09-15-2019, 10:50 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Oppo A3s Unlock Down Without Data Loss & Without Any Kind Of Dead Risk !! 1. connect with Medusa pro 2. go partition manager 3. tick only MISC and select MISC file ** If u want without data loss dn select "keep data MISC" or If u reset user data dn select "reset MISC" 4. write partition(only tick MISC) if u see phone still lock !! dont worry, go emergency dial in phone key board and just type *#813# enjoy. here is unlock log...................... Welcome to Medusa Pro Software version 1.7.7. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203D6EDD33465EF Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) D6EDD334 Manufacturing date : 06/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2064384 Number of sectors : 7030784 Build ID :OPM1.171019.026 Release ID :8.1.0 Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190717.054518 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_12_09_2019_11_49_48.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: reserve_exp1 (0003F828, 00001000) 2048 KB P09: reserve_exp2 (00040828, 00001000) 2048 KB P10: fsc (00041828, 00000002) 1024 b P11: ssd (00041830, 00000010) 8 KB P12: sbl1 (00041840, 00000400) 512 KB P13: rpm (00041C40, 00000400) 512 KB P14: tz (00042040, 00001000) 2048 KB P15: devcfg (00043040, 00000200) 256 KB P16: sbl1bak (00043240, 00000400) 512 KB P17: rpmbak (00043640, 00000400) 512 KB P18: tzbak (00043A40, 00001000) 2048 KB P19: devcfgbak (00044A40, 00000200) 256 KB P20: dsp (00044C40, 00008000) 16 MB P21: DDR (00050000, 00000040) 32 KB P22: fsg (00050040, 00000C00) 1536 KB P23: sec (00050C40, 00000020) 16 KB P24: aboot (00050C60, 00000800) 1024 KB P25: abootbak (00051460, 00000800) 1024 KB P26: modem (00051C60, 00040000) 128 MB P27: dtbo (00091C60, 00004000) 8 MB P28: vbmeta (00095C60, 00000080) 64 KB P29: boot (00095CE0, 00020000) 64 MB P30: recovery (000B5CE0, 00020000) 64 MB P31: devinfo (000D5CE0, 00000800) 1024 KB P32: splash (000D8000, 00005800) 11 MB P33: LOGO (000DD800, 00010000) 32 MB P34: DRIVER (000ED800, 00010000) 32 MB P35: cache (000FD800, 00080000) 256 MB P36: misc (0017D800, 00000800) 1024 KB P37: keystore (0017E000, 00000400) 512 KB P38: config (0017E400, 00000040) 32 KB P39: oem (0017E440, 00000800) 1024 KB P40: limits (00180000, 00000040) 32 KB P41: mota (00184000, 00000400) 512 KB P42: dip (00184400, 00000800) 1024 KB P43: mdtp (00184C00, 00010000) 32 MB P44: syscfg (00194C00, 00000400) 512 KB P45: mcfg (00195000, 00002000) 4 MB P46: lksecapp (00198000, 00000100) 128 KB P47: cmnlib (00198100, 00000800) 1024 KB P48: cmnlib64 (00198900, 00000800) 1024 KB P49: keymaster (00199100, 00000800) 1024 KB P50: lksecappbak (00199900, 00000100) 128 KB P51: cmnlibbak (00199A00, 00000800) 1024 KB P52: cmnlib64bak (0019A200, 00000800) 1024 KB P53: keymasterbak (0019AA00, 00000800) 1024 KB P54: apdp (0019C000, 00000200) 256 KB P55: msadp (0019C200, 00000200) 256 KB P56: dpo (0019C400, 00000010) 8 KB P57: logdump (0019C410, 00020000) 64 MB P58: vm-kystore (001BC410, 00000800) 1024 KB P59: vm-data (001BCC10, 00005000) 10 MB P60: hyp (001C4000, 00004000) 8 MB P61: vm-system (001C8000, 00020000) 64 MB P62: vm-linux (001E8000, 00010000) 32 MB P63: system (001F8000, 006B4800) 3433 MB P64: vendor (008AC800, 0020FB00) 1055 MB P65: userdata (00AC0000, 0125EFDF) 9.186 GB Partition table has been found on device. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition misc from C:/Program Files (x86)/Medusa Pro Software/Pin pattren Remove/keep data MISC.bin file... Done. Writing is finished. SW: 1.7.7; FW: 1.24. Reconnect the device to see changesDisconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203D6EDD33465EF Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) D6EDD334 Manufacturing date : 06/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2064384 Number of sectors : 7030784 Build ID :OPM1.171019.026 Release ID :8.1.0 Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190717.054518 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_12_09_2019_11_50_42.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: reserve_exp1 (0003F828, 00001000) 2048 KB P09: reserve_exp2 (00040828, 00001000) 2048 KB P10: fsc (00041828, 00000002) 1024 b P11: ssd (00041830, 00000010) 8 KB P12: sbl1 (00041840, 00000400) 512 KB P13: rpm (00041C40, 00000400) 512 KB P14: tz (00042040, 00001000) 2048 KB P15: devcfg (00043040, 00000200) 256 KB P16: sbl1bak (00043240, 00000400) 512 KB P17: rpmbak (00043640, 00000400) 512 KB P18: tzbak (00043A40, 00001000) 2048 KB P19: devcfgbak (00044A40, 00000200) 256 KB P20: dsp (00044C40, 00008000) 16 MB P21: DDR (00050000, 00000040) 32 KB P22: fsg (00050040, 00000C00) 1536 KB P23: sec (00050C40, 00000020) 16 KB P24: aboot (00050C60, 00000800) 1024 KB P25: abootbak (00051460, 00000800) 1024 KB P26: modem (00051C60, 00040000) 128 MB P27: dtbo (00091C60, 00004000) 8 MB P28: vbmeta (00095C60, 00000080) 64 KB P29: boot (00095CE0, 00020000) 64 MB P30: recovery (000B5CE0, 00020000) 64 MB P31: devinfo (000D5CE0, 00000800) 1024 KB P32: splash (000D8000, 00005800) 11 MB P33: LOGO (000DD800, 00010000) 32 MB P34: DRIVER (000ED800, 00010000) 32 MB P35: cache (000FD800, 00080000) 256 MB P36: misc (0017D800, 00000800) 1024 KB P37: keystore (0017E000, 00000400) 512 KB P38: config (0017E400, 00000040) 32 KB P39: oem (0017E440, 00000800) 1024 KB P40: limits (00180000, 00000040) 32 KB P41: mota (00184000, 00000400) 512 KB P42: dip (00184400, 00000800) 1024 KB P43: mdtp (00184C00, 00010000) 32 MB P44: syscfg (00194C00, 00000400) 512 KB P45: mcfg (00195000, 00002000) 4 MB P46: lksecapp (00198000, 00000100) 128 KB P47: cmnlib (00198100, 00000800) 1024 KB P48: cmnlib64 (00198900, 00000800) 1024 KB P49: keymaster (00199100, 00000800) 1024 KB P50: lksecappbak (00199900, 00000100) 128 KB P51: cmnlibbak (00199A00, 00000800) 1024 KB P52: cmnlib64bak (0019A200, 00000800) 1024 KB P53: keymasterbak (0019AA00, 00000800) 1024 KB P54: apdp (0019C000, 00000200) 256 KB P55: msadp (0019C200, 00000200) 256 KB P56: dpo (0019C400, 00000010) 8 KB P57: logdump (0019C410, 00020000) 64 MB P58: vm-kystore (001BC410, 00000800) 1024 KB P59: vm-data (001BCC10, 00005000) 10 MB P60: hyp (001C4000, 00004000) 8 MB P61: vm-system (001C8000, 00020000) 64 MB P62: vm-linux (001E8000, 00010000) 32 MB P63: system (001F8000, 006B4800) 3433 MB P64: vendor (008AC800, 0020FB00) 1055 MB P65: userdata (00AC0000, 0125EFDF) 9.186 GB |
The Following 13 Users Say Thank You to reaz.com For This Useful Post: |
09-18-2019, 12:07 | #2 (permalink) | |
Freak Poster Join Date: Aug 2014 Location: algeria
Member: 2232889 Status: Offline Thanks Meter: 91 | Quote:
09-25-2019, 15:52 | #11 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: ALGERIA Age: 42
Member: 135661 Status: Offline Thanks Meter: 92 | thanks reaz.com for this CPH1853 DONE same way but data gone Quote:
The Following User Says Thank You to zaki_barika For This Useful Post: |
