Member: 135661
Thanks Meter: 92 | Quote:
Originally Posted by gsmfriend hi
need LG LS755 EMMC IC pinout for repairing boot and unlock
there is no tp on motherboard ,therefore I need emmc pinout to test
direct connection with emmc
NB: EMMC is KMQE10013M (samsung) CPU mediatek MT6755V
is there any video for help
thanks. | i think this is your pinout http://forum.gsmhosting.com/vbb/f258...inout-2193633/
also you need connect tp to connect it
this log from dead sm-g615f dead boot same but still dead Quote:
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC RX14MB
Page size : 512 B
Block size : 512 B
Block count : 61071360
Size : 29.12 GB (29820.00 MB)
CID Info
CID : 150100525831344D4200FFA9DA1C4599
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : RX14MB
Product revision : 0.0
Product serial number : (hex) FFA9DA1C
Manufacturing date : 04/2018
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x04) 00000100
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 15261696 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : 47c00000 bytes
Device sector size : 512 bytes
Partition offset : 622592
Number of sectors : 6291456
Device Manufacturer :samsung
Device Platform :mt6757
Build ID :NRD90M
Display Build ID :NRD90M.G615FXXU1AQH6
Release ID :7.0
Device Model :SM-G615F
Device Name :j7maxlteins
Architecture ABI :armeabi-v7a
Architecture ABI2 :armeabi
Architecture ABI List :armeabi-v7a,armeabi
Build Description :j7maxlteins-user 7.0 NRD90M G615FXXU1AQH6 release-keys
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/RX14MB_06_09_2018_10_45_37.bin.
Connect successful.
SW: 1.6.3; FW: 1.24.
P00: GPT (00000000, 00002000) 4 MB
P01: lk (00002000, 00001000) 2048 KB
P02: seccfg (00003000, 00000800) 1024 KB
P03: efuse (00003800, 00000800) 1024 KB
P04: nvram (00004000, 00004000) 8 MB
P05: tee1 (00008000, 00004000) 8 MB
P06: bota0 (0000C000, 00002000) 4 MB
P07: bota1 (0000E000, 00002000) 4 MB
P08: bota2 (00010000, 00004000) 8 MB
P09: efs (00014000, 00004000) 8 MB
P10: protect1 (00018000, 00004000) 8 MB
P11: protect2 (0001C000, 00004000) 8 MB
P12: nvcfg (00020000, 0000C000) 24 MB
P13: nvdata (0002C000, 00010000) 32 MB
P14: param (0003C000, 00004000) 8 MB
P15: recovery (00040000, 0000C000) 24 MB
P16: boot (0004C000, 0000C000) 24 MB
P17: md1img (00058000, 00032000) 100 MB
P18: md1dsp (0008A000, 00001000) 2048 KB
P19: md1arm7 (0008B000, 00001000) 2048 KB
P20: md3img (0008C000, 00004000) 8 MB
P21: proinfo (00090000, 00001800) 3072 KB
P22: boot_para (00091800, 00000800) 1024 KB
P23: para (00092000, 00000400) 512 KB
P24: persistent (00092400, 00000400) 512 KB
P25: steady (00092800, 00002000) 4 MB
P26: nad_refer (00094800, 00002800) 5 MB
P27: reserved2 (00097000, 00001000) 2048 KB
P28: system (00098000, 00600000) 3072 MB
P29: cache (00698000, 000D8000) 432 MB
P30: hidden (00770000, 00032000) 100 MB
P31: userdata (007A2000, 0329A000) 25.3 GB
Selected pit file: L:/Samsung/SM-G/G615F/J7MAXLTE_SWA_INS.pit
Open file "L:/Samsung/SM-G/G615F/G615FXXU2ARG2_G615FODD2ARH1_INS/BL_G615FXXU2ARG2_CL14085544_QB19148692_REV00_user_ low_ship_MULTI_CERT.tar.md5".
Writing MBR...Done.
Writing primary GPT...Done.
Writing secondary GPT...Done.
Writing PIT
Write data verification is enabled.
Writing. Please wait...
Switched to boot area partition 1.
Writing partition BOOTLOADER... Done.
Switched to user area.
Writing partition lk... Done.
Writing partition efuse... Done.
Writing partition tee1... Done.
Writing partition PARAM... Done.
Writing is finished.
Disconnected.
