backuping Gpt partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HCG8e_Gpt_0x0_0x100_24_01_2018_16_44_53.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.2; FW: 1.22. Backuping Cid partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HCG8e_Cid_0x59a40_0x100_24_01_2018_16_44_53.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.2; FW: 1.22. Erasing partition GPT... Done. Erasing partition modem... Done. Erasing partition sbl1... Done. Erasing partition sdi... Done. Erasing partition sec... Done. Erasing partition ddr... Done. Erasing partition aboot... Done. Erasing partition rpm... Done. Erasing partition utags... Done. Erasing partition tz... Done. Erasing partition factorytune1... Done. Erasing partition padA... Done. Erasing partition sbl1bak... Done. Erasing partition abootBackup... Done. Erasing partition rpmBackup... Done. Erasing partition utagsBackup... Done. Erasing partition tzBackup... Done. Erasing partition mdm1m9kefs1... Done. Erasing partition mdm1m9kefs2... Done. Erasing partition padB... Done. Erasing partition frp... Done. Erasing partition logs... Done. Erasing partition persist... Done. Erasing partition mdm1hob... Done. Erasing partition mdm1dhob... Done. Erasing partition sp... Done. Erasing partition cid... Done. Erasing partition pds... Done. Erasing partition logo... Done. Erasing partition clogo... Done. Erasing partition misc... Done. Erasing partition padC... Done. Erasing partition mdm1m9kefs3... Done. Erasing partition mdm1m9kefsc... Done. Erasing partition ssd... Done. Erasing partition kpan... Done. Erasing partition boot... Done. Erasing partition recovery... Done. Erasing partition factorytune2... Done. Erasing partition cache... Done. Erasing partition system... Done. Erasing partition userdata... Done. Erasing is finished. SW: 1.5.2; FW: 1.22. Write data verification is enabled. Write partitions from C:/Users/maanarman/Desktop/1254/ turbo Samsung eMMC MBG4GC_Tue Jan 23 2018_20_02_22.mpt file... Writing partition GPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sdi... Done. Writing partition sec... Done. Writing partition ddr... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition utags... Done. Writing partition tz... Done. Writing partition factorytune1... Done. Writing partition padA... Done. Writing partition sbl1bak... Done. Writing partition abootBackup... Done. Writing partition rpmBackup... Done. Writing partition utagsBackup... Done. Writing partition tzBackup... Done. Writing partition mdm1m9kefs1... Done. Writing partition mdm1m9kefs2... Done. Writing partition padB... Done. Writing partition frp... Done. Writing partition logs... Done. Writing partition persist... Done. Writing partition mdm1hob... Done. Writing partition mdm1dhob... Done. Writing partition sp... Done. Writing partition cid... Done. Writing partition pds... Done. Writing partition logo... Done. Writing partition clogo... Done. Writing partition misc... Done. Writing partition padC... Done. Writing partition mdm1m9kefs3... Done. Writing partition mdm1m9kefsc... Done. Writing partition ssd... Done. Writing partition kpan... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition factorytune2... Done. SW: 1.5.2; FW: 1.22. Disconnected. Last edited by Medusa Box; 01-25-2018 at 06:12. |
The Following User Says Thank You to maanarman For This Useful Post: |
