03-16-2020, 20:45 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: algeria
Member: 1480336 Status: Offline Sonork: 100.1606959 Thanks Meter: 76 | Realme 5 dead after oppo reset [Solved] I check clk line seem To be ok Please help Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 10 MHz Connecting... Device : Micron eMMC S0J9K9 Page size : 512 B Block size : 512 B Block count : 244285440 Size : 116.48 GB (119280.00 MB) --------------------------------------------------------------- CID Info CID : 13014E53304A394B391011D690B876AF Manufacturer ID : 0X13 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : S0J9K9 Product revision : 1.0 Product serial number : (hex) 11D690B8 Manufacturing date : 07/2019 --------------------------------------------------------------- CSD Info CSD : D05F01328F5913FFFFFFFFEF964000A9 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 50 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 40697856 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 1f000000 bytes Device sector size : 512 bytes Partition offset : 2932736 Number of sectors : 9989120 Build ID : PKQ1.190616.001 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : trinket-user 9 PKQ1.190616.001 eng.root.20191224.002823 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/S0J9K9_16_03_2020_16_48_51.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.6; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00001000) 2048 KB P04: modemst2 (0000B028, 00001000) 2048 KB P05: persist (0000C028, 00010000) 32 MB P06: opporeserve1 (0001C028, 00004000) 8 MB P07: opporeserve2 (00020028, 00020000) 64 MB P08: opporeserve3 (00040028, 00020000) 64 MB P09: xbl (00064000, 00001C00) 3584 KB P10: xbl_config (00068000, 00000100) 128 KB P11: tz (0006C000, 00002000) 4 MB P12: rpm (0006E000, 00000400) 512 KB P13: hyp (0006E400, 00000400) 512 KB P14: fsg (0006E800, 00001000) 2048 KB P15: fsc (00070000, 00000100) 128 KB P16: boot (00070100, 00020000) 64 MB P17: vm-kystore (00090100, 00000800) 1024 KB P18: vm-data (00090900, 00005000) 10 MB P19: vm-system (00095900, 00040000) 128 MB P20: vm-linux (000D8000, 00010000) 32 MB P21: keymaster (000E8000, 00000400) 512 KB P22: cmnlib (000E8400, 00000400) 512 KB P23: cmnlib64 (000E8800, 00000400) 512 KB P24: mdtpsecapp (000E8C00, 00002000) 4 MB P25: mdtp (000EAC00, 00010000) 32 MB P26: dsp (000FAC00, 00010000) 32 MB P27: abl (0010AC00, 00000800) 1024 KB P28: ddr (0010B400, 00000800) 1024 KB P29: bluetooth (0010BC00, 00000800) 1024 KB P30: ssd (00110000, 00000010) 8 KB P31: dtbo (00110010, 0000C000) 24 MB P32: LOGO (0011C010, 00010000) 32 MB P33: DRIVER (0012C010, 00010000) 32 MB P34: imagefv (0013C010, 00001000) 2048 KB P35: uefisecapp (0013D010, 00001000) 2048 KB P36: metadata (0013E010, 00008000) 16 MB P37: misc (00146010, 00000800) 1024 KB P38: keystore (00146810, 00000400) 512 KB P39: devcfg (00146C10, 00000100) 128 KB P40: qupfw (00146D10, 00000080) 64 KB P41: frp (00146D90, 00000400) 512 KB P42: rawdump (00147190, 00040000) 128 MB P43: devinfo (00188000, 00000008) 4 KB P44: dip (00188008, 00000800) 1024 KB P45: apdp (0018C000, 00000200) 256 KB P46: spunvm (0018C200, 00004000) 8 MB P47: splash (00190200, 00010520) 32.64 MB P48: limits (001A4000, 00000008) 4 KB P49: toolsfv (001A4008, 00000800) 1024 KB P50: logfs (001A8000, 00004000) 8 MB P51: cateloader (001AC000, 00001000) 2048 KB P52: logdump (001AD000, 00020000) 64 MB P53: multiimgoem (001D0000, 00000040) 32 KB P54: multiimgqti (001D0040, 00000040) 32 KB P55: secdata (001D0080, 00000032) 25 KB P56: catefv (001D00B8, 00000400) 512 KB P57: catecontentfv (001D04B8, 00000800) 1024 KB P58: uefivarstore (001D0CB8, 00000400) 512 KB P59: vbmeta (001D10B8, 00000080) 64 KB P60: recovery (001D1138, 00020000) 64 MB P61: modem (001F1138, 0005A000) 180 MB P62: cache (0024C000, 00080000) 256 MB P63: system (002CC000, 00986C00) 4.763 GB P64: vendor (00C52C00, 002B4800) 1385 MB P65: oppo_sec (00F07400, 00005000) 10 MB P66: storsec (00F10000, 00000100) 128 KB P67: userdata (00F14000, 0D9E3FDF) 108.9 GB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/S0J9K9_modemst1_0xa028_0x1000_16_03_2020_16_48_51. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.6; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/S0J9K9_modemst2_0xb028_0x1000_16_03_2020_16_48_51. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.6; FW: 1.24. Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/S0J9K9_fsg_0x6e800_0x1000_16_03_2020_16_48_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.6; FW: 1.24. Reset operation finished Disconnected. |
03-24-2020, 11:20 | #6 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Please, download and install this .SRF file after connect your pinouts same as described in this file, set 1.8V and speed to Auto (2.8 may damage your device) write repair and try to put your device into Recovery Mode from there You can reflash your device. |
03-31-2020, 00:41 | #7 (permalink) |
Member: 1480336 Status: Offline Sonork: 100.1606959 Thanks Meter: 76 | solved with isp . oppo reset not work . i remove cmd and make jump on clk and D0 phone working now . and about pinout first one work |
The Following User Says Thank You to fethirx For This Useful Post: |
