05-28-2020, 16:34 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,073 | Oppo Realme 5 RMX1911 Pattern FRP Unlock Without Losing Data Done By Medusa PRO Oppo Realme 5 RMX1911 Pattern FRP Unlock Without Losing Data Done .::By::. .::: Medusa PRO :::. Code: Please disconnect battery and USB cable. Model Settings Interface eMMC Voltage 2.2V Bus Mode 1 bit Bus speed Auto Connecting... ERROR[001] Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings Interface eMMC Voltage 2.8V Bus Mode 1 bit Bus speed Auto Connecting... Device Micron eMMC S0J9D8 Page size 512 B Block size 512 B Block count 122142720 Size 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID 13014E53304A39443810075E727B95A7 Manufacturer ID 0X13 DeviceBGA BGA (Discrete embedded) OEMApplication ID 0X4E Product name S0J9D8 Product revision 1.0 Product serial number (hex) 75E727B Manufacturing date 092018 --------------------------------------------------------------- CSD Info CSD D05F01328F5913FFFFFFFFEF964000A9 CSD structure CSD version No. 1.2 SPEC version 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1 50 ms TRAN speed 26 MHz READ block length 512 Bytes WP group enable YES PERM_WRITE_PROTECT NO TMP_WRITE_PROTECT NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size 512 Kbytes Boot1 size 4096 Kbytes Boot2 size 4096 Kbytes RPMB size 4096 Kbytes Partition config (0x38) 00111000 Boot partition enable User area (Bus width = 1Bit) Boot ACK No boot acknowledge sent (default) Boot bus conditions (0x00) 00000000 Boot bus width x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode Use single data rate + backward compatible timings in boot operation (default) RST_n function (0x01) RST_n signal is permanently enabled Partitioning support Device supports partitioning features Enhanced attribute Device can have enhanced technological features in partitions and user data area. Max enhanced data size 20348928 Kbytes Partitions attribute 0x0 Part setting completed 0x0 GP partition 1 size 0 b GP partition 2 size 0 b GP partition 3 size 0 b GP partition 4 size 0 b Enhanced area size (0x0) 0 b Enhanced area start (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok DiskImage size 8f800000 bytes Device sector size 512 bytes Partition offset 2932736 Number of sectors 9989120 Build ID PKQ1.190616.001 Release ID 9 Architecture ABI arm64-v8a Architecture ABI List arm64-v8a,armeabi-v7a,armeabi Build Description trinket-user 9 PKQ1.190616.001 eng.root.20200324.011603 release-keys Backup EXT_CSD saved to file CProgram Files (x86)Medusa Pro SoftwareEXT_CSD BackupsS0J9D8_26_05_2020_19_48_18.bin. Connect successful. --------------------------------------------------------------- SW 2.0.9; FW 1.24. P00 GPT (00000000, 00000028) 20 KB P01 oppodycnvbk (00000028, 00005000) 10 MB P02 oppostanvbk (00005028, 00005000) 10 MB P03 modemst1 (0000A028, 00001000) 2048 KB P04 modemst2 (0000B028, 00001000) 2048 KB P05 persist (0000C028, 00010000) 32 MB P06 opporeserve1 (0001C028, 00004000) 8 MB P07 opporeserve2 (00020028, 00020000) 64 MB P08 opporeserve3 (00040028, 00020000) 64 MB P09 xbl (00064000, 00001C00) 3584 KB P10 xbl_config (00068000, 00000100) 128 KB P11 tz (0006C000, 00002000) 4 MB P12 rpm (0006E000, 00000400) 512 KB P13 hyp (0006E400, 00000400) 512 KB P14 fsg (0006E800, 00001000) 2048 KB P15 fsc (00070000, 00000100) 128 KB P16 boot (00070100, 00020000) 64 MB P17 vm-kystore (00090100, 00000800) 1024 KB P18 vm-data (00090900, 00005000) 10 MB P19 vm-system (00095900, 00040000) 128 MB P20 vm-linux (000D8000, 00010000) 32 MB P21 keymaster (000E8000, 00000400) 512 KB P22 cmnlib (000E8400, 00000400) 512 KB P23 cmnlib64 (000E8800, 00000400) 512 KB P24 mdtpsecapp (000E8C00, 00002000) 4 MB P25 mdtp (000EAC00, 00010000) 32 MB P26 dsp (000FAC00, 00010000) 32 MB P27 abl (0010AC00, 00000800) 1024 KB P28 ddr (0010B400, 00000800) 1024 KB P29 bluetooth (0010BC00, 00000800) 1024 KB P30 ssd (00110000, 00000010) 8 KB P31 dtbo (00110010, 0000C000) 24 MB P32 LOGO (0011C010, 00010000) 32 MB P33 DRIVER (0012C010, 00010000) 32 MB P34 imagefv (0013C010, 00001000) 2048 KB P35 uefisecapp (0013D010, 00001000) 2048 KB P36 metadata (0013E010, 00008000) 16 MB P37 misc (00146010, 00000800) 1024 KB P38 keystore (00146810, 00000400) 512 KB P39 devcfg (00146C10, 00000100) 128 KB P40 qupfw (00146D10, 00000080) 64 KB P41 frp (00146D90, 00000400) 512 KB P42 rawdump (00147190, 00040000) 128 MB P43 devinfo (00188000, 00000008) 4 KB P44 dip (00188008, 00000800) 1024 KB P45 apdp (0018C000, 00000200) 256 KB P46 spunvm (0018C200, 00004000) 8 MB P47 splash (00190200, 00010520) 32.64 MB P48 limits (001A4000, 00000008) 4 KB P49 toolsfv (001A4008, 00000800) 1024 KB P50 logfs (001A8000, 00004000) 8 MB P51 cateloader (001AC000, 00001000) 2048 KB P52 logdump (001AD000, 00020000) 64 MB P53 multiimgoem (001D0000, 00000040) 32 KB P54 multiimgqti (001D0040, 00000040) 32 KB P55 secdata (001D0080, 00000032) 25 KB P56 catefv (001D00B8, 00000400) 512 KB P57 catecontentfv (001D04B8, 00000800) 1024 KB P58 uefivarstore (001D0CB8, 00000400) 512 KB P59 vbmeta (001D10B8, 00000080) 64 KB P60 recovery (001D1138, 00020000) 64 MB P61 modem (001F1138, 0005A000) 180 MB P62 cache (0024C000, 00080000) 256 MB P63 system (002CC000, 00986C00) 4.763 GB P64 vendor (00C52C00, 002B4800) 1385 MB P65 oppo_sec (00F07400, 00005000) 10 MB P66 storsec (00F10000, 00000100) 128 KB P67 userdata (00F14000, 06567FDF) 50.7 GB Backuping modemst1 partition... Opening CProgram Files (x86)Medusa Pro SoftwareBackupsS0J9D8_modemst1_0xa028_0x1000_26_05_2020_19_48_18.bin file... Reading. Please wait... Done. Elapsed time 000000 SW 2.0.9; FW 1.24. Backuping modemst2 partition... Opening CProgram Files (x86)Medusa Pro SoftwareBackupsS0J9D8_modemst2_0xb028_0x1000_26_05_2020_19_48_18.bin file... Reading. Please wait... Done. Elapsed time 000000 SW 2.0.9; FW 1.24. Backuping fsg partition... Opening CProgram Files (x86)Medusa Pro SoftwareBackupsS0J9D8_fsg_0x6e800_0x1000_26_05_2020_19_48_18.bin file... Reading. Please wait... Done. Elapsed time 000000 SW 2.0.9; FW 1.24. Reset operation finished Backuping FRP data... Opening CProgram Files (x86)Medusa Pro SoftwareBackupsFRP_0x5f440_0x800_26_05_2020_19_48_30.bin file... Reading. Please wait... Done. Elapsed time 000000 SW 2.0.9; FW 1.24. Removing FRP. Please wait... Done. SW 2.0.9; FW 1.24. |
The Following 2 Users Say Thank You to kabul For This Useful Post: |
05-28-2020, 16:39 | #2 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,073 | Again 1 phone Oppo Realme 5 RMX1911 Pattern FRP Unlock Without Losing Data Done .::By::. .::: Medusa PRO :::. Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Micron eMMC S0J9K9 Page size : 512 B Block size : 512 B Block count : 244285440 Size : 116.48 GB (119280.00 MB) --------------------------------------------------------------- CID Info CID : 13014E53304A394B391012F9E9978649 Manufacturer ID : 0X13 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : S0J9K9 Product revision : 1.0 Product serial number : (hex) 12F9E997 Manufacturing date : 08/2019 --------------------------------------------------------------- CSD Info CSD : D05F01328F5913FFFFFFFFEF964000A9 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 50 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 40697856 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/S0J9K9_28_05_2020_18_48_27.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.0; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00001000) 2048 KB P04: modemst2 (0000B028, 00001000) 2048 KB P05: persist (0000C028, 00010000) 32 MB P06: opporeserve1 (0001C028, 00004000) 8 MB P07: opporeserve2 (00020028, 00020000) 64 MB P08: opporeserve3 (00040028, 00020000) 64 MB P09: xbl (00064000, 00001C00) 3584 KB P10: xbl_config (00068000, 00000100) 128 KB P11: tz (0006C000, 00002000) 4 MB P12: rpm (0006E000, 00000400) 512 KB P13: hyp (0006E400, 00000400) 512 KB P14: fsg (0006E800, 00001000) 2048 KB P15: fsc (00070000, 00000100) 128 KB P16: boot (00070100, 00020000) 64 MB P17: vm-kystore (00090100, 00000800) 1024 KB P18: vm-data (00090900, 00005000) 10 MB P19: vm-system (00095900, 00040000) 128 MB P20: vm-linux (000D8000, 00010000) 32 MB P21: keymaster (000E8000, 00000400) 512 KB P22: cmnlib (000E8400, 00000400) 512 KB P23: cmnlib64 (000E8800, 00000400) 512 KB P24: mdtpsecapp (000E8C00, 00002000) 4 MB P25: mdtp (000EAC00, 00010000) 32 MB P26: dsp (000FAC00, 00010000) 32 MB P27: abl (0010AC00, 00000800) 1024 KB P28: ddr (0010B400, 00000800) 1024 KB P29: bluetooth (0010BC00, 00000800) 1024 KB P30: ssd (00110000, 00000010) 8 KB P31: dtbo (00110010, 0000C000) 24 MB P32: LOGO (0011C010, 00010000) 32 MB P33: DRIVER (0012C010, 00010000) 32 MB P34: imagefv (0013C010, 00001000) 2048 KB P35: uefisecapp (0013D010, 00001000) 2048 KB P36: metadata (0013E010, 00008000) 16 MB P37: misc (00146010, 00000800) 1024 KB P38: keystore (00146810, 00000400) 512 KB P39: devcfg (00146C10, 00000100) 128 KB P40: qupfw (00146D10, 00000080) 64 KB P41: frp (00146D90, 00000400) 512 KB P42: rawdump (00147190, 00040000) 128 MB P43: devinfo (00188000, 00000008) 4 KB P44: dip (00188008, 00000800) 1024 KB P45: apdp (0018C000, 00000200) 256 KB P46: spunvm (0018C200, 00004000) 8 MB P47: splash (00190200, 00010520) 32.64 MB P48: limits (001A4000, 00000008) 4 KB P49: toolsfv (001A4008, 00000800) 1024 KB P50: logfs (001A8000, 00004000) 8 MB P51: cateloader (001AC000, 00001000) 2048 KB P52: logdump (001AD000, 00020000) 64 MB P53: multiimgoem (001D0000, 00000040) 32 KB P54: multiimgqti (001D0040, 00000040) 32 KB P55: secdata (001D0080, 00000032) 25 KB P56: catefv (001D00B8, 00000400) 512 KB P57: catecontentfv (001D04B8, 00000800) 1024 KB P58: uefivarstore (001D0CB8, 00000400) 512 KB P59: vbmeta (001D10B8, 00000080) 64 KB P60: recovery (001D1138, 00020000) 64 MB P61: modem (001F1138, 0005A000) 180 MB P62: cache (0024C000, 00080000) 256 MB P63: system (002CC000, 00986C00) 4.763 GB P64: vendor (00C52C00, 002B4800) 1385 MB P65: oppo_sec (00F07400, 00005000) 10 MB P66: storsec (00F10000, 00000100) 128 KB P67: userdata (00F14000, 0D9E3FDF) 108.9 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/S0J9K9_modemst1_0xa028_0x1000_28_05_2020_18_48_27.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/S0J9K9_modemst2_0xb028_0x1000_28_05_2020_18_48_27.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/S0J9K9_fsg_0x6e800_0x1000_28_05_2020_18_48_27.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 1f000000 bytes Device sector size : 512 bytes Partition offset : 2932736 Number of sectors : 9989120 Build ID : PKQ1.190616.001 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : trinket-user 9 PKQ1.190616.001 eng.root.20191129.225506 release-keys ---------------------------------------------------------------Reset operation finished Backuping FRP data... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FRP_0x6d0c00_0x40_28_05_2020_18_48_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.1.0; FW: 1.24. |
