05-11-2020, 06:09 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | Samsung A30 SM-A305F AVOID BOX ERRORS & CONNECTION HERE I WANT SHARE TO MEDUSA/OCTOPLUS USERS THE BEST SOLUTION FOR MAKING BEST BOX CONNECTION AND AVOID ERRORS & DAMAGED RESISTORS CMD AND CLK AND ALSO FOR USERS WHO GOT REDUCED STORAGE CAPACITY FROM 64GB TO 32GB OR 16GB IF YOU GOT PHONE DETECTED ON PC AS EXYNOS 7xxx AFTER EMMC CONNECTION FAILLED BEFORE THAT THREAD THEN THE SOLUTION IS HERE FIRST MAKE CLK JUMPER IF PROBLEM SAME CHANGE THE RESISTOR CLK RESISTOR VALUE IS : 22OHM,5%,1/20W IF PROBLEM STILL CHANGE CMD RESISTOR CMD RESISTOR VALUE IS : 10KOHM,1%,1/20W PLEASE DO ALL STEPS AS I WRITE HERE TO AVOID ALL PROBLEMS FIRST YOU NEED 2 RESISTORS 150 OHM.5% ( END WITH GOLD LINE FOR STABILITY CONNECTION) THE 150 OHM RESISTORS MUST BOTH SOLDERING 1 SIDE OF EACH TO 2.9V AND THE OTHER SIDE 1 TO CMD AND OTHER TO DATA0 ON BOX ADAPTER AND HERE IS THE RESULT : LOG INFO : Code: Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: Alcor Micro USB Smart Card Reader 2 Loading firmware. Please wait... Done. Selected eMMC interface. Selected PIN - CONNECTOR socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 50 MHz Connecting... Device : Samsung eMMC CUTA42 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100435554413432005FDFFA23564F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CUTA42 Product revision : 0.0 Product serial number : (hex) 5FDFFA23 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 557056 Number of sectors : 9830400 Device Manufacturer : samsung Build ID : PPR1.180610.011 Display Build ID : PPR1.180610.011.A305FDDU4ATA2 Release ID : 9 Device Model : SM-A305F Device Name : a30dd Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a30dd-user 9 PPR1.180610.011 A305FDDU4ATA2 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CUTA42_11_05_2020_00_39_46.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: bota0 (00002000, 00002000) 4 MB P02: bota1 (00004000, 00004000) 8 MB P03: efs (00008000, 0000A000) 20 MB P04: sec_efs (00012000, 0000A000) 20 MB P05: cpefs (0001C000, 00004000) 8 MB P06: bota2 (00020000, 00004000) 8 MB P07: cm (00024000, 00004000) 8 MB P08: m9kefs1 (00028000, 00002000) 4 MB P09: m9kefs2 (0002A000, 00002000) 4 MB P10: m9kefs3 (0002C000, 00002000) 4 MB P11: nad_refer (0002E000, 00000800) 1024 KB P12: param (0002E800, 00004000) 8 MB P13: up_param (00032800, 00004000) 8 MB P14: misc (00036800, 00001000) 2048 KB P15: boot (00037800, 00012000) 36 MB P16: recovery (00049800, 0001A800) 53 MB P17: dtb (00064000, 00004000) 8 MB P18: dtbo (00068000, 00004000) 8 MB P19: radio (0006C000, 00016800) 45 MB P20: persistent (00082800, 00000400) 512 KB P21: steady (00082C00, 00002000) 4 MB P22: vbmeta (00084C00, 00000400) 512 KB P23: bota3 (00085000, 00000400) 512 KB P24: reserved2 (00085400, 00002C00) 5.5 MB P25: system (00088000, 00960000) 4.688 GB P26: vendor (009E8000, 0011C000) 568 MB P27: product (00B04000, 000C8000) 400 MB P28: cache (00BCC000, 000C8000) 400 MB P29: omr (00C94000, 00019000) 50 MB P30: cp_debug (00CAD000, 00002800) 5 MB P31: nad_fw (00CAF800, 0000A000) 20 MB P32: userdata (00CB9800, 067C0000) 51.88 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CUTA42_efs_0x8000_0xa000_11_05_2020_00_39_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.0.9; FW: 2.00. RPMB: Counter of the successful data write requests = 5067. LOG READING FULL DUMP WITHOUT ERRORS: Code: Opening C:/Users/STARKRIMES/Desktop/A305FDDU4ATA2_United_Arab_Emirates_Android_9/Samsung eMMC CUTA42_11_05_2020_00_40_13.bin file... Reading. Please wait... Done. Elapsed time 02:51:14 SW: 2.0.9; FW: 2.00. NOTICE : SRF FILE WITH PINOUTS WILL BE SEND TO TEAM AFTER UPLOAD ALSO SRF FILE CAN HELP YOU TO DOWNGRADE DEVICE AND IT HAS FRP REMOVED SO NO NEED TO ERASE PERSISTENT PARTITION FOR SAFE SO PLEASE DON'T ASK ME HERE FOR FILES |
The Following 4 Users Say Thank You to starkrimes For This Useful Post: |
05-11-2020, 06:33 | #2 (permalink) |
Member: 1191316 Status: Offline Thanks Meter: 900 | And here i flash stock rom just for improving also writing LOG ZRITING FLASH : Code: Selected pit file: C:/Users/STARKRIMES/Desktop/A305FDDU4ATA2_United_Arab_Emirates_Android_9/A30_SWA_OPEN.pit Open file "C:/Users/STARKRIMES/Desktop/A305FDDU4ATA2_United_Arab_Emirates_Android_9/BL_A305FDDU4ATA2_CL17281663_QB28661799_REV00_user_low_ship.tar.md5". Open file "C:/Users/STARKRIMES/Desktop/A305FDDU4ATA2_United_Arab_Emirates_Android_9/AP_A305FDDU4ATA2_CL17281663_QB28661799_REV00_user_low_ship_meta_OS9.tar.md5". Open file "C:/Users/STARKRIMES/Desktop/A305FDDU4ATA2_United_Arab_Emirates_Android_9/CP_A305FXXU4ATA1_CP14896210_CL17281663_QB28606723_REV00_user_low_ship.tar.md5". Open file "C:/Users/STARKRIMES/Desktop/A305FDDU4ATA2_United_Arab_Emirates_Android_9/CSC_OMC_OJM_A305FOJM4ATA1_CL17281663_QB28606723_REV00_user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... from 0 to 898 Done. Switched to user area. Writing partition CM... from 24000 to 253 Done. Writing partition PARAM... from 2E800 to E80 Done. Writing partition BOOT... from 37800 to 81B2 Done. Writing partition RECOVERY... from 49800 to D6A5 Done. Writing partition DTB... from 64000 to 80 Done. Writing partition DTBO... from 68000 to 10A Done. Writing partition RADIO... from 6C000 to A369 Done. Writing partition VBMETA... from 84C00 to 7 Done. Writing partition SYSTEM... from 88000 to 524D9A Done. Writing partition VENDOR... from 9E8000 to 58685 Done. Writing partition PRODUCT... from B04000 to 36269 Done. Writing partition CACHE... from BCC000 to 4 Done. Writing partition OMR... from C94000 to 3 Done. Writing partition CP_DEBUG... from CAD000 to 181C Done. Writing partition USERDATA... from CB9800 to 133E3E Done. Writing is finished. SW: 2.0.9; FW: 2.00. |
12-19-2020, 14:50 | #3 (permalink) |
Freak Poster Join Date: Feb 2017
Member: 2686635 Status: Offline Thanks Meter: 94 | im make 150 ohm but same issu try with 1.8 and 2.8 bus speed 50 1 bit and 4 bit but not connect phone and error in a305f and other device oppo realme connect ok but help this issu |
12-21-2020, 09:03 | #6 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. You need to solder resistors to VCCQ. Besides, next settings, must be set to: Voltage 2.0V Frequency: 1-2Mhz You need to use short wires. |
12-23-2020, 13:48 | #7 (permalink) | |
Member: 2686635 Status: Offline Thanks Meter: 94 | wrong Quote:
sort cmd to vccq and data0 to vccq your post im see and make solder 2 resistore vcc to d0 and cmd now my phone short and dead wrong info not a vcc vccq is perfect for this solution | |
