09-15-2017, 22:31 | #1 (permalink) |
Crazy Poster Join Date: Jun 2016
Member: 2584885 Status: Offline Thanks Meter: 30 | Is Possible?! Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 Bus speed : 15 Connecting... Device : Samsung eMMC 8GME4R Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 15010038474D45345201B349FC1D3461 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 8GME4R Product revision : 0.1 Product serial number : (hex) B349FC1D Manufacturing date : 03/2001 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/8GME4R_15_09_2017_18_20_36.bin. Connect successful. [/IMG] [/IMG] [/IMG] br |
09-16-2017, 08:10 | #2 (permalink) | ||||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Quote:
BTW, You have not connected the device correctly. eMMC size (capacity) can't be 1 GB: Quote:
09-19-2017, 16:18 | #3 (permalink) |
Member: 2584885 Status: Offline Thanks Meter: 30 | ok, I think it's a stabilization problem or compatibility, because the one I used is in perfect condition, its memory is 8GB, but only 1GB. I tried with all voltages and mhz and they all connect the same, I tried masmo with external power, and it stays the same. sorry my bad English |
