03-19-2013, 17:27 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Need huawei u8652 full flash backup!! yes dear i try show pink color screen and not connecting |
03-19-2013, 17:30 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Have You tried to write Repair file from the Support Area? |
03-20-2013, 16:42 | #5 (permalink) |
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Log started at 16/03/2013 09:19:55 a.m. ... Welcome to Octoplus JTAG Box Software version 1.0.7 Selected device model: Huawei U8652 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 78 ns, average speed 12820 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 203C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.56 V CPU : Qualcomm MSM7227T Core ID : 203C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000037. MI: Detailed server caps: FLASH, CFG, ECC, WDOG, DWP MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xA0AD55BC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000037 Flash device: Hynix H8BES0UQ0MCR Flash ID : 00AD55BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. Connect successful. ECC Mode enabled. Opening "C:\Documents and Settings\Owner\Desktop\Huawei U8652 FullFlash 15-03-2013 15_46_38.bin" file... Reading BOOT section. Please wait... Done Reading FIRMWARE section. Please wait... Done Disconnected Selected device model: Huawei U8652 Connecting. Please wait... ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 203C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.55 V CPU : Qualcomm MSM7227T Core ID : 203C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000037. MI: Detailed server caps: FLASH, CFG, ECC, WDOG, DWP MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xA0AD55BC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000037 Flash device: Hynix H8BES0UQ0MCR Flash ID : 00AD55BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. Connect successful. |
