12-28-2017, 12:02 | #1 (permalink) |
Insane Poster Join Date: Dec 2016 Location: Belo Horizonte - MG
Member: 2658469 Status: Offline Thanks Meter: 20 | Question about boot mode [Answered] Its possible an device works with the configuration boot; Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) The second line says (default). Thank you. Last edited by Medusa Box; 12-28-2017 at 12:24. |
12-28-2017, 12:19 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
"Device not boot enabled" means, that device boots from "User Parition Area", not from "Boo1 Parition Area". If You change eMMC chip, You should always set correct "Partition config" value - the same, as was on the original eMMC, when device was working. That's why we upload "Live Log" (text file with correct device connection info, which contains also necessary "Partition config" settings) together with SRF (Smart Repair File) into the Support Area. | |
12-28-2017, 13:35 | #3 (permalink) |
Member: 2658469 Status: Offline Thanks Meter: 20 | [QUOTE=Medusa Box;12869537] "Device not boot enabled" means, that device boots from "User Parition Area", not from "Boo1 Parition Area". So, what is the difference between Boot partition enable (Device not boot enabled and Boot partition enable User area, if Devise not boot Default it looks for boot in User Area. Both are the same? Did you understand my question? |
12-28-2017, 20:06 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Similar, but different bit values. More info You can read from official JEDEC eMMC specification: https://www.jedec.org/standards-docu...ufs-emmc/e-mmc, http://www.issi.com/WW/pdf/IS21_22ES...G_32G_64GB.pdf, http://yourcmc.ru/wiki/images/5/55/EMMC_JESD84-A441.pdf. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
