Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 09-10-2019, 15:00   #1 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 69
oppo A3s cph1853 dead after connect and erase user data only Qualcomm
hey guys anyone can help me here i have this oppo cph1853 after i connected it with my octoplus jtag pro and erase userdata the phone died and only Qualcomm mode i did write a full dump bin and skiped this 4 and userdata and samething did restore backup ext_csd and nothing seems to work i am downloading a full extrated firmware abd will try to write and see
P01: oppodycnvbk (00005000, 00A00000) 10 MB
P02: oppostanvbk (00A05000, 00A00000) 10 MB
P03: modemst1 (01405000, 00180000) 1536 KB
P04: modemst2 (01585000, 00180000) 1536 KB
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC QE63MB
Page size : 512 B
Block size : 512 B
Block count : 30535680
Size : 14.56 GB (14910.00 MB)
CID Info
CID : 150100514536334D4203FDCEF23EC5CF
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : QE63MB
Product revision : 0.3
Product serial number : (hex) FDCEF23E
Manufacturing date : 12/2018
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x38) 00111000
Boot partition enable : User area
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7626752 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : a3e00000 bytes
Device sector size : 512 bytes
Partition offset : 2179072
Number of sectors : 7030784
Build ID :OPM1.171019.026
Release ID :8.1.0
Architecture ABI :arm64-v8a
Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi
Build Description :S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190105.224843 release-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/QE63MB_10_09_2019_13_59_58.bin.
Connect successful.
SW: 1.7.7; FW: 1.24.
P00: GPT (00000000, 00005000) 20 KB
P05: persist (01705000, 02000000) 32 MB
P06: opporeserve1 (03705000, 00800000) 8 MB
P07: opporeserve2 (03F05000, 04000000) 64 MB
P08: fsc (07F05000, 00000400) 1024 b
P09: ssd (07F06000, 00002000) 8 KB
P10: sbl1 (07F08000, 00080000) 512 KB
P11: rpm (07F88000, 00080000) 512 KB
P12: tz (08008000, 00200000) 2048 KB
P13: devcfg (08208000, 00040000) 256 KB
P14: sbl1bak (08248000, 00080000) 512 KB
P15: rpmbak (082C8000, 00080000) 512 KB
P16: tzbak (08348000, 00200000) 2048 KB
P17: devcfgbak (08548000, 00040000) 256 KB
P18: dsp (08588000, 01000000) 16 MB
P19: DDR (09800000, 00008000) 32 KB
P20: fsg (09808000, 00400000) 4 MB
P21: sec (09C08000, 00004000) 16 KB
P22: aboot (09C0C000, 00100000) 1024 KB
P23: abootbak (09D0C000, 00100000) 1024 KB
P24: modem (09E0C000, 08000000) 128 MB
P25: dtbo (11E0C000, 00800000) 8 MB
P26: vbmeta (1260C000, 00010000) 64 KB
P27: boot (1261C000, 04000000) 64 MB
P28: recovery (1661C000, 04000000) 64 MB
P29: devinfo (1A61C000, 00100000) 1024 KB
P30: splash (1A800000, 00B00000) 11 MB
P31: LOGO (1B300000, 02000000) 32 MB
P32: DRIVER (1D300000, 02000000) 32 MB
P33: cache (1F300000, 10000000) 256 MB
P34: misc (2F300000, 00100000) 1024 KB
P35: keystore (2F400000, 00080000) 512 KB
P36: config (2F480000, 00008000) 32 KB
P37: log (2F488000, 04000000) 64 MB
P38: oem (33488000, 00100000) 1024 KB
P39: limits (33800000, 00008000) 32 KB
P40: mota (34000000, 00080000) 512 KB
P41: dip (34080000, 00100000) 1024 KB
P42: mdtp (34180000, 02000000) 32 MB
P43: syscfg (36180000, 00080000) 512 KB
P44: mcfg (36200000, 00400000) 4 MB
P45: lksecapp (36800000, 00020000) 128 KB
P46: cmnlib (36820000, 00100000) 1024 KB
P47: cmnlib64 (36920000, 00100000) 1024 KB
P48: keymaster (36A20000, 00100000) 1024 KB
P49: lksecappbak (36B20000, 00020000) 128 KB
P50: cmnlibbak (36B40000, 00100000) 1024 KB
P51: cmnlib64bak (36C40000, 00100000) 1024 KB
P52: keymasterbak (36D40000, 00100000) 1024 KB
P53: apdp (37000000, 00040000) 256 KB
P54: msadp (37040000, 00040000) 256 KB
P55: dpo (37080000, 00002000) 8 KB
P56: logdump (37082000, 04000000) 64 MB
P57: vm-kystore (3B082000, 00100000) 1024 KB
P58: vm-data (3B182000, 00A00000) 10 MB
P59: hyp (3C000000, 00800000) 8 MB
P60: vm-system (3C800000, 04000000) 64 MB
P61: vm-linux (40800000, 02000000) 32 MB
P62: system (42800000, D6900000) 3433 MB
P63: vendor (119100000, 41F60000) 1055 MB
P64: userdata (15B800000, 2485FBE00) 9.131 GB
Writing EXT_CSD succesfully complete!
Disconnected.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Ok
Release ID :8.1.0
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/QE63MB_10_09_2019_14_02_07.bin.
Connect successful.
Old 09-29-2019, 11:38   #2 (permalink)
RazaKhan544's Avatar
Member: 2822559
Sonork: 100.1683406
Thanks Meter: 55
Talking
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Ok
Release ID :8.1.0
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Ok
Release ID :8.1.0
Connect successful.
i knew this medusa.
i've had OPPO A3s Phone For Tow Days
but i don't try medusa
i figured the mobile would be dead
See your mobile is dead
Old 09-29-2019, 15:52   #3 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 69
Originally Posted by RazaKhan544 View Post
i knew this medusa.
I did unlock with medusa cph1803 but 1853 didn’t work
Old 09-29-2019, 16:16   #4 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 579
You Told that Your CPH1853 Dead After Erased UserData…
for that cases need to write UserData File Only...
(extract CPH1853.ofp firmware by any supported tool & Flash Only UserData By Medusa Pro)
Please Do this & Post Results here...
[NOTE: UserData Erase is not Safe for Some Brands/Models]
Old 09-29-2019, 16:49   #5 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 69
I did write only user data but same doesn’t boot up
Old 09-29-2019, 17:13   #6 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 579
Okey…
Now Check CLK Resistor on PCB...
if doubt then Remove CLK Resistor & make a jumper on CLK line..
after that check....
Page generated in 0.33736 seconds with 7 queries
