09-28-2019, 16:55
#1 (permalink)
Member: 2822559
Sonork: 100.1683406 Thanks Meter: 101 | Samsung G531h Dead Repair Problem Medusa ? [Answered] Samsung G531h Dead Repair Problem Medusa
How to Fix This Error ? Quote:
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-G531H
SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531H_EMMC_P1J95K.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Micron eMMC P1J95K
Page size : 512 B
Block size : 512 B
Block count : 15269888
Size : 7.28 GB (7456.00 MB)
CID Info
CID : FE014E50314A39354B131D4FCB7192E9
Manufacturer ID : 0XFE
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4E
Product name : P1J95K
Product revision : 1.3
Product serial number : (hex) 1D4FCB71
Manufacturing date : 09/2015
CSD Info
CSD : D07F01320F5913FFFFFFFFEF924000A3
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 80 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.6 (for MMC v4.5, v4.51)
Erase block size : 8192 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x08) 00001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 3817472 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/P1J95K_28_09_2019_19_44_01.bin.
Connect successful.
SW: 1.7.7; FW: 1.24.
Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531H_EMMC_P1J95K.srf".
Write data verification is enabled. Switch error!!!
Writing BOOT1 partition...
Write verification error 1. Possible reasons: damaged or write protected eMMC.
Disconnected. | |
