09-15-2018, 16:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: yemen
Member: 346934 Status: Offline Sonork: 100.1575675 Thanks Meter: 59 | My new box can't write any boot [Answered] how are you i have new box when write any boot can't always hange when read any boot without problem how solve this problem thank you Last edited by Medusa Box; 09-16-2018 at 11:09. |
09-16-2018, 11:09 | #6 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. What device do You want to repair exactly? Please post here full Software log with all of perform operations with the device, we will check it. It is not possible to guess where can be the problem without any data/Software logs. |
09-16-2018, 13:59 | #7 (permalink) |
Member: 346934 Status: Offline Sonork: 100.1575675 Thanks Meter: 59 | thank you for reply about model : ls777 log : Welcome to Medusa Pro Software version 1.6.7. Started. Reader #0: Alcor Micro USB Smart Card Reader 4 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777_Unlock SRF : K:/lg/UNLOCK/LG_LS777_Unlock.srf Voltage : 3.0V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420DC1A1CC934435 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) C1A1CC93 Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_ظ،ظ¥_ظ*ظ©_ظ¢ظ*ظ،ظ¨_ظ،ظ¨_ظConnect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: (8001188079793DD5, 8086FE8686C22C) 7.078e+07 GB Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777_Unlock SRF : K:/lg/UNLOCK/LG_LS777_Unlock.srf Voltage : 3.0V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420DC1A1CC934435 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) C1A1CC93 Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_ظ،ظ¥_ظ*ظ©_ظ¢ظ*ظ،ظ¨_ظ،ظ¨_ظConnect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: (8001188079793DD5, 8086FE8686C22C) 7.078e+07 GB Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777_Unlock SRF : K:/lg/UNLOCK/LG_LS777_Unlock.srf Voltage : 3.0V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420DC1A1CC934435 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) C1A1CC93 Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_ظ،ظ¥_ظ*ظ©_ظ¢ظ*ظ،ظ¨_ظ،ظ¨_ظConnect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: (8001188079793DD5, 8086FE8686C22C) 7.078e+07 GB Repairing from file "K:/lg/UNLOCK/LG_LS777_Unlock.srf". Write data verification is enabled. Writing modem partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. but with other box write without problem |
09-17-2018, 04:49 | #9 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Quote:
