Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 06-05-2012, 11:26   #1 (permalink)
Member: 1750374
need galaxy ace flash file dump (5830)
hello team
i got s5830 in dead mode.
i repair boot and imei, done
after 2 days imei auto gone.
then i repete same.
after that 2 days imei gone again.
then i full erase,repair boot and flash.
now just logo comes and restart problam.
it may be repair with full dump write,
please give me full dump or tell me other solution.
thanks
Old 10-07-2012, 09:17   #2 (permalink)
Member: 1624056
yess sir same problemm.................phone stock loop.....
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.32, JTAG Manager Version: 1.43
Selected Resurrector: [Samsung S5830 V1.00]
Connecting to the dead body...OK
Detected dead body ID: 0x303C10E1 - CORRECT!
Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
Flashing the dead body...OK
Resurrection complete!
Old 10-07-2012, 09:22   #3 (permalink)
raezak's Avatar
Member: 260632
this is not riff section .. this is medusa section any problem from riff post at riff section
br
The Following User Says Thank You to raezak For This Useful Post:
Old 10-08-2012, 07:33   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
@ Radhika.Babe
Have You tried to write Full flash wron the support area and then we-flash the phone and Repair IMEI using Octopus Box Samsung Software? If yes - please post here full software logs with actions mentioned above. If not - please do this and also post logs here.
Old 10-12-2012, 18:53   #5 (permalink)
gseme's Avatar
Member: 789577
Sonork: 1601878
yes i have the same problem after repair s5830L phone no imei and restart please fix this problem
Old 10-12-2012, 18:56   #6 (permalink)
gseme's Avatar
Member: 789577
Sonork: 1601878
Log started at 10/10/2012 03:19:50 p.m. ...
Welcome to Medusa Box Software version 1.5.8
Selected device model: Samsung GT-S5830L
Connecting. Please wait...
VREF = 0.0V is less than required level. Please check target device power supply.
ERROR[035]: Target device has been powered off during connect.
Please connect the target device and power it on...
ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz.
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision B.
Detected TAP ID: 303C10E1, IR Length = 4.
MI: Halting target, attempt 1.
JTAG speed : 1000 KHz.
VREF level : 2.59 V
CPU : Qualcomm MSM7227T
Core ID : 303C10E1
MI: Loading Medusa Device Server V1.2.
MI: Starting...
MI: Received status 0x0000F00F, cycle 0.
MI: Received server capabilities 0x00000135.
MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL
MI: Watchdog configuration: 0xB800010C, 0x00000001... ok
MI: Server init.
MI: Received flash ID 0xB0EC0050.
MI: Flash geometry set.
MI: Recheking settings... ok
Server caps : 00000135
Flash device: Samsung OneNAND KFG4GH6Q4M
Flash ID : 00EC0050
Page size : 4096 bytes
Block size : 64 pages (256 Kb)
Block count: 2048
Flash size : 512 Mb
Write protection disabled.
Opening "D:\Medusa\SAMSUNG_GTS5830L_Repair.mf" file...
Writting BOOT section. Please wait... Done
Writting EFS section. Please wait... Done
Writting APPBOOT section. Please wait...
MI: Server status 0xFFFFFFFF (not STAT_IDLE).
ERROR[018]: Logical block operation failed at 46864 Kb (Hex address 0x02DC4000). Reason: Connection lost.
VREF level : 2.59 V
Core ID : 303C10E1
MI: Starting...
MI: Server init.
Flash ID : 00EC0050
Block count: 2048
Flash size : 512 Mb
Writting APPBOOT section. Please wait... Done
Writting UPCH section. Please wait... Done
Repairing IMEI... Done
Disconnected
Old 10-12-2012, 19:10   #7 (permalink)
gseme's Avatar
Member: 789577
Sonork: 1601878
phone its for *******r and work fine after wrong update for *******r
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.42937 seconds with 11 queries
