01-06-2018, 16:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1867244 Status: Offline Thanks Meter: 63 | A question [Answered] accourding to support area live log this is the boot configuration of LG G3 D855 -------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : User area Partition config : 00111000 Backup EXT_CSD saved to file D:/Projects/Octoplus_JTag/build/EXT_CSD Backups/SDW16G_17_08_2016_09_10_32.bin. Connect successful. but today i have removed a sandisk 32G chip from a live and working phone and boot config was like this Model Settings: Interface : eMMC Voltage : 3.2V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Sandisk eMMC SDW32G Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 45010053445733324701AB17808F71A1 Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : SDW32G Product revision : 0.1 Product serial number : (hex) AB17808F Manufacturing date : 07/2014 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFFEF8A40401F CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 14385152 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 720896 Number of sectors : 4227072 Device Manufacturer : lge Device Platform : msm8974 Build ID : MRA58K Display Build ID : MRA58K Release ID : 6.0 Device Model : LG-D855 Device Name : g3_global_com Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : g3_global_com-user 6.0 MRA58K 16271181728f3 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/SDW32G_06_01_2018_18_53_46.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. P00: GPT (00000000, 00008000) 16 MB P01: modem (00008000, 00020000) 64 MB P02: sbl1 (00028000, 00000800) 1024 KB P03: dbi (00028800, 00000400) 512 KB P04: DDR (00028C00, 00000400) 512 KB P05: aboot (00029000, 00001000) 2048 KB P06: rpm (0002A000, 00000800) 1024 KB P07: tz (0002A800, 00000800) 1024 KB P08: pad (0002B000, 00000008) 4 KB P09: sbl1b (0002B008, 00000800) 1024 KB P10: dbibak (0002B808, 00000400) 512 KB P11: rpmbak (0002BC08, 00000800) 1024 KB P12: tzbak (0002C408, 00000800) 1024 KB P13: rpmf (0002CC08, 00000800) 1024 KB P14: tzf (0002D408, 00000800) 1024 KB P15: sdif (0002DC08, 00000400) 512 KB P16: abootf (0002E008, 00001000) 2048 KB P17: spare1 (0002F008, 00000FF8) 2044 KB P18: boot (00030000, 00008000) 16 MB P19: persist (00038000, 00010000) 32 MB P20: recovery (00048000, 00008000) 16 MB P21: modemst1 (00050000, 00001800) 3072 KB P22: modemst2 (00051800, 00001800) 3072 KB P23: pad1 (00053000, 00000008) 4 KB P24: fsg (00053008, 00001800) 3072 KB P25: fsc (00054808, 00000400) 512 KB P26: ssd (00054C08, 00000400) 512 KB P27: pad2 (00055008, 00000008) 4 KB P28: encrypt (00055010, 00000400) 512 KB P29: eksst (00055410, 00000400) 512 KB P30: rct (00055810, 00000010) 8 KB P31: spare2 (00055820, 000027E0) 4.984 MB P32: misc (00058000, 00008000) 16 MB P33: laf (00060000, 00010000) 32 MB P34: fota (00070000, 00010000) 32 MB P35: spare3 (00080000, 00008000) 16 MB P36: drm (00088000, 00004000) 8 MB P37: sns (0008C000, 00004000) 8 MB P38: mpt (00090000, 00010000) 32 MB P39: factory (000A0000, 00010000) 32 MB P40: system (000B0000, 00408000) 2064 MB P41: cache (004B8000, 00130000) 608 MB P42: cust (005E8000, 00080000) 256 MB P43: userdata (00668000, 033D5BF5) 25.92 GB P44: grow (03A3DBF5, 000003EA) 501 KB EXT_CSD saved to file D:/pc 2/Dump/LG/D 855/EXT_CSD_06_01_2018_18_54_27.bin. so im a little confused about which one is the correct boot config for this model a little help please Last edited by Medusa Box; 01-08-2018 at 17:55. |
01-06-2018, 23:30 | #2 (permalink) |
Insane Poster Join Date: Dec 2016 Location: Belo Horizonte - MG
Member: 2658469 Status: Offline Thanks Meter: 20 | Hello Hello Friend, the log live says; ================================== EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : User area ================================== Change boot mode to user area and install full flash. [QUOTE=mastershex;12888054] EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : User area Partition config : 00111000 Backup EXT_CSD saved to file D:/Projects/Octoplus_JTag/build/EXT_CSD Backups/SDW16G_17_08_2016_09_10_32.bin. Connect successful. but today i have removed a sandisk 32G chip from a live and working phone and boot config was like this |
01-07-2018, 16:42 | #3 (permalink) | |
Member: 1867244 Status: Offline Thanks Meter: 63 | [QUOTE=sidnei35;12888574]Hello Friend, the log live says; ================================== EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : User area ================================== Change boot mode to user area and install full flash. Quote:
but phone is ok and completely working and i just needed to read out a full dump ... emmc is ok 1000000% | |
01-08-2018, 17:55 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | @ mastershex Hello. Accordingly to your Software log, device was connected correctly, and if thi eMMC chip is from working device, so eMMC settings in your log is correct for your phone revision. As You can see "Live Log" on the Support Area is from device with another eMMC chip (from 16GB eMMC chip, but in your your device is 32GB chip), so they can be diffent. |
