02-06-2018, 19:46 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1038150 Status: Offline Thanks Meter: 45 | OPFJ400 Desire 820N eMMC repair and no download mode [Answered] no fastboot no download mode Model Settings: Interface : eMMC Brand : HTC Model : D820N SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/HTC_D820N_EMMC_HAG2A.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG2e Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48414732650507E9789662C18B Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG2e Product revision : 0.7 Product serial number : (hex) E9789662 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HAG2e_06_02_2018_21_43_22.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. P00: GPT (00000000, 00000022) 17 KB P01: board_info (00000022, 00000020) 16 KB P02: pg1fs (00000042, 00002000) 4 MB P03: sbl1 (00002042, 00000800) 1024 KB P04: reserve_1 (00002842, 000057BE) 10.97 MB P05: mfg (00008000, 00000200) 256 KB P06: pg2fs (00008200, 0000BD7E) 23.69 MB P07: rpm (00013F7E, 00000400) 512 KB P08: tz (0001437E, 00001000) 2048 KB P09: hyp (0001537E, 00001000) 2048 KB P10: hboot (0001637E, 00002000) 4 MB P11: tool_diag (0001837E, 00002000) 4 MB P12: sp1 (0001A37E, 00002800) 5 MB P13: ddr (0001CB7E, 00000040) 32 KB P14: wcnss (0001CBBE, 00002800) 5 MB P15: rfg_0 (0001F3BE, 00000800) 1024 KB P16: rfg_1 (0001FBBE, 00000800) 1024 KB P17: rfg_2 (000203BE, 00000800) 1024 KB P18: rfg_3 (00020BBE, 00000800) 1024 KB P19: rfg_4 (000213BE, 00000800) 1024 KB P20: rfg_5 (00021BBE, 00000800) 1024 KB P21: rfg_6 (000223BE, 00000800) 1024 KB P22: rfg_7 (00022BBE, 00000800) 1024 KB P23: fsg (000233BE, 00000C00) 1536 KB P24: radio (00023FBE, 0001D802) 59 MB P25: reserve_2 (000417C0, 00006840) 13.03 MB P26: misc (00048000, 00000800) 1024 KB P27: modem_st1 (00048800, 00000C00) 1536 KB P28: modem_st2 (00049400, 00000C00) 1536 KB P29: fataldevlog (0004A000, 0000A000) 20 MB P30: devlog (00054000, 0000F000) 30 MB P31: pdata (00063000, 00000200) 256 KB P32: control (00063200, 00000020) 16 KB P33: local (00063220, 00000A02) 1281 KB P34: extra (00063C22, 00000080) 64 KB P35: cdma_record (00063CA2, 00000800) 1024 KB P36: fsc (000644A2, 00000002) 1024 b P37: ssd (000644A4, 00000010) 8 KB P38: sensor_hub (000644B4, 00000200) 256 KB P39: backup_hboot (000646B4, 00002800) 5 MB P40: reserve (00066EB4, 0000114C) 2214 KB P41: cache (00068000, 000A0000) 320 MB P42: boot (00108000, 00010000) 32 MB P43: recovery (00118000, 00010000) 32 MB P44: system (00128000, 008C0000) 4.375 GB P45: userdata (009E8000, 01300000) 9.5 GB P46: carrier (01CE8000, 0000C800) 25 MB P47: battery (01CF4800, 00005000) 10 MB Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/HTC_D820N_EMMC_HAG2A.srf". Write data verification is disabled. Writing GPT partition... Done. Writing board_info partition... Done. Writing pg1fs partition... Done. Writing sbl1 partition... Done. Writing reserve_1 partition... Done. Writing mfg partition... Done. Writing pg2fs partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing hyp partition... Done. Writing hboot partition... Done. Writing tool_diag partition... Done. Writing sp1 partition... Done. Writing ddr partition... Done. Writing wcnss partition... Done. Writing rfg_0 partition... Done. Writing rfg_1 partition... Done. Writing rfg_2 partition... Done. Writing rfg_3 partition... Done. Writing rfg_4 partition... Done. Writing rfg_5 partition... Done. Writing rfg_6 partition... Done. Writing rfg_7 partition... Done. Writing fsg partition... Done. Writing radio partition... Done. Writing reserve_2 partition... Done. Writing misc partition... Done. Writing modem_st1 partition... Done. Writing modem_st2 partition... Done. Writing fataldevlog partition... Done. Writing devlog partition... Done. Writing pdata partition... Done. Writing control partition... Done. Writing local partition... Done. Writing extra partition... Done. Writing cdma_record partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing sensor_hub partition... Done. Writing backup_hboot partition... Done. Writing reserve partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing carrier partition... Done. Writing battery partition... Done. Smart Repair is successfully complete. SW: 1.5.1; FW: 1.22. Disconnected. Last edited by Medusa Box; 02-07-2018 at 06:38. |
02-07-2018, 06:36 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. As I see from your Software log, You have done "Smart Repair" with disabled :Write data verification" option: Quote:
Also to write full flash from the Support Area and post here the result. If the problem is still the same, probably Repair file and Full flash are not compatible with your device revision or device has HW problem. Also please look here: http://forum.gsmhosting.com/vbb/f664.../#post12686846. | |
