02-03-2020, 13:00 | #1 (permalink) |
Junior Member Join Date: May 2012 Location: algeria
Member: 1763771 Status: Offline Thanks Meter: 2 | need help! condor c8 [Answered] Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC K7XVMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 1501004B3758564D4201CD05C696A117 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : K7XVMB Full name : KMK7X000VM-B314 Product revision : 0.1 Product serial number : (hex) CD05C696 Manufacturing date : 10/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2539520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/K7XVMB_03_02_2020_12_39_44.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. |
02-03-2020, 14:54 | #3 (permalink) |
Member: 1763771 Status: Offline Thanks Meter: 2 | Code: Selected scatter file: E:/Condor_C8_(PHS-601)/MT6589_Android_scatter_emmc.txt. Scatter file type 1. Opened input file: E:/Condor_C8_(PHS-601)/preloader_phs601.bin Found 4 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : KUS00M eMMC CID : 1501004B555330304D eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : H8G2d eMMC CID : 90014A483847326404 eMMC Vendor ID : 45 (Sandisk eMMC) eMMC Model ID : 0001 eMMC Name : SEM08G eMMC CID : 45010053454D303847 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : K7XVMB eMMC CID : 1501004B3758564D42 Please select file. Writing. Please wait... Write data verification is enabled. Writing partition PRELOADER... Write data verification is enabled. Done. Writing partition MBR... Done. Writing partition EBR1... Done. Writing partition UBOOT... Done. Writing partition BOOTIMG... Done. Writing partition RECOVERY... Done. Writing partition SEC_RO... Done. Writing partition LOGO... Done. Writing partition EBR2... Done. Writing partition ANDROID... Done. Writing partition CACHE... Done. Writing partition USRDATA... Done. Writing checksums...Done. Writing finished. SW: 1.7.7; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC K7XVMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 1501004B3758564D4201CD05C696A117 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : K7XVMB Full name : KMK7X000VM-B314 Product revision : 0.1 Product serial number : (hex) CD05C696 Manufacturing date : 10/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2539520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/K7XVMB_03_02_2020_14_53_06.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. |
02-03-2020, 16:57 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | can you post S.M.A.R.T. report with medusa pro soft to see emmc health stat may be this emmc need to be changed |
The Following User Says Thank You to rebainoor For This Useful Post: |
02-03-2020, 17:10 | #5 (permalink) |
Member: 1763771 Status: Offline Thanks Meter: 2 | Code: Smart report info: Hash code: 0000000000000000000000000000000000000000000000000000000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 SW: 2.0.1; FW: 1.24. |
02-03-2020, 17:27 | #6 (permalink) | |
Member: 231728 Status: Offline Thanks Meter: 2,104 | Quote:
The Following 3 Users Say Thank You to rebainoor For This Useful Post: |
