09-20-2017, 06:37 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello. Repairing Nokia X (Rm-980) is supported via JTAG in the old Medusa Software. Please install the latest version of old Medusa Software 2.6.1.5 (Medusa Box Downloads - Software, Drivers, Manual), select this model in Software list, press "Help" button to look at JTAG pinout picture, solder all necessary JTAG wires (make each of them as short as possible (max. 3-5 CM length)) and try to repair the phone. Don't forget to make backup (read Full flash) before repairing. Post here the result. Also, please read these rules: http://forum.gsmhosting.com/vbb/f62/...rules-1591101/, http://forum.gsmhosting.com/vbb/f664...leted-2165828/. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
09-20-2017, 07:41 | #3 (permalink) |
Freak Poster Join Date: May 2016 Location: India,Odisha Age: 27
Member: 2573604 Status: Offline Thanks Meter: 30 | Medusa JTAG Firmware version 1.22. Detected TAP ID: 007700E1, IR Length = 4. JTAG speed : 2400 KHz. VREF level : 1.77 V CPU : Qualcomm MSM8225 Core ID : 007700E1 Storage Device: Samsung eMMC S5XKMB Device ID : 00150001 Block size : 512 bytes Blocks : 7634944 Storage size : 3728 Mb Opening "C:\Program Files\GsmServer\Medusa\Firmware\NOKIA_RM-980_Repair.mf" file... Writing BOOT section. Please wait... ERROR[018]: Logical block operation failed at 16 Kb (Hex address 0x00004000). Reason: Command failed. |
09-20-2017, 08:17 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | In most cases this error means, that there is a problem with your phone's flash chip (damaged of write protected). Also, to connect the phone, try to do the next: 1. Re-solder all JTAG wires, make each of them as short as possible. 2. Fully charge phone's battery by using external charger. 3. Disconnect the phone from PC, remove the battery, then press and hold "Power" button for 10-15 seconds to fully deenergize (discharge) the phone. 4. Connect the phone to Box, press "Connect" button in Software and connect battery. Also try to connect with USB cable. 5. Try to connect the phone with different values of JTAG Speed. Try to connect the device a few times, if the problem is still present, check HW. |
