10-18-2019, 21:18 | #17 (permalink) | |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Quote:
The Following User Says Thank You to Pijush Das For This Useful Post: |
10-20-2019, 11:40 | #18 (permalink) |
Freak Poster Join Date: Aug 2014 Location: algeria
Member: 2232889 Status: Offline Thanks Meter: 91 | oppo a3s 1803 works just fine bro Welcome to Octoplus Pro JTAG Software version 1.7.7. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s_CPH1803 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_A3s_CPH1803_RESET_ISP.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A5C6A3B50DB503 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.5 Product serial number : (hex) C6A3B50D Manufacturing date : 11/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 2064384 Number of sectors : 7030784 Build ID :OPM1.171019.026 Release ID :8.1.0 Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20181103.202305 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HAG4a2_20_10_2019_11_30_28.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00005000) 20 KB P01: oppodycnvbk (00005000, 00A00000) 10 MB P02: oppostanvbk (00A05000, 00A00000) 10 MB P03: modemst1 (01405000, 00180000) 1536 KB P04: modemst2 (01585000, 00180000) 1536 KB P05: persist (01705000, 02000000) 32 MB P06: opporeserve1 (03705000, 00800000) 8 MB P07: opporeserve2 (03F05000, 04000000) 64 MB P08: reserve_exp1 (07F05000, 00200000) 2048 KB P09: reserve_exp2 (08105000, 00200000) 2048 KB P10: fsc (08305000, 00000400) 1024 b P11: ssd (08306000, 00002000) 8 KB P12: sbl1 (08308000, 00080000) 512 KB P13: rpm (08388000, 00080000) 512 KB P14: tz (08408000, 00200000) 2048 KB P15: devcfg (08608000, 00040000) 256 KB P16: sbl1bak (08648000, 00080000) 512 KB P17: rpmbak (086C8000, 00080000) 512 KB P18: tzbak (08748000, 00200000) 2048 KB P19: devcfgbak (08948000, 00040000) 256 KB P20: dsp (08988000, 01000000) 16 MB P21: DDR (0A000000, 00008000) 32 KB P22: fsg (0A008000, 00180000) 1536 KB P23: sec (0A188000, 00004000) 16 KB P24: aboot (0A18C000, 00100000) 1024 KB P25: abootbak (0A28C000, 00100000) 1024 KB P26: modem (0A38C000, 08000000) 128 MB P27: dtbo (1238C000, 00800000) 8 MB P28: vbmeta (12B8C000, 00010000) 64 KB P29: boot (12B9C000, 04000000) 64 MB P30: recovery (16B9C000, 04000000) 64 MB P31: devinfo (1AB9C000, 00100000) 1024 KB P32: splash (1B000000, 00B00000) 11 MB P33: LOGO (1BB00000, 02000000) 32 MB P34: DRIVER (1DB00000, 02000000) 32 MB P35: cache (1FB00000, 10000000) 256 MB P36: misc (2FB00000, 00100000) 1024 KB P37: keystore (2FC00000, 00080000) 512 KB P38: config (2FC80000, 00008000) 32 KB P39: oem (2FC88000, 00100000) 1024 KB P40: limits (30000000, 00008000) 32 KB P41: mota (30800000, 00080000) 512 KB P42: dip (30880000, 00100000) 1024 KB P43: mdtp (30980000, 02000000) 32 MB P44: syscfg (32980000, 00080000) 512 KB P45: mcfg (32A00000, 00400000) 4 MB P46: lksecapp (33000000, 00020000) 128 KB P47: cmnlib (33020000, 00100000) 1024 KB P48: cmnlib64 (33120000, 00100000) 1024 KB P49: keymaster (33220000, 00100000) 1024 KB P50: lksecappbak (33320000, 00020000) 128 KB P51: cmnlibbak (33340000, 00100000) 1024 KB P52: cmnlib64bak (33440000, 00100000) 1024 KB P53: keymasterbak (33540000, 00100000) 1024 KB P54: apdp (33800000, 00040000) 256 KB P55: msadp (33840000, 00040000) 256 KB P56: dpo (33880000, 00002000) 8 KB P57: logdump (33882000, 04000000) 64 MB P58: vm-kystore (37882000, 00100000) 1024 KB P59: vm-data (37982000, 00A00000) 10 MB P60: hyp (38800000, 00800000) 8 MB P61: vm-system (39000000, 04000000) 64 MB P62: vm-linux (3D000000, 02000000) 32 MB P63: system (3F000000, D6900000) 3433 MB P64: vendor (115900000, 41F60000) 1055 MB P65: userdata (158000000, 2533FBE00) 9.301 GB Repairing from file "C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_A3s_CPH1803_RESET_ISP.srf". Write data verification is enabled. Writing misc partition... Done. Writing config partition... Done. Smart Repair is successfully complete. SW: 1.7.7; FW: 1.24. Disconnected. |
The Following User Says Thank You to AnonDz For This Useful Post: |
11-19-2021, 20:02 | #24 (permalink) |
Junior Member Join Date: Dec 2013 Location: india,roorkee,uttarakhand
Member: 2090321 Status: Offline Thanks Meter: 4 | My isp connector not connect Every emmc error extcsd data error connect unsuccessful I have tried everything set voltages bus speed vcc vccq data cable without data cable external power supply but its fails please help me how to connect isp connector to phone |
