06-11-2018, 20:55 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: karachi Age: 31
Member: 1779651 Status: Offline Sonork: 100.1603336 Thanks Meter: 97 | Motorola XT1766 boot repair successfully done here is logs:- Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203E45FB87AA491 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) E45FB87A Manufacturing date : 10/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE63MB_11_06_2018_21_02_12.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.1; FW: 1.23. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00013F00) 39.88 MB P02: sbl1 (00014000, 00000400) 512 KB P03: DDR (00014500, 00000100) 128 KB P04: aboot (00014600, 00000898) 1100 KB P05: rpm (000151B8, 000001F4) 250 KB P06: tz (000154A0, 00000460) 560 KB P07: hyp (00015950, 00000100) 128 KB P08: utags (00015C88, 00000400) 512 KB P09: misc (00016088, 00000400) 512 KB P10: padA (00016488, 00001B78) 3516 KB P11: abootBackup (00018000, 00000898) 1100 KB P12: rpmBackup (00018BB8, 000001F4) 250 KB P13: tzBackup (00018EA0, 00000460) 560 KB P14: hypBackup (00019350, 00000100) 128 KB P15: utagsBackup (00019688, 00000400) 512 KB P16: logs (00019A88, 00001000) 2048 KB P17: frp (0001AA88, 00000400) 512 KB P18: padB (0001AE88, 00001178) 2236 KB P19: modemst1 (0001C000, 00000C00) 1536 KB P20: modemst2 (0001CC00, 00000C00) 1536 KB P21: hob (0001D800, 000003D0) 488 KB P22: dhob (0001DBD0, 00000040) 32 KB P23: fsg (0001DD00, 00000C00) 1536 KB P24: fsc (0001E900, 00000002) 1024 b P25: cid (0001E902, 00000100) 128 KB P26: metadata (0001EA02, 00000400) 512 KB P27: logo (0001EE02, 00003000) 6 MB P28: clogo (00021E02, 00003000) 6 MB P29: persist (00024F00, 00004000) 8 MB P30: kpan (00028F00, 00004000) 8 MB P31: boot (0002CF00, 00010000) 32 MB P32: recovery (0003CF00, 0000FFE0) 31.98 MB P33: ssd (0004CF00, 00000010) 8 KB P34: padC (0004CF10, 000030F0) 6.117 MB P35: sp (00050000, 00004000) 8 MB P36: keystore (00054000, 00004000) 8 MB P37: customize (00058000, 00010000) 32 MB P38: oem (00068000, 00008000) 16 MB P39: carrier (00070000, 00008000) 16 MB P40: cache (00078000, 00180000) 768 MB P41: system (001F8000, 00550000) 2720 MB P42: userdata (00748000, 015D6F00) 10.92 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE63MB_Gpt_0x0_0x100_11_06_2018_21_02_12.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.1; FW: 1.23. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE63MB_Cid_0x1e902_0x100_11_06_2018_21_02_12.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.1; FW: 1.23. Save to C:/Program Files/Medusa Pro Software/usssss/Samsung eMMC QE63MB_Mon Jun 11 2018_21_02_48.mpt file... Reading partition modem... Done. Reading partition modemst1... Done. Reading partition modemst2... Done. Reading partition carrier... Done. Reading is finished. SW: 1.6.1; FW: 1.23. Selected file: F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/servicefile.xml. File parsing finished. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Write data verification is enabled. Writing. Please wait... Writing partition sbl1... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition devcfg... Done. Writing partition aboot... Done. Writing partition cmnlib... Done. Writing partition cmnlib64... Done. Writing partition keymaster... Done. Writing partition prov... Done. Writing partition modem... Done. Writing partition dsp... Done. Erasing partition DDR... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Writing partition fsg... Done. Writing partition logo... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition oem... Done. Writing partition system (5 parts): Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.0 (1/5)... Done Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.1 (2/5)... Done Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.2 (3/5)... Done Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.3 (4/5)... Done Writing from file F:/motorola/xt1766/SPERRY_SPRINT_NCQS26.69-64-5_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml/system.img_sparsechunk.4 (5/5)... Done Writing partition system... Done. Writing is finished. SW: 1.6.1; FW: 1.23. feel the power of medusa team BR. USMAN SOFTRWARE Last edited by Medusa Box; 06-12-2018 at 04:33. |
The Following 2 Users Say Thank You to s a dot com For This Useful Post: |
