11-27-2018, 08:56 | #1 (permalink) |
Freak Poster Join Date: Oct 2017
Member: 2773088 Status: Offline Thanks Meter: 24 | Reading dump via ADB question [Solved] Last edited by Octopus box; 11-27-2018 at 13:36. |
11-27-2018, 09:02 | #3 (permalink) |
Member: 2773088 Status: Offline Thanks Meter: 24 | Welcome to Medusa Pro Software version 1.6.8. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.6V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010051333133424200FF839705549B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) FF839705 Manufacturing date : 05/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q313BB_26_11_2018_23_49_42.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.8; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000400) 512 KB P04: rpm (00002C00, 00000400) 512 KB P05: tz (00003000, 00001000) 2048 KB P06: aboot (00004000, 00001000) 2048 KB P07: sec (00005000, 00000200) 256 KB P08: lksecapp (00005200, 00000400) 512 KB P09: keymaster (00005600, 00000400) 512 KB P10: cmnlib (00005A00, 00000200) 256 KB P11: fsg (00005C00, 00002000) 4 MB P12: cmnlib64 (00007C00, 00000200) 256 KB P13: pad (00007E00, 00000200) 256 KB P14: modemst1 (00008000, 00002000) 4 MB P15: modemst2 (0000A000, 00002000) 4 MB P16: efs (0000E000, 00008000) 16 MB P17: fsc (00016000, 00001A00) 3328 KB P18: ssd (00017A00, 00000200) 256 KB P19: devcfg (00017C00, 00000200) 256 KB P20: apdp (00017E00, 00000100) 128 KB P21: msadp (00017F00, 00000100) 128 KB P22: param (00018000, 00006000) 12 MB P23: backup (0001E000, 00002000) 4 MB P24: boot (00020000, 00010000) 32 MB P25: recovery (00030000, 00010000) 32 MB P26: bota (00040000, 00004000) 8 MB P27: fota (00044000, 00002000) 4 MB P28: persist (00046000, 00010000) 32 MB P29: persistent (00056000, 00000800) 1024 KB P30: steady (00056800, 00002000) 4 MB P31: keystore (00058800, 00000800) 1024 KB P32: config (00059000, 00000800) 1024 KB P33: dsp (00059800, 00008000) 16 MB P34: modem (00061800, 00030000) 96 MB P35: apnhlos (00091800, 00012000) 36 MB P36: reserved2 (000A3800, 00000800) 1024 KB P37: system (000A4000, 006D8000) 3504 MB P38: cache (0077C000, 00096000) 300 MB P39: userdata (00812000, 01546000) 10.64 GB Write data verification is enabled. Write partitions from D:/j727r4 dump.mpt file... Writing partition GPT... Done. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition ddr... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition aboot... Done. Writing partition sec... Done. Writing partition lksecapp... Done. Writing partition keymaster... Done. Writing partition cmnlib... Done. Writing partition fsg... Done. Writing partition cmnlib64... Done. Writing partition pad... Done. Writing partition fsc... Done. Writing partition ssd... Done. Writing partition devcfg... Done. Writing partition apdp... Done. Writing partition msadp... Done. Writing partition param... Done. Writing partition backup... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition bota... Done. Writing partition fota... Done. Writing partition persist... Done. Writing partition persistent... Done. Writing partition steady... Done. Writing partition keystore... Done. Writing partition config... Done. Writing partition dsp... Done. Writing partition modem... Done. Writing partition apnhlos... Done. Writing partition reserved2... Done. Writing partition cache... Done. SW: 1.6.8; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.6V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010051333133424200FF839705549B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) FF839705 Manufacturing date : 05/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q313BB_26_11_2018_23_56_22.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.8; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000400) 512 KB P04: rpm (00002C00, 00000400) 512 KB P05: tz (00003000, 00001000) 2048 KB P06: aboot (00004000, 00001000) 2048 KB P07: sec (00005000, 00000200) 256 KB P08: lksecapp (00005200, 00000400) 512 KB P09: keymaster (00005600, 00000400) 512 KB P10: cmnlib (00005A00, 00000200) 256 KB P11: fsg (00005C00, 00002000) 4 MB P12: cmnlib64 (00007C00, 00000200) 256 KB P13: pad (00007E00, 00000200) 256 KB P14: modemst1 (00008000, 00002000) 4 MB P15: modemst2 (0000A000, 00002000) 4 MB P16: efs (0000E000, 00008000) 16 MB P17: fsc (00016000, 00001A00) 3328 KB P18: ssd (00017A00, 00000200) 256 KB P19: devcfg (00017C00, 00000200) 256 KB P20: apdp (00017E00, 00000100) 128 KB P21: msadp (00017F00, 00000100) 128 KB P22: param (00018000, 00006000) 12 MB P23: backup (0001E000, 00002000) 4 MB P24: boot (00020000, 00010000) 32 MB P25: recovery (00030000, 00010000) 32 MB P26: bota (00040000, 00004000) 8 MB P27: fota (00044000, 00002000) 4 MB P28: persist (00046000, 00010000) 32 MB P29: persistent (00056000, 00000800) 1024 KB P30: steady (00056800, 00002000) 4 MB P31: keystore (00058800, 00000800) 1024 KB P32: config (00059000, 00000800) 1024 KB P33: dsp (00059800, 00008000) 16 MB P34: modem (00061800, 00030000) 96 MB P35: apnhlos (00091800, 00012000) 36 MB P36: reserved2 (000A3800, 00000800) 1024 KB P37: system (000A4000, 006D8000) 3504 MB P38: cache (0077C000, 00096000) 300 MB P39: userdata (00812000, 01547FD8) 10.64 GB Disconnected. |
