Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 06-01-2012, 07:28   #1 (permalink)
Member: 997544
Thanks Meter: 70
N7000 galaxy note n7000 boot repair failed
Hi mates i have GALXY NOTE N7000 boot dead then i tryed to repair with Medusa box but its giving following error message
elcome to Medusa Box Software version 1.4.6
Selected device model: Samsung GT-N7000
Connecting. Please wait...
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision C.
Detected TAP ID: 4BA00477, IR Length = 4.
ERROR[000]: Unable to halt core.
Please connect the target device and power it on...
JTAG speed : 8000 KHz.
VREF level : 2.85 V
CPU : Samsung S5PC210
Core ID : 4BA00477
ERROR[008]: Unknown flash device. Device No:ID = 0:00000000.
ERROR[035]: Target device has been powered off during connect.
please help me wts wrong with my phone please help me
THANKS
Old 06-01-2012, 08:11   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,401
Hello.
Please select Jtag speed 1.0 MHz and try to connect again. Also please solder Jtag wires as short as possible. And note - for powering the device, please use BOTH fully charged battery (or external power supply) AND USB cable. Try to connect a few times.
Old 08-03-2012, 08:36   #3 (permalink)
Member: 556452
Question Boot Repair Needed for Galaxy Note GT - N7000
Hello all
According to this post on here:
http://forum.gsmhosting.com/vbb/f200...-here-1488048/
It seems possible to revive a bricked Samsung phone without the use of JTAG box ?
My reason I ask is because....
I need some advice asap please, on how to - Boot Repair or have the boot loader regenerated for a Galaxy Note GT - N7000
To cut a long story short....
I used odin on the pc and flashed (by mistake) the wrong bootloader into the phone (as part of flashing fresh rom procedure)!
So now....
Basically when I press power on the phone, nothing happens.
When I put the 'jig' into it - nothing happens - no download mode
when I press the recovery key / download key modes - nothing happens
When I plug the charger in - there is no battery charge icon
When I plug the usb cable into the laptop - nothing happens
Basically the phone is bricked and having read a similar thread on how to revive a Samsung without the phone having to be turned on, or the battery in, well I thought to ask.
Many thanks for any replies.
If anyone knows of any mobile phone outlets in the South West part of the UK that can fix such problems, I look forward to hearing from you on that issue also.
Old 08-07-2012, 18:47   #4 (permalink)
Member: 1755599
Thanks Meter: 19
Originally Posted by tsam19 View Post
Hello all
So now....
some samsung can revived without jtag box....
but not all...
The Following User Says Thank You to JTAG'gerz For This Useful Post:
Old 12-13-2012, 22:26   #5 (permalink)
Member: 445979
Thanks Meter: 3
this error note n7000 repair boot
Modelo del dispositivo seleccionado: Samsung GT-N7000
Conectando, por favor espere...
Insuficiente nivel de voltaje VREF = 2.23 V. Por favor, chequee el estado de la alimentación del dispositivo.
TAP ID. detectado: 4BA00477, Largo de IR= 4.
Velocidad de JTAG: 1000 KHz.
Nivel de VREF: 2.24 V.
Tipo de procesador: Samsung S5PC210
ID. del núcleo: 4BA00477
Dispositivo de almacenamiento: Samsung eMMC VYL00M
ID del dispositivo: 00150001
Tamaño del bloque: 512 bytes
Bloque: 30777344
Tamaño de almacenamiento: 14.7 Gb
Abriendo el archivo "G:\MEDUSA BOX\SAMSUNG_GTN7000_Repair.mf"...
Escribiendo la sección BOOT. Por favor espere...
ERROR[018]: Operación con el bloque lógico fallida en 16 Kb. (Dirección Hexadecimal 0x00004000). Razón: Command failed.
Old 12-20-2012, 15:44   #6 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 20,746
@ SYRYA TEL
Please look here: Regarding "Unknown flash device. Device No:ID = 0:00000000" with GT-I9100 or GT-N7000.
Old 07-17-2013, 20:05   #7 (permalink)
Member: 1980963
Sonork: kontol
please,. help me samsung galaxy note n7000 short
please,. help me
if in the immediate short press on and the engine so hot
how its solutions,. I beg master
Old 07-18-2013, 05:40   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Please explain the problem in more details. What is the state of your device? What is the problem with it exactly?... Does the device go into Download Mode?
Old 07-07-2016, 20:45   #9 (permalink)
Member: 2146344
Thanks Meter: 6
N7000 jtag error jtag
Log started at 09/07/2016 15:49:56 ...
Welcome to Octoplus JTAG Box Software version 1.9.5
Operating Mode: EasyRepair Mode
Checking data...
VREF = 2.56V is less than required level. Please check target device power supply.
Medusa JTAG Hardware S256 revision D.
ERROR[030]: TDO is constant high. Please check target device connection.
MI: Medusa JTAG init failed.
Checking data...
Checking data...
Checking data...
VREF = 2.55V is less than required level. Please check target device power supply.
MI: Halting target, attempt 1.
VREF level : 2.55 V
Core ID : 4BA00477
MI: Loading Medusa Device Server V1.2.
MI: Starting...
MI: Received status 0x0000F00F, cycle 0.
MI: Received server capabilities 0x00000011.
MI: Detailed server caps: FLASH, WDOG
MI: Watchdog are preconfigured.
MI: Server init.
MI: Received flash ID 0x00000000.
Checking data...
VREF level : 2.55 V
Core ID : 4BA00477
MI: Starting...
MI: Received status 0xFFFFFFFF, cycle 0.
MI: Received status 0xFFFFFFFF, cycle 1.
MI: Received status 0xFFFFFFFF, cycle 2.
MI: Failed to start Medusa Device Server.
ERROR[004]: Medusa Device Server did not replied to HELLO command.
Checking data...
VREF = 2.61V is less than required level. Please check target device power supply.
VREF level : 2.56 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF = 2.58V is less than required level. Please check target device power supply.
VREF level : 2.58 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF = 2.59V is less than required level. Please check target device power supply.
VREF level : 2.58 V
Core ID : 4BA00477
MI: Starting...
Checking data...
VREF = 2.64V is less than required level. Please check target device power supply.
Checking data...
VREF = 0.0V is less than required level. Please check target device power supply.
VREF level : 2.77 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF level : 2.77 V
Core ID : 4BA00477
MI: Starting...
Old 07-08-2016, 06:04   #10 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,401
Hi.
Please select JTAG speed 1.0 MHz and try to connect again. Also please solder JTAG wires as short as possible.
For powering the device, please use BOTH fully charged battery (or external power supply) AND USB cable, this is important! Try to connect the device a few times.
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
Nokia "Contact Service" Repairer Dirk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 10-04-2011 05:45
New!! Nokia Flash Checksum And Contact Service Repair HookerGsM Main Sales Section 0 01-02-2001 09:12
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 14:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 00:28
Page generated in 0.44805 seconds with 8 queries
