01-11-2020, 15:40 | #1 (permalink) |
Major Poster Join Date: Feb 2012
Member: 1728056 Status: Offline Thanks Meter: 110 | repaire emmc huawei y6ii cam-l21 Code: Repairing from file "E:/Huawei_CAM-L21.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing vrl partition... Done. Writing vrl_bkup partition... Done. Writing mcuimage partition... Done. Writing frp partition... Done. Writing fastboot partition... Done. Writing modemnvbkup partition... Done. Writing nvme partition... Done. Writing oeminfo partition... Done. Writing splash partition... Done. Writing modemnvm1 partition... Done. Writing modemnvm2 partition... Done. Writing modemnvm3 partition... Done. Writing securetystorage partition... Done. Writing 3rdmodemnvm partition... Done. Writing 3rdmodemnvmback partition... Done. Writing reserved1 partition... Done. Writing modemlog partition... Done. Writing splash2 partition... Done. Writing misc partition... Done. Writing modemnvreserved partition... Done. Writing recovery2 partition... Done. Writing reserved2 partition... Done. Writing teeos partition... Done. Writing trustfirmware partition... Done. Writing sensorhub partition... Done. Writing hifi partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing dtimage partition... Done. Writing modemimage partition... Done. Writing dsp partition... Done. Writing dfx partition... Done. Writing 3rdmodem partition... Done. Writing cache partition... Done. Writing hisitest0 partition... Done. Writing hisitest1 partition... Done. Writing hisitest2 partition... Done. Smart Repair is successfully complete. Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Huawei Model : CAM-L21 SRF : E:/Huawei_CAM-L21.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132D4550B30401447 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 13.4 Product serial number : (hex) 550B3040 Manufacturing date : 01/2017 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 1835008 Number of sectors : 5242880 Device Manufacturer : hi6210sft Device Platform : hi6210sft Build ID : MRA58K Display Build ID : deleted Release ID : 6.0 Device Model : hi6210sft Device Name : hi6210sft Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : deleted Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4a2_13_01_2020_15_04_16.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.2; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: vrl (00000400, 00000200) 256 KB P02: vrl_bkup (00000600, 00000200) 256 KB P03: mcuimage (00000800, 00000200) 256 KB P04: frp (00000A00, 00000600) 768 KB P05: fastboot (00001000, 00002000) 4 MB P06: modemnvbkup (00003000, 00003000) 6 MB P07: nvme (00006000, 00002000) 4 MB P08: oeminfo (00008000, 00010000) 32 MB P09: splash (00018000, 00004000) 8 MB P10: modemnvm1 (0001C000, 00008000) 16 MB P11: modemnvm2 (00024000, 00008000) 16 MB P12: modemnvm3 (0002C000, 00008000) 16 MB P13: securetystorage (00034000, 00010000) 32 MB P14: 3rdmodemnvm (00044000, 00008000) 16 MB P15: 3rdmodemnvmback (0004C000, 00008000) 16 MB P16: reserved1 (00054000, 00006000) 12 MB P17: modemlog (0005A000, 00008000) 16 MB P18: splash2 (00062000, 00020000) 64 MB P19: misc (00082000, 00001000) 2048 KB P20: modemnvreserved (00083000, 0000C000) 24 MB P21: recovery2 (0008F000, 00020000) 64 MB P22: reserved2 (000AF000, 00010000) 32 MB P23: teeos (000BF000, 00002000) 4 MB P24: trustfirmware (000C1000, 00001000) 2048 KB P25: sensorhub (000C2000, 00008000) 16 MB P26: hifi (000CA000, 00006000) 12 MB P27: boot (000D0000, 0000C000) 24 MB P28: recovery (000DC000, 00020000) 64 MB P29: dtimage (000FC000, 00010000) 32 MB P30: modemimage (0010C000, 00020000) 64 MB P31: dsp (0012C000, 00004000) 8 MB P32: dfx (00130000, 00008000) 16 MB P33: 3rdmodem (00138000, 00002000) 4 MB P34: cache (0013A000, 00080000) 256 MB P35: hisitest0 (001BA000, 00001000) 2048 KB P36: hisitest1 (001BB000, 00001000) 2048 KB P37: hisitest2 (001BC000, 00004000) 8 MB P38: system (001C0000, 00500000) 2560 MB P39: cust (006C0000, 00100000) 512 MB P40: userdata (007C0000, 0159A000) 10.8 GB كود: |
The Following 6 Users Say Thank You to kaka88 For This Useful Post: |
