11-02-2018, 17:56 | #1 (permalink) |
Freak Poster Join Date: Aug 2014 Location: algeria
Member: 2232889 Status: Offline Thanks Meter: 91 | Oppo A3S "dead" after trying to reset [Answered] Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC S0J9F8 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 13014E53304A3946381003C07AD35533 Manufacturer ID : 0X13 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : S0J9F8 Product revision : 1.0 Product serial number : (hex) 3C07AD3 Manufacturing date : 05/2002 --------------------------------------------------------------- CSD Info CSD : D05F01328F5913FFFFFFFFEF964000A9 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 50 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 32640 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0xFF) 11111111 Boot bus width : Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : RST_n function : (0x03) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 0 Kbytes Partitions attribute : 0xFF Part setting completed: 0xFF GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0xFFFFFE00) 4096 MB ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/S0J9F8_02_11_2018_17_46_35.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. Last edited by Medusa Box; 11-03-2018 at 10:56. |
11-02-2018, 18:38 | #2 (permalink) | |
No Life Poster Join Date: Jul 2010 Location: Not Reachable Age: 31
Member: 1351351 Status: Offline Thanks Meter: 277 | Quote:
Device not connect medusa pro. Again check device is dead... Cannot turn on and no qload mode... Pls help Sent from my NX591J using Tapatalk | |
11-02-2018, 21:14 | #3 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | In your log operation the emmc chip not correctely detected please check all your isp connections You Can test to repaire it by USB connection in Qualcomm auto detect |
11-03-2018, 10:55 | #5 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Yes, as You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 1024.00 MB: Quote:
07-04-2019, 12:36 | #7 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | reson for this is emmc not well conncted probbly voltage supply is low and ofcourse while emmc is soldered it has tto be emergency qlm port reason is clk has been soldered so if it doesnt connect on desolder phone should be ohkay kindly check connection |
