N7000 galaxy note n7000 boot repair failed Hi mates i have GALXY NOTE N7000 boot dead then i tryed to repair with Medusa box but its giving following error message elcome to Medusa Box Software version 1.4.6 Selected device model: Samsung GT-N7000 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.85 V CPU : Samsung S5PC210 Core ID : 4BA00477 ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. please help me wts wrong with my phone please help me THANKS |
Hello. Please select Jtag speed 1.0 MHz and try to connect again. Also please solder Jtag wires as short as possible. And note - for powering the device, please use BOTH fully charged battery (or external power supply) AND USB cable. Try to connect a few times. |
Boot Repair Needed for Galaxy Note GT - N7000 Hello all According to this post on here: http://forum.gsmhosting.com/vbb/f200...-here-1488048/ It seems possible to revive a bricked Samsung phone without the use of JTAG box ? My reason I ask is because.... I need some advice asap please, on how to - Boot Repair or have the boot loader regenerated for a Galaxy Note GT - N7000 To cut a long story short.... I used odin on the pc and flashed (by mistake) the wrong bootloader into the phone (as part of flashing fresh rom procedure)! So now.... Basically when I press power on the phone, nothing happens. When I put the 'jig' into it - nothing happens - no download mode when I press the recovery key / download key modes - nothing happens When I plug the charger in - there is no battery charge icon When I plug the usb cable into the laptop - nothing happens Basically the phone is bricked and having read a similar thread on how to revive a Samsung without the phone having to be turned on, or the battery in, well I thought to ask. Many thanks for any replies. :cool: If anyone knows of any mobile phone outlets in the South West part of the UK that can fix such problems, I look forward to hearing from you on that issue also. :D |
but not all... |
this error note n7000 repair boot Modelo del dispositivo seleccionado: Samsung GT-N7000 Conectando, por favor espere... Insuficiente nivel de voltaje VREF = 2.23 V. Por favor, chequee el estado de la alimentación del dispositivo. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. TAP ID. detectado: 4BA00477, Largo de IR= 4. Velocidad de JTAG: 1000 KHz. Nivel de VREF: 2.24 V. Tipo de procesador: Samsung S5PC210 ID. del núcleo: 4BA00477 Dispositivo de almacenamiento: Samsung eMMC VYL00M ID del dispositivo: 00150001 Tamaño del bloque: 512 bytes Bloque: 30777344 Tamaño de almacenamiento: 14.7 Gb Abriendo el archivo "G:\MEDUSA BOX\SAMSUNG_GTN7000_Repair.mf"... Escribiendo la sección BOOT. Por favor espere... ERROR[018]: Operación con el bloque lógico fallida en 16 Kb. (Dirección Hexadecimal 0x00004000). Razón: Command failed. |
please,. help me samsung galaxy note n7000 short please,. help me samsung galaxy note n7000 if in the immediate short press on and the engine so hot how its solutions,. I beg master |
Please explain the problem in more details. What is the state of your device? What is the problem with it exactly?... Does the device go into Download Mode? |
N7000 jtag error jtag Log started at 09/07/2016 15:49:56 ... Welcome to Octoplus JTAG Box Software version 1.9.5 Operating Mode: EasyRepair Mode Selected device model: Samsung GT-N7000 Connecting. Please wait... Checking data... VREF = 2.56V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. ERROR[030]: TDO is constant high. Please check target device connection. MI: Medusa JTAG init failed. Please connect the target device and power it on... Checking data... VREF = 2.56V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. ERROR[030]: TDO is constant high. Please check target device connection. MI: Medusa JTAG init failed. Checking data... VREF = 2.56V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. ERROR[000]: Unable to halt core. Checking data... VREF = 2.55V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 8000 KHz. VREF level : 2.55 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000011. MI: Detailed server caps: FLASH, WDOG MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0x00000000. ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Please connect the target device and power it on... Checking data... VREF = 2.55V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 8000 KHz. VREF level : 2.55 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0xFFFFFFFF, cycle 0. MI: Received status 0xFFFFFFFF, cycle 1. MI: Received status 0xFFFFFFFF, cycle 2. MI: Failed to start Medusa Device Server. ERROR[004]: Medusa Device Server did not replied to HELLO command. Checking data... VREF = 2.61V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 8000 KHz. VREF level : 2.56 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0x00000000. ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Checking data... VREF = 2.58V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 8000 KHz. VREF level : 2.58 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000011. MI: Detailed server caps: FLASH, WDOG MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0x00000000. ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Please connect the target device and power it on... Checking data... VREF = 2.59V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 8000 KHz. VREF level : 2.58 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0xFFFFFFFF, cycle 0. MI: Received status 0xFFFFFFFF, cycle 1. MI: Received status 0xFFFFFFFF, cycle 2. MI: Failed to start Medusa Device Server. ERROR[004]: Medusa Device Server did not replied to HELLO command. Checking data... VREF = 2.64V is less than required level. Please check target device power supply. ERROR[035]: Target device has been powered off during connect. Checking data... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 8000 KHz. VREF level : 2.77 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000011. MI: Detailed server caps: FLASH, WDOG MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0x00000000. ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Please connect the target device and power it on... Checking data... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 8000 KHz. VREF level : 2.77 V CPU : Samsung S5PC210 Core ID : 4BA00477 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0xFFFFFFFF, cycle 0. MI: Received status 0xFFFFFFFF, cycle 1. MI: Received status 0xFFFFFFFF, cycle 2. MI: Failed to start Medusa Device Server. ERROR[004]: Medusa Device Server did not replied to HELLO command. |
Hi. Please select JTAG speed 1.0 MHz and try to connect again. Also please solder JTAG wires as short as possible. For powering the device, please use BOTH fully charged battery (or external power supply) AND USB cable, this is important! Try to connect the device a few times. |
