05-15-2020, 15:35 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | samsung A107F repair fail [Answered] Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QD63MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100514436334D42031FFB06FFB6AF Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QD63MB Product revision : 0.3 Product serial number : (hex) 1FFB06FF Manufacturing date : 11/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 2899968 Number of sectors : 7176192 Device Manufacturer : samsung Build ID : PPR1.180610.011 Display Build ID : PPR1.180610.011.A107FXXU5ATA9 Release ID : 9 Device Model : SM-A107F Device Name : a10sxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : a10sxx-user 9 PPR1.180610.011 A107FXXU5ATA9 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QD63MB_15_05_2020_15_31_28.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: boot_para (00002000, 00000800) 1024 KB P02: para (00002800, 00000400) 512 KB P03: efuse (00002C00, 00000400) 512 KB P04: nvram (00003000, 00020000) 64 MB P05: efs (00023000, 00004000) 8 MB P06: sec_efs (00027000, 00004000) 8 MB P07: bota (0002B000, 0000A800) 21 MB P08: param (00035800, 00002000) 4 MB P09: up_param (00037800, 00002000) 4 MB P10: expdb (00039800, 0000A000) 20 MB P11: frp (00043800, 00000800) 1024 KB P12: nvcfg (00044000, 00010000) 32 MB P13: nvdata (00054000, 00020000) 64 MB P14: metadata (00074000, 00010000) 32 MB P15: protect1 (00084000, 00004000) 8 MB P16: protect2 (00088000, 00004000) 8 MB P17: seccfg (0008C000, 00004000) 8 MB P18: persist (00090000, 00018000) 48 MB P19: persistent (000A8000, 00000400) 512 KB P20: misc (000A8400, 00003C00) 7.5 MB P21: sec1 (000AC000, 00001000) 2048 KB P22: proinfo (000AD000, 00001800) 3072 KB P23: md1img (000AE800, 00032000) 100 MB P24: spmfw (000E0800, 00000800) 1024 KB P25: scp1 (000E1000, 00000800) 1024 KB P26: sspm_1 (000E1800, 00000800) 1024 KB P27: lk (000E2000, 00001000) 2048 KB P28: steady (000E3000, 00002000) 4 MB P29: boot (000E5000, 00010000) 32 MB P30: recovery (000F5000, 00010000) 32 MB P31: dtbo (00105000, 00004000) 8 MB P32: tee1 (00109000, 00003000) 6 MB P33: vendor (0010C000, 000E0000) 448 MB P34: product (001EC000, 000D8000) 432 MB P35: system (002C4000, 006D8000) 3504 MB P36: vbmeta (0099C000, 00004000) 8 MB P37: cache (009A0000, 000C8000) 400 MB P38: omr (00A68000, 00018000) 48 MB P39: userdata (00A80000, 02FBC000) 23.87 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QD63MB_efs_0x23000_0x4000_15_05_2020_15_31_28.bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.0.9; FW: 1.24. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QD63MB_nvdata_0x54000_0x20000_15_05_2020_15_31_28. bin file... Reading. Please wait... ERROR[011]: Read error. Attempting to read... Done. Elapsed time 00:00:39 SW: 2.0.9; FW: 1.24. |
05-15-2020, 23:22 | #2 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | you need to change the voltage for low and bits & speed bus to get stable connection |
The Following 3 Users Say Thank You to starkrimes For This Useful Post: |
05-26-2020, 12:49 | #4 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Or use pollup 2x resistance 150 ohm to stabilise connection And You need fix your boot config for mtk cpu In your log its wrong Quote:
The Following User Says Thank You to rebainoor For This Useful Post: |
