04-06-2017, 08:01 | #1 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | Samsung SM-G935F boot repair question [Answered] Just got dead phone from customer .. He says Phone dead during soft wifi update . I have removed emmc try factory repair but same ..Log is not with me now . anything special for this phone or factory repair should works ?? Last edited by Medusa Box; 01-11-2019 at 07:17. |
04-06-2017, 08:15 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Quote:
04-06-2017, 09:03 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Ok, the next time, when You will have such device in hands, please contact us, we will research how to repair such device. At least, we need to look at Software log with chip info and connection operation. |
04-06-2017, 10:51 | #5 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | Here is soft log Code: Welcome to Medusa Pro Software version 1.3.4. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC V2W00M Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 15010056325730304D007C8BB8CB900D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : V2W00M Product revision : 0.0 Product serial number : (hex) 7C8BB8CB Manufacturing date : 09/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/V2W00M_03_04_2017_20_59_53.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.4; FW: 1.16. P00: GPT (00000000, 00002000) P01: BOTA0 (00002000, 00002000) P02: BOTA1 (00004000, 00002000) P03: EFS (00006000, 0000A000) P04: m9kefs1 (00010000, 00002000) P05: m9kefs2 (00012000, 00002000) P06: m9kefs3 (00014000, 00002000) P07: CARRIER (00016000, 00002000) P08: PARAM (00018000, 00004000) P09: BOOT (0001C000, 00004000) P10: RECOVERY (00020000, 00004000) P11: OTA (00024000, 00004000) P12: CDMA-RADIO (00028000, 00002000) P13: RADIO (0002A000, 0000A000) P14: TOMBSTONES (00034000, 00002000) P15: TDATA (00036000, 00002000) P16: HIDDEN (00038000, 0000A000) P17: PERSDATA (00042000, 00006000) P18: RESERVED2 (00048000, 00002000) P19: CACHE (0004A000, 00096000) P20: SYSTEM (000E0000, 0048A000) P21: USERDATA (0056A000, 034D2000) Selected pit file: //192.168.0.9/SmartWare/saad/Samsung (Odin)/G935F/G935FXXU1APB8_G935FOXE1APAX_G935FXXU1APB8_6.0.1_SERVICE/G935FXXU1APB8_G935FOXE1APAX_G935FXXU1APB8_6.0.1_SERVICE/HERO2LTE_EUR_OPEN_HIDDEN150M.pit Open file "//192.168.0.9/SmartWare/saad/Samsung (Odin)/G935F/G935FXXU1ZPK4 Andriod 7/G935FXXU1ZPK4/BL_G935FXXU1ZPK4_CL9658725_QB11446888_REV00_user_low_ship.tar". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Switched to boot area partition 2. Writing partition CM... Done. Switched to user area. Writing partition PARAM... Done. Writing is finished. SW: 1.3.4; FW: 1.16. Erasing partition GPT... Done. Erasing partition BOTA0... Done. Erasing partition BOTA1... Done. Erasing partition EFS... Done. Erasing partition m9kefs1... Done. Erasing partition m9kefs2... Done. Erasing partition m9kefs3... Done. Erasing partition CARRIER... Done. Erasing partition PARAM... Done. Erasing partition BOOT... Done. Erasing partition RECOVERY... Done. Erasing partition OTA... Done. Erasing partition CDMA-RADIO... Done. Erasing partition RADIO... Done. Erasing partition TOMBSTONES... Done. Erasing partition TDATA... Done. Erasing partition HIDDEN... Done. Erasing partition PERSDATA... Done. Erasing partition RESERVED2... Done. Erasing partition CACHE... Done. Erasing partition SYSTEM... Done. Erasing partition USERDATA... Done. Erasing is finished. SW: 1.3.4; FW: 1.16. Selected pit file: //192.168.0.9/SmartWare/saad/Samsung (Odin)/G935F/G935FXXU1APB8_G935FOXE1APAX_G935FXXU1APB8_6.0.1_SERVICE/G935FXXU1APB8_G935FOXE1APAX_G935FXXU1APB8_6.0.1_SERVICE/HERO2LTE_EUR_OPEN_HIDDEN150M.pit Open file "//192.168.0.9/SmartWare/saad/Samsung (Odin)/G935F/G935FXXU1ZPK4 Andriod 7/G935FXXU1ZPK4/BL_G935FXXU1ZPK4_CL9658725_QB11446888_REV00_user_low_ship.tar". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is disabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Switched to boot area partition 2. Writing partition CM... Done. Switched to user area. Writing partition PARAM... Done. Writing is finished. SW: 1.3.4; FW: 1.16. |
04-06-2017, 11:09 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Have You removed phone's chip from the device or You found eMMC (ISP) pinout? What CPU is in the board? If possible, please make photo of phone'd PCB in high quality and post it here. |
04-06-2017, 11:59 | #8 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | i attach it to you hope that enough |
The Following User Says Thank You to Fast Unlocker For This Useful Post: |
04-06-2017, 12:53 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Yes, really, this PCB revision is with eMMC chip. Also, as I can see from your Software log, after erasing partitions You have written only "PARAM" partition, but also need to write others. Try to find another PIT file and firmware, and make Factory Repair again. |
04-06-2017, 13:52 | #11 (permalink) | |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | Quote:
04-06-2017, 14:01 | #12 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | We will find this device and try to research and develop Repair solution. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
