05-28-2020, 16:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Oppo A3s CPH1853 Pattern FRP Unlock Without Losing Data Done By Medusa PRO Oppo A3s CPH1853 Pattern FRP Unlock Without Losing Data Done .::By::. .::: Medusa PRO :::. Code: Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4204D88FA8C7169D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.4 Product serial number : (hex) D88FA8C7 Manufacturing date : 01/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2179072 Number of sectors : 7030784 Build ID : OPM1.171019.026 Release ID : 8.1.0 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20191205.151001 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_23_05_2020_14_49_32.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: fsc (0003F828, 00000002) 1024 b P09: ssd (0003F830, 00000010) 8 KB P10: sbl1 (0003F840, 00000400) 512 KB P11: rpm (0003FC40, 00000400) 512 KB P12: tz (00040040, 00001000) 2048 KB P13: devcfg (00041040, 00000200) 256 KB P14: sbl1bak (00041240, 00000400) 512 KB P15: rpmbak (00041640, 00000400) 512 KB P16: tzbak (00041A40, 00001000) 2048 KB P17: devcfgbak (00042A40, 00000200) 256 KB P18: dsp (00042C40, 00008000) 16 MB P19: DDR (0004C000, 00000040) 32 KB P20: fsg (0004C040, 00002000) 4 MB P21: sec (0004E040, 00000020) 16 KB P22: aboot (0004E060, 00000800) 1024 KB P23: abootbak (0004E860, 00000800) 1024 KB P24: modem (0004F060, 00040000) 128 MB P25: dtbo (0008F060, 00004000) 8 MB P26: vbmeta (00093060, 00000080) 64 KB P27: boot (000930E0, 00020000) 64 MB P28: recovery (000B30E0, 00020000) 64 MB P29: devinfo (000D30E0, 00000800) 1024 KB P30: splash (000D4000, 00005800) 11 MB P31: LOGO (000D9800, 00010000) 32 MB P32: DRIVER (000E9800, 00010000) 32 MB P33: cache (000F9800, 00080000) 256 MB P34: misc (00179800, 00000800) 1024 KB P35: keystore (0017A000, 00000400) 512 KB P36: config (0017A400, 00000040) 32 KB P37: log (0017A440, 00020000) 64 MB P38: oem (0019A440, 00000800) 1024 KB P39: limits (0019C000, 00000040) 32 KB P40: mota (001A0000, 00000400) 512 KB P41: dip (001A0400, 00000800) 1024 KB P42: mdtp (001A0C00, 00010000) 32 MB P43: syscfg (001B0C00, 00000400) 512 KB P44: mcfg (001B1000, 00002000) 4 MB P45: lksecapp (001B4000, 00000100) 128 KB P46: cmnlib (001B4100, 00000800) 1024 KB P47: cmnlib64 (001B4900, 00000800) 1024 KB P48: keymaster (001B5100, 00000800) 1024 KB P49: lksecappbak (001B5900, 00000100) 128 KB P50: cmnlibbak (001B5A00, 00000800) 1024 KB P51: cmnlib64bak (001B6200, 00000800) 1024 KB P52: keymasterbak (001B6A00, 00000800) 1024 KB P53: apdp (001B8000, 00000200) 256 KB P54: msadp (001B8200, 00000200) 256 KB P55: dpo (001B8400, 00000010) 8 KB P56: logdump (001B8410, 00020000) 64 MB P57: vm-kystore (001D8410, 00000800) 1024 KB P58: vm-data (001D8C10, 00005000) 10 MB P59: hyp (001E0000, 00004000) 8 MB P60: vm-system (001E4000, 00020000) 64 MB P61: vm-linux (00204000, 00010000) 32 MB P62: system (00214000, 006B4800) 3433 MB P63: vendor (008C8800, 0020FB00) 1055 MB P64: userdata (00ADC000, 01242FDF) 9.131 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_modemst1_0xa028_0xc00_23_05_2020_14_49_32.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_modemst2_0xac28_0xc00_23_05_2020_14_49_32.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_fsg_0x4c040_0x2000_23_05_2020_14_49_32.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.9; FW: 1.24. Reset operation finished Backuping FRP data... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FRP_0x17a400_0x40_23_05_2020_14_49_42.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.0.9; FW: 1.24. |
The Following 2 Users Say Thank You to kabul For This Useful Post: |
