05-25-2020, 09:30 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | Repair lg k10 dual sim k430dsy no download mode & recovery REPAIR LG K10 DUAL SIM K430DSY WON'T GOES DOWNLOAD MODE OR RECOVERY BY THE GIANT MEDUSA PRO SINCE IT'S MTK I SAW THAT BOOT MODE WAS DISABLED BY DEFAULT AND THAT WAS THE PROBLEM IT WAS SIMPLY EASY TO RECOVER IT BY ENABLING BOOT AND FLASH SMOOTHLY FIRMWARE KDZ LOG INFO : Code: Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: Alcor Micro USB Smart Card Reader 2 Loading firmware. Please wait... Done. Selected eMMC interface. Selected PIN - CONNECTOR socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 50 MHz Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420DA8A268671415 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) A8A26867 Manufacturing date : 01/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 884736 Number of sectors : 6176768 Device Manufacturer : lge Device Platform : mt6753 Build ID : MRA58K Display Build ID : MRA58K Release ID : 6.0 Device Model : LG-K430 Device Name : m253_global_com Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : m253_global_com-user 6.0 MRA58K 1708319266d90 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_25_05_2020_07_06_58.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 2.00. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: misc2 (00001C00, 00004000) 8 MB P03: ftm (00005C00, 00004000) 8 MB P04: nvram (00009C00, 00002800) 5 MB P05: protect1 (0000C400, 00005000) 10 MB P06: protect2 (00011400, 00005000) 10 MB P07: lk (00016400, 00001000) 2048 KB P08: lkbak (00017400, 00001000) 2048 KB P09: laf (00018400, 0000E000) 28 MB P10: para (00026400, 00000400) 512 KB P11: boot (00026800, 00008000) 16 MB P12: recovery (0002E800, 00008000) 16 MB P13: recoverybak (00036800, 00008000) 16 MB P14: logo (0003E800, 00004000) 8 MB P15: lo_bak_go (00042800, 00004000) 8 MB P16: expdb (00046800, 00005000) 10 MB P17: seccfg (0004B800, 00000400) 512 KB P18: oemkeystore (0004BC00, 00001000) 2048 KB P19: secro (0004CC00, 00003000) 6 MB P20: keystore (0004FC00, 00004000) 8 MB P21: tee1 (00053C00, 00002800) 5 MB P22: tee2 (00056400, 00002800) 5 MB P23: eksst (00058C00, 00000400) 512 KB P24: encrypt (00059000, 00000400) 512 KB P25: persist_lg (00059400, 00004000) 8 MB P26: mpt (0005D400, 0000B000) 22 MB P27: persistent (00068400, 00001000) 2048 KB P28: lgfota (00069400, 00005000) 10 MB P29: cust (0006E400, 00032000) 100 MB P30: rct (000A0400, 00000800) 1024 KB P31: factory (000A0C00, 0000E000) 28 MB P32: persist (000AEC00, 00018000) 48 MB P33: efuse (000C6C00, 00000400) 512 KB P34: frp (000C7000, 00000800) 1024 KB P35: nvdata (000C7800, 00010800) 33 MB P36: system (000D8000, 005E4000) 3016 MB P37: cache (006BC000, 00064000) 200 MB P38: OP (00720000, 00008000) 16 MB P39: userdata (00728000, 015EEC00) 10.97 GB P40: flashinfo (01D16C00, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE13MB_nvdata_0xc7800_0x10800_25_05_2020_07_06_58.bin file... Reading. Please wait... Done. Elapsed time 00:00:05 SW: 2.0.9; FW: 2.00. RPMB: Authentication Key not yet programmed. LOG CHANGING BOOT CONFIGURATION : Code: SW: 2.0.9; FW: 2.00. Boot config succesfully changed! Disconnected. LOG FACTORY REPAIR : Code: Opening E:/FLASH TELEPHONE/LG/K/K430dsY/K430dsY10i_00_0915.kdz file... Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition preloader... Done. Switched to user area. Writing partition pgpt... Done. Writing partition lk... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition logo... Done. Writing partition secro... Done. Writing partition tee1... Done. Writing partition tee2... Done. Writing partition cust... Done. Writing partition factory... Done. Writing partition efuse... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition OP... Done. Writing partition sgpt... Done. Writing is finished. SW: 2.0.9; FW: 2.00. Disconnected. Download MEDUSA PRO II Software Find out more at: https://medusabox.com/ Download Octoplus PRO JTAG Software Find out more at: www.octoplusbox.com |
The Following User Says Thank You to starkrimes For This Useful Post: |
