08-25-2019, 08:34 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Armenia, Armavir
Member: 616204 Status: Offline Thanks Meter: 26 | Replacing EMMC on Philips W8510 [Answered] 1. It happens that 2 identical EMMCs (H9TP32A8JDMC) were with different volumes of the partitions boot1, boot 2 and RPM ???? 2. Is it possible to change these partitions on skHynix EMMC with Medusa Pro ???? 3. The volumes of these partitions are critical or not ?????? 4. Is it possible to change the configuration and CID of the Samsung EMMC under the SkHinyx and flash the appropriate firmware ??? Thank you in advance |
08-29-2019, 08:30 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello. 2. What exactly You want to change, it's not clear?! 3. All must be set to original values, same as in log file 4. Yes, You can edit CID, but there is some eMMC where You can't do that |
09-06-2019, 20:41 | #3 (permalink) |
Member: 616204 Status: Offline Thanks Meter: 26 | Hi You dont answer 1. It happens that 2 identical EMMCs (H9TP32A8JDMC) were with different volumes of the partitions boot1, boot 2 and RPM ???? and 3. The volumes of these partitions are critical or not ?????? Thanks for Advance |
