04-21-2018, 18:21 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: San Fernando La Union Age: 34
Member: 2068959 Status: Offline Thanks Meter: 252 | Samsung GT-N7100 connection question [Answered] Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N7100 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf Voltage : 1.8V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 15010056545530304DF780F6213A2123 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VTU00M Product revision : 15.7 Product serial number : (hex) 80F6213A Manufacturing date : 02/1998 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_21_04_2018_10_17_33.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Read verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Last edited by Medusa Box; 04-23-2018 at 04:47. |
04-21-2018, 18:33 | #2 (permalink) |
Member: 2068959 Status: Offline Thanks Meter: 252 | maybe CLK Is Problem When IM Press Connect button i Try To Removed CLK From wire software is saccessfully connect but when im trying to connect again soft is not detect why sorry for my bad english |
04-23-2018, 04:47 | #3 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. As You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 1024.00 MB: Quote:
The Following 2 Users Say Thank You to Medusa Box For This Useful Post: |
