02-10-2014, 16:02
#1 (permalink)
Member: 1129443
Thanks Meter: 3 | Problem with e970 I have one lg e970 connecting as qualcomm, after boot repair phone power on download mode... i flash with OCtopus LG but phone still poweron in downlaod mode... log of jtag Quote:
Log started at 2/7/2014 8:43:52 AM ...
Welcome to Medusa Box Software version 2.1.3
Operating Mode: EasyRepair Mode
Selected device model: LG E970
Connecting. Please wait...
VREF = 0.0V is less than required level. Please check target device power supply.
ERROR[035]: Target device has been powered off during connect.
Please connect the target device and power it on...
ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz.
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision B.
Detected TAP ID: 4BA00477, IR Length = 4.
Detected TAP ID: 107190E1, IR Length = 11.
MI: Halting target, attempt 1.
JTAG speed : 1000 KHz.
VREF level : 1.73 V
CPU : Qualcomm APQ8064
Core ID : 107190E1
MI: Loading Medusa Device Server V1.2.
MI: Starting...
MI: Received status 0x0000F00F, cycle 0.
MI: Received server capabilities 0x00000191.
MI: Detailed server caps: FLASH, WDOG, A64, IOCTL
MI: Watchdog configuration: 0xB800010C, 0x00000001... ok
MI: Server init.
MI: Received flash ID 0xE0110001.
MI: Flash geometry set.
MI: Recheking settings... ok
Server caps : 00000191
Storage Device: Unknown eMMC 016G92
Device ID : 00110001
Block size : 512 bytes
Blocks : 30777344
Storage size : 14.7 Gb
Opening "C:\Users\Claudio\Documents\LG_E970_Repair.mf" file...
Writing BOOT section. Please wait...
MI: Server status 0xFFFFFFFF (not STAT_IDLE).
ERROR[018]: Logical block operation failed at 1568 Kb (Hex address 0x00188000). Reason: Connection lost.
VREF = 1.70V is less than required level. Please check target device power supply.
ERROR[030]: TDO is constant high. Please check target device connection.
MI: Medusa JTAG init failed.
VREF level : 1.77 V
Core ID : 107190E1
MI: Starting...
MI: Server init.
Blocks : 30777344
Writing BOOT section. Please wait... Done
Disconnected
